Page 99 of 131 FirstFirst ... 498990919293949596979899100101102103104105106107108109 ... LastLast
Results 981 to 990 of 1303
Thread: LSX (VOID) released
  1. #981
    May 2004
    Quote Originally Posted by liquid_smoke View Post
    just to make sure, you do know what the red dot is right?
    Honestly, no. I thought it was representative of the mouse dragging
  2. #982
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    In RR.ini
    usegesture=false and the red dot is gone.
  3. #983
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by tmar89 View Post
    ok that explains your problem.
    RR has gesture support. When you click and drag your mouse in predefined shapes or gestures it will execute a command. The red dot appears when the gesture is being drawn.
    Likely you are in the gps screen and while you are trying to click a button your finger drags also, activating the gestures, and executing commands based on how you dragged your finger.
    You can either
    A: read up on the gesture feature and learn how it works and use it for quick access to commands.
    B: Turn it off
    Open RRConfig.exe or from inside the skin click the "Config" button > "Settings" button and uncheck "Gestures Enabled (default)"
    beer replenishment fund
    mp3car live search
  4. #984
    May 2004
    Thanks. Yeah I still have alot to learn about RR.
  5. #985
    Aug 2003
    Chicago
    One thing ive been thinking about doing, not sure if its better or not.
    The quickmenu, accessed from the top middle where the gps speed is. Is also customizeable so you can stick whatever commands you want in there and they will show up on any screen where the quickmenu is available.
    I was thinking about making the quick menu context sensitive or unique for each screen that its available on. So for example on the main screen you could have buttons in the menu that are generic actions, like shutdown,mini,lock etc. But if you go to the audio screen the quick menu would show audio related options that aren't currently avail in the audio player.
    The only downside to doing it like this would be that you dont have the same commands available on every screen which was the whole point of the quickmenu to begin with.
    Just wanted to put that out there and see what others thoughts are on the matter. So if your happy with the way the quick menu works now, say so, if you would like to see context quick menus say so also.
    thanks.
    mp3car live search
  6. #986
    May 2004
    Oh I never realized that functionality. Right now when I click on the GPS speed in the top middle it goes to Audio, and does that on each screen. Are you saying that you're thinking about allowing that command to be custom to each screen? I thought you meant the drop down list that appears when you press the time was the quick menu. So in my opinion, I don't see any extra need to have it customizable on each screen since I really don't use it. Each screen for me has exactly what I need.
    Also, on a side note, can the GPS speed be changed to say a scrolling song title instead of GPS speed? It's kinda defunct for me since I use Mapmonkey most of the time and it just says 0 Mi/h.
  7. #987
    Aug 2003
    Chicago
    by default it should open the quickmenu, i moved it from the time, time now minimizes. You have to copy and paste the ADDTORR.ini stuff again to see the changes if you've been using the skin for a long time.
    Or just click and hold the gps speed and choose "MENU" from the command list (2ndscreen). Then you get the popup menu.
    mp3car live search
  8. #988
    Aug 2003
    Chicago
    the gps speed will work no matter what gps app you use.
    For this to work a few requirements need to be met first.
    1. Split your GPS com port (search for xport)
    this allows you to have more than one application access your gps port at the same time.
    2. Set the gps port in RRConfig.exe
    now the speed will show how fast ur going.
    mp3car live search
  9. #989
    May 2004
    Thanks! Never knew about this app.
  10. #990
    May 2004
    I went to go download 1.6 and 1.6 patch and Kaspersky picked this up:
    detected: Trojan program Trojan-Downloader.Win32.Agent.axn URL: hxxp://download.andgear.com/rr/skins/LSX/VOID/lsxvoid1.6patch1.exe/UPX/LSTOOLS\ALT\copy_bbaa_big.exe/PE_Patch.UPX/UPX
    detected: Trojan program Trojan-Downloader.Win32.Agent.axn URL: hxxp://download.andgear.com/rr/skins/LSX/VOID/lsxvoid1.6.exe/LSTOOLS\IG3scripts\Itinerary.exe/PE_Patch.UPX/UPX
    Anything to worry about or should this be ok?
  1. LSX....void
    By liquid_smoke in forum RR Skins
    Last Post: 05-06-2006, 06:59 PM
  2. LSX Scripts
    By Osiris in forum RR Skins
    Last Post: 01-14-2006, 11:13 PM
  3. QT 4 crossplatform released
    By s003apr in forum Software & Software Development
    Last Post: 07-02-2005, 04:41 PM
  4. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  5. Lorty's mp3car plugin 2.4.08 released
    By lorty in forum Software & Software Development
    Last Post: 01-19-2001, 10:47 AM
