Page 46 of 101 FirstFirst ... 36373839404142434445464748495051525354555696 ... LastLast
Results 451 to 460 of 1006
Thread: Blue Devil Skin RELEASED
  1. #451
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    ok John, i'll explain
    BTW, i have read your guide through and even some FAQ's here on the roadrunner forum. proud of meself patontheback:
    According to legend (heehee) i'm suppose to go to RRConfig.exe and under GPS put under City "New York" - i do and save the file. When i go back to the file the city is not there. Unless i'm suppose to put "New York, NY" city AND state??
    Also, when i press one of the 5 buttons at the top of the screen as you mentioned, nothing happens.
    To be sure i grabbed the latest RoadRunner release 10-08-06 (i think).
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
  2. #452
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Hi,
    1st off: Blue Devil is a beautiful piece of work.
    now,
    Some questions:
    -- When I press the GPS button on the main screen I don't get the gps program to start (at all), however it starts fine when I go into music and then select gps -- What am I messing up?
    -- How does one add Favorites/POI's within BD (for IGuidance)?
    -- Does S/PDIF work with the equalizer?
    -- The flash objects (in the center) seem to be leading to "overrun" errors (all, but the default one that is).
    -- Where do the .ini file go to change the look of IGuidance?
    Again, I would like to comment on how BEAUTIFUL Blue Devil really is....
    Nasa
  3. #453
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    iGuidace questions
    Quote Originally Posted by nasa View Post
    Hi,
    now,
    Some questions:
    Nasa
    Thanks for the compliments!
    1) Sounds like you do not have GPS set up correctly in the Road RUnner Config utility. Run that, and go to the GPS section, and put the path to iGuidance and the witdow title 'iGuidance". The Audio player screen has that path built into the button, thats why it is working from that screen.
    2) You can either press the menu button and browse to favorites, press the top right arrow and go into favorites, ect. As for POI, pressing the POI button will toggle them on and off. You can set what POI's are displayed in the iGuidance setup, by selecting menu, settings, display options, and custom.
    3) I am not sure what you mean by "overrun errors".
    4) Place the theme.ini file in the root directory of iGuidance. If one is there already, back it up so you can switch back if you want to later.
    My Fiero Build Thread
  4. #454
    Nov 2006
    plx help a dummy
    iam new to the scene , i love the blue devil and all is working fine but... the gps stats. what ALL is needed to get this to work. i have the delorme usb gps with the usb to com port program running in order to make the ig3 work, just need help with e gps stats. thanks in advance. do i need xport3 or something? i see no menus or areas for setting any kinda of settings to get it to work.
  5. #455
    Constant Bitrate jeffreyd_tx's Avatar
    Sep 2006
    Wilkes-Barre, Pennsylvania, United States
    Quote Originally Posted by clonecds View Post
    Search and you shall find the answer... I will give you a hint, it is in this thread and not that far back!
  6. #456
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Gps
    As this is your very fist post, Welcome to the forums! You might want to search and see if you can find an answer to your solution first though
    If you are using the Delorme serial emulator, that has the icon in the system tray, open that, and set one virtual com port for use with Iguidance, and one for Road Runnner. Then you need to go into Road Runner config and set the com port in there. The gauges use the same port that RR is using.
    If you are looking for a better explination, check the Blue Devil Help file as well.
  7. #457
    Jun 2002
    Virginia
    iGuidance Questions
    I have a couple of questions about using iGuidance in this skin.
    1. In iGuidance options whenever I try to change one of the settings I get a message that the necessary vbs file hasn't been found in the specified directory notwithstanding that the files appear to be in the correct location (see attached graphics).
    2. What does the balloon button (like someone's talking in a cartoon) on the right hand side do?
    3. What does the auto config button do? I know it brings up the iGuidance options screen, but sometimes it has the word "on" in red just below it and I'm not sure what that means.
    Thanks in advance.
  8. #458
    Jun 2002
    Virginia
    Quote Originally Posted by kbreeden View Post
    Okay, I found that one. My RR directory was named "RoadRunner" (no space between) instead of "Road Runner."
    Found that one in the help file (which is very helpful), though I'm still not sure what the red "on" button means.
    One other issue I've seen: I really like the XM screen showing the favorites icons. The problem is that even though I can get to the screen and see the icons, clicking on the icons does not change the station.
  9. #459
    Nov 2006
    Quote Originally Posted by Volsfan View Post
    Have you tried the DeLorme Serial Emulation Driver for USB?
    It is what I had to use to get things working. My gauges work, however the speedometer is off about 20mph in the gauges. IG works perfectly in the skin
    http://www.delorme.com/support/suppo...te.aspx?id=217
    I have my GPS using COM 2, GPSGATE or Xport sents to com 6. I set RR to COM 6 and IG to COM2
    iam using the delorme serial emu also and i get the 20mph difference too. i have the com2 as the gps and com5 for the gps stats in rr. the compass is also not working, should i try xport instead of delorme. i love this ***** and wish to get it working to its full potential. Blue Devil Rocks, looks awesome with the corvette logo
    1997 corvette c5
    toshiba laptop 2.4
    1 gig ram
    dvd-rw
    8" lilliput ws ts
    Delorme usb
    road runner / blue devil
  10. #460
    Dec 2005
    I am wondering about the little red on indicator on the autoconfig button as well. Currently my music does not pause when iGuidance speaks. However, I do get the ding sound. What should the setting be in rr config in regards to lowering the music volume in order to use the pause function in autoconfig?
    Thank you
  1. Open Source Skin Editor for RR
    By lbooker in forum Road Runner
    Last Post: 04-16-2007, 02:51 AM
  2. Can you tell I was bored today: Take a look.
    By Sweet05 in forum RR Skins
    Last Post: 08-17-2006, 04:25 AM
  3. new skin 'Blue'
    By CdRsKuLL in forum RR Skins
    Last Post: 09-25-2005, 06:48 PM
  4. Cool Blue skin
    By Rireal in forum ME Archive
    Last Post: 01-31-2004, 07:53 PM
  5. Nissan Blue skin final
    By SpeersSV in forum ME Archive
    Last Post: 01-06-2004, 07:00 PM
