Page 97 of 131 FirstFirst ... 4787888990919293949596979899100101102103104105106107 ... LastLast
Results 961 to 970 of 1303
Thread: LSX (VOID) released
  1. #961
    Apr 2006
    when i type in "San Francisco, CA", it somehow shows San Francisco, Argentina... and none of the numbers are displaying correctly... it displays something like A^o(degree)
  2. #962
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    what are the three dots in the front of the command for? If the LSONSKINSTART command isnt present it will break the ratings plugin intergration and other things. Actually i see your using the ONSKINSTART command also, without the custom button code so this will break the entire skin.
    what does the ANTISTATUS do, i dont see it defined anywhere.
    Any case, i still think its just easier to ask guino to make a status label that does it, less stuff to manage. I havnt tried the code below so i dont know if it works or not or what the results are.
    Quote Originally Posted by deus ex machina View Post
    I hath rigged it thusly:
    ExecTBL.ini:
    Code:
    "ONSKINSTART","...LSONSKINSTART||PLAY||SETVARBYCODE;ANTISTATUS;STATUS||PLAY"
    skin:
    Code:
    B,312,363,159,76,"SETVARBYCODE;ANTISTATUS;STATUS||PLAY",@MUTE@
    L,323,420,147,30,255,255,255,12,"Arial:B","=$ANTISTATUS$","CENTER"
    I don't know if it's possible to sync the webdings label with the state. I think if the play state were returned as a number (like STATUSNUM), that would be best. Then you could use BYVAR to do this, right?
    beer replenishment fund
    mp3car live search
  3. #963
    Constant Bitrate deus ex machina's Avatar
    Mar 2006
    The elipses were just for the sake of the post. The whole line is in the file.
    I was not aware that variables must be defined somewhere. But evidently I was right because it works!
    "PLAY||SETVARBYCODE;ANTISTATUS;STATUS||PLAY"
    /change from either stopped or playing to paused, save the status to ANTISTATUS, change to either stopped^h^h^h^h^h^h^hplaying or paused (depending on orginal state)
    /save status, then play (which switches the status)
    /display old status before play button was triggered
  4. #964
    Aug 2003
    Chicago
    Quote Originally Posted by itstdt View Post
    I need more details on what your trying to do and where your doing it. As it is now i have no idea what your talking about.
    mp3car live search
  5. #965
    Aug 2003
    Chicago
    /change from either stopped or playing to pause, save the status to ANTISTATUS, change to either stopped or paused (depending on orginal state)
    i understand what your doing better now. Im a little burned out right now. Im still concerned about the ONSKINSTART command though. It seems like you are replaceing the entire command instead of adding on to it and this will break the skin.
    mp3car live search
  6. #966
    Apr 2006
    i type that in in RRConfig, at the very bottom
    Weather Settings
    City, State
    San Francisco, CA
    Weather Units
    USA
  7. #967
    Aug 2003
    Chicago
    @deus ex machina
    just gave it a try, and it works. How its working, im not sure. I know if you have an ONSKINSTART command in the ExecTBL thats in the root of RR and in the one in the skin folder, it will break the skin. But for some reason dosent seem to care about it being 2 of them in the same file.
    I think there is a way to change the play label though based on the state, so you could have a pause icon then the arrow at the right times. You could also use an image instead of the arrow text.
    edit:
    does seem to be some small issues with this, when RR first starts up the status is blank, is this why you have the 2 play commands?
    mp3car live search
  8. #968
    Aug 2003
    Chicago
    Weather Settings
    City, State
    San Francisco, CA
    Weather Units
    USA
    I have no idea why it says Argentina instead of Cali. I tried it and it also says that for me. There is nothing i can do about that, i didnt code the weather plugin, i just skinned it. Thats why questions like these really should be posted in the general RoadRunner forum instead of in the skins. You'll get better help if the questions are directed to the right place so the right people can see them.
    Maybe try to spell California instead of CA and see if that works.
    mp3car live search
  9. #969
    Aug 2003
    Chicago
    ahhhh! ok, i thought you had a whole new line of code, the ... threw me waaay off. I though thats the way you had it in the file, and i was even more confused by the word "elipses" i never knew thats what they were officially called. I just allways called them 3dots, LOL.
    but it works good, the only thing being the quick pause/play while it sets the label. I think originaly when i first started using RR i wanted it to work like this, but since have just gotten used to the way it worked. I think i may still drop guino a line about it though, it dosent seem to respond if you modify the state outside of RR, like from a remote.
    mp3car live search
  10. #970
    May 2004
    Ok, after my 200 miles trip today I have some stuff to report on.
    1- Is it easy to change the font colors for the tracks and highlighted track, especially on the main skin? (I've never made a skin so I'm not sure) Reason is, the red text on the dark background is hard to read in the day. The white text is much easier to read and I was thinking of either swapping the current track with the white and the other tracks with red or changing the red to another color like green, teal or yellow.
    2- I was having difficulty with the VIS OPT functionality. I tried changing to the small vis screen and some other options but it didn't change anything. I was still getting the large vis and the menus kept looking the same. I may have broken something which caused this to happen because I editted menu.skin's 3rd line to use the no album art background:
    menu_alt_noAA_off.jpg,menu_alt_noAA_off.jpg,menu_a lt_on.jpg,menu_alt_on.jpg
    Could this have broken the VIS OPT functionality?
    3- In the previous version of the skin, I was able to get the XM channel logos on pages 1 and 2 and the track listing on the bottom between the volume buttons. Now, I get nothing except the channel name at the top right. Is this related to item #2 with the larger viz screens or something else?
    4- A few days ago I told you about the << and >> issue in the main screen with an XM favorite playlist where I would have the XM Favorites list selected but the main screen would scan through all the channels. I have the same problem on the GPS screen. (It works fine on the main screen, thanks!)
    5- On the GPS screens, sometimes when I am playing with the GPS program (either MM or iG) the XM channel changes. It's almost like the XM skin underneath is acting on the areas I am pressing in the GPS area.
    Either way, the 200 mile trip went alot smoother thanks to your skin and guino's amazing work on RR. Thanks!!!
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
