what spelling mistake?
I am technically only half Colombian.
Was WAITING for someone to catch that one! I noticed it in the car today! It was me just being really stupid! When I redid the Video screen, I did it from scratch, (Was one of the very first screens I did, and I seem to have loast the PSD's) and forgot to add those back buttons in! I will work on it tonight and be fixed in the next release.
My Fiero Build Thread
AfterDigital, and SangreDeThor: Don't MAKE me separate you two!![]()
I have yet to tackle the whole OBD thing as of yet. But there are quite a few programs out there, and one works with this car, one with that one, one that sinnable, one thats not, I doubt if I will try to tackle this. If I DO tackle one it will be the one HERE. As that will work with MY car
If, and when I do tackle it, I will gladly share the PSD's that will match the skin, so you can try to get it to work with whatever software that you are using. Again, this is a pretty big IF and, even then it is quite some time away for sure.
try me!
Thanks for this skin. To me this is the most usable skin and good looking skin. Great work.
Does anybody have a problem with window start toolbar appearing when you use iguidance? also, whenever i load iguidance, it would load as if it was an external program and then it will embed in roadrunner. is there a way to fix this, cause it doens't look smooth that way. I think it's is because it's loading as an external application that the window toolbar show up on top on road runner. when i click HOME the toolbar disappear. it only happen when i click gps and click on the map. also, how do i make the equalizer preset work. I downloaded several different skin and i don't have success with the equalizer. i thought you just click on whichever one and that's it. but it's probably more complicated then that. please let me know.
How do you set up the gps gauge? I read your help file and it just say to download xport, but how does the program know which com port the information is at. where do i input the com port so the program knows the data is there. i set up iguidance on com 9, so it knows data is there. i hope you understand the question. thank you
@tuan 823
In the RRconfig under GPS setting, there's an entry for GPSport, in there use the com port you have free when you setup a virual port splitter like Xport..
Ok Now SangreDeThor! This is the last warning! If I DO have seperate you two, it is gonna be a "lío sangriento!"(Bloody mess) hahah! ME making a "play on words in Spanish! Hahah
Just like WSF1 said, but in a bit more detail:
(Actually I was gonna say you didn't read far enough in the help file, but realized I added detailed instructions AFTER the last update that has been posted heheheeh)
Fire up Xport, set the top com port to the port you GPS receiver is ACTUALLY ON. If you don't know, open device manager, and then open the com ports tree. Looking at the com ports, unplug the GPS receiver, and one will disappear, wait a few seconds and plug the GPS back in, the port that appears is your actual gps port, put that in the top box.
In the lower part of Xport (Enable it of course), and set up your virtual com ports, for instance 5 & 6. You are done with Xport now. No Put Port 5 in RR's GPS config, and port 6 in your GPS program in this example. Now your REAL COM port is split to to virtual ones, as you see you can have many more than just 2 com ports set up in Xport.
