"Changes", are just that. If you have changed, say the Menu skin, to add code say to the GPS button, to load something special, it will be overwritten if you let it. Same goes for any changes to the Main menu IMAGES, moving buttons around ect.
If anyone has made any changes, the best thing to do, is to rename the Blue Devil folder. Then run the installer, and let it install everything. Then just copy over whatever images or individual skin files that you have altered.
I put this together, as I have had a lot of comments on not knowing what to update, and having to copy all the files over manually each and every time. This was to try to make it MUCH easier, when the updates are released. It also allows the skin to work "out of the box", meaning the DLL"s are registerd automatically, so when you install the skin, the Screen Lock utility works as soon as the skin is loaded, without having to deal with registering the Dll's ect.
Hehehe Glad you found it, as I was about to say check the help file, as it explains in great detail how to get the clock logo set up![]()
LinkBack URL
About LinkBacks
, but that takes a whole 3 seconds outta my life. im just playing if no one was able to understand...
I have used my friend's slingplayer on his
