Page 54 of 101 FirstFirst ... 4444546474849505152535455565758596061626364 ... LastLast
Results 531 to 540 of 1006
Thread: Blue Devil Skin RELEASED
  1. #531
    Variable Bitrate miwise's Avatar
    Sep 2006
    How about windvd support? any plans on that?
    Celeron 2.53 Ghz Processor
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    mp3car.com XM Direct USB interface box
    1999 Mustang GT Convertible Supercharged
  2. #532
    A Brit in Las Vegas
    Installed this skin and everything is now working including Google Earth, Traffic and IG3 - woohoo!
    However I can't get Video to work - as soon as I click Video it opens the skin and then freezes up - none of the buttons work at that point.
    It works ok under other skins such as LSX Void
    Any ideas?
    RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
    Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
    Webmaster for the European Ford Scorpio Site
  3. #533
    Sep 2006
    Do you use the default Media player classic or other dvd player. If you use something other than MPC, you have to change the menu.skin file to point to the appropriate skin that matches your program that you're using. I'm using mpc right now with no problems (other than the mouse constantly trying to relocate itself to the upper left corner every millisecond thereby negating any action I try to take with the mouse. . .thankfully touchscreen selections are instant).
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
  4. #534
    Nov 2006
    the rip cd button is just freezing my comp
    PC
    AMD 3500+ 2.2Ghz, MSI K9VGM-V Motherboard,
    Geil 512MB PC4200 DDR2-RAM, 7" Lilliput Touchscreen, 30GB HD
    Audio
    300 watt RMS 2 Channel MTX AMP, 500 watt RMS D-Class MTX AMP, 2 Front - 5 1/4" Sony Xplods,
    2 Back - 6 1/2" Sony Xplods, 12" MTX Sub
  5. #535
    A Brit in Las Vegas
    I use the default video player (this is for video files and not for DVDs) and it calls video_player.skin which opens up, displays a green -4:3 on the screen and freezes.
    Are there any log files anywhere that shows where it freezes?
  6. #536
    A Brit in Las Vegas
    I just changed it to use Windows Media Player as the External video player and it works. However I also tried running mplayerc.exe in Windows and that worked too so I'm just confused it works ok with WMP so I'll leave it alone.
    I noticed in the GAS prices skin when running IG3 that there is a button called Show Map that runs a command called gas_0_showlocation but I can't see that this command is defined anywhere and it certainly doesn't actually work.
    Is it possible for the zipcode in these apps (Gas, Traffic etc) to be obtained from the Web by using the Long and Lat from the GPS. It would be much neater for the Gas prices and the Traffic to be updated automatically as we drive.
  7. #537
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Qyestions and answers
    Quote Originally Posted by dima237 View Post
    Can I request something? Is it possible to modify the Sirius skin so have some sort of sorting by category? Because 200 channels is kind of hard to scroll. Maybe someone can recommend a skin that has this implemented so that I can modify it to look like bluedevil
    There is no real way of sorting the list other than by channel number. That is what the Channel Favorites is really for. You can put all the favorites in there, and weed out all the unwanted channels.
    Quote Originally Posted by RichP714 View Post
    The Code for L should be 076 instead of 108...then it'll work
    Thanks, that did the trick, This has been corrected for the next relesae.
    Quote Originally Posted by miwise View Post
    I am not using any external dvd player currently. My DVD's are actually .avi's that I play through the standard "Video" screen. I will look into trying to get this to work though.
    Quote Originally Posted by SteveC View Post
    I can't get Video to work - as soon as I click Video it opens the skin and then freezes up - none of the buttons work at that point. It works ok under other skins such as LSX Void Any ideas?
    It sounds like there is a video "Cached" and it has been mobed ort something. Try deleting the video.ini file inthe RR Root directory (It will be created again the next time you watch a vdieo)
    Quote Originally Posted by Legacy View Post
    This is not skin related, check the Road Runners FAQ on the top page of the forums for instructions to get it to work correctly. If after that it still is not working for you, do a search on the forums, as this has been discussed at least 100 times.
    My Fiero Build Thread
  8. #538
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    New Menu Screen
    Ok, I just did not like the menu screens that were in the previous posts, as they did just look too cluttered. I came up with this and want opinions on what you think. The compass in the clock area is a "horizontal compass" meaning it will float left and right to show your direction of travel (Much like a boat or aircraft compass works).
    If you do not want the speed and altitude on the top, those can easily be removed by taking out the lines in the menu.skin file.
  9. #539
    Jun 2002
    Virginia
    Regarding post 538: I like having all that information (speed, compass, altitude, etc.) on one screen. It does seem a little cluttered to me, but I don't see how it can be made uncluttered with all that information. I think it would be ideal if this could be made a fifth click so we could have the option of having logo, clock, speedo, compass or this comprehensive screen appear.
  10. #540
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    JohnWPB,
    Wow... That looks really nice. I can't find anything wrong with it...
    Nasa
  1. Open Source Skin Editor for RR
    By lbooker in forum Road Runner
    Last Post: 04-16-2007, 02:51 AM
  2. Can you tell I was bored today: Take a look.
    By Sweet05 in forum RR Skins
    Last Post: 08-17-2006, 04:25 AM
  3. new skin 'Blue'
    By CdRsKuLL in forum RR Skins
    Last Post: 09-25-2005, 06:48 PM
  4. Cool Blue skin
    By Rireal in forum ME Archive
    Last Post: 01-31-2004, 07:53 PM
  5. Nissan Blue skin final
    By SpeersSV in forum ME Archive
    Last Post: 01-06-2004, 07:00 PM
