Page 64 of 101 FirstFirst ... 14545556575859606162636465666768697071727374 ... LastLast
Results 631 to 640 of 1006
Thread: Blue Devil Skin RELEASED
  1. #631
    Variable Bitrate miwise's Avatar
    Sep 2006
    How about the EQ section? When I click on an slider, it doesn't light up. Is it set so it won't light up? It would be helpful if it did so I could use the arrows. Is there a way to make them light up when clicked?
    Celeron 2.53 Ghz Processor
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    mp3car.com XM Direct USB interface box
    1999 Mustang GT Convertible Supercharged
  2. #632
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Valentine One and Auto dimming of the screen.
    Quote Originally Posted by jmciver View Post
    Great skin. Definately one of the most 'complete' skins I have seen. I have a software integration request: Software One. The software is located here.
    In a nut shell, the software allows CarPC integration of the Valentine One radar detector. It is skinable and I have seen it integrated in another skin (iDrive by Enforcer).
    Also, does your skin incorporate the ability to auto dim/switch to night skin based on sunrise/sunset data from GPS position? Ideally, I would like the monitor to be tapped into the vehical to automatically dim when the lights are turned on (I found a few threads on this topic but since they involved hacking into the circuit board of the monitor I backed away), but I don't think that is feasible for me now.
    I searched your thread in particular but didn't find a difinitive answer on the auto dimming aspect.
    I just checked out the Valentine One, and it looks pretty neat, but I do not see myself buying a $400 radar detector in the near future. I also grabbed the iDrive skin to see how Enforcer has it integrated into the skin, and can find no reference to the Valentine One in his skin. As I do not have the radar detector, the only I could support it is to see how a skin has it integrated.
    As for dimming the screen, this can be done in RR automatically based on the time of day. The other hardware option would take a bit more work. The easiest way being to use one of the game pad plugins or other way to get info into the computer. With the game pad plugin, you cold hook a small relay that closes when the lights are turned on, and hook one of wires from the game pad to that relay. WHen the relay is closed it would then send a definable command from the plugin to RR. The nice part about this is the game pad wiring can be plugged into a standard USB port, and no other hardware, other than the relay would be needed.
    Quote Originally Posted by miwise View Post
    I will look into that, and see if I can come up with something. If so, I will definitely re-do the EQ screen, as this would be a nice feature for sure.
    My Fiero Build Thread
  3. #633
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    New Mixer Screen
    Ok the mixer was a lot easier than I thought it was going to be I like it when that happens. The mixer was one of the first skins that I had created, and I have learned quite a bit more then back when I put it together so I added a bit more functionality as well.
    Below the inputs, there is now a clickable area to mute, and indicate the status, muted or not. The same goes for the preamp, by clicking that area, you can turn it on and off, and see the status.
    Here is a screen cap:
  4. #634
    Jun 2002
    Virginia
    IG Autoswitch Now Working
    I don't know what I changed, but IG Autoswitch is now working perfectly on my machine.
  5. #635
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    IG Auto Switching
    Glad to hear it! Is is a really nice feature!
  6. #636
    Nov 2005
    The Valentine One integration is under one of the sub menu's in the iDrive skin. I forget whiich one it is (my CarPC is being installed by an audio shop and I don't have RR installed on my desktop right now). It is nothing too elaborate but makes launching the program easier than having to go to the Applications menu in RR. Enforcer doesn't have a V1 either, he just incorporated it into his skin since the Software One program is very easy to work with. He even made it part of his setup program for his skin.
    As far as the USB/Autodim interface, is there any more info on exactly how to build what you are talking about (I saw another thread that briefly talked about using the game pad method you spoke of), including the necessary software plugin? I am having my installer tap into the lights on the car so that I will already have a 12V signal (from the parking lights, close to the PC) available to make such a system work.
  7. #637
    Sep 2006
    Richmond, Tx: USA
    Quote Originally Posted by JohnWPB View Post
    Mine never worked . It neither pauses the music nor switches screen.
  8. #638
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Auto Dimming Road Runner screen
    I opened the iDrive skin in the RR skin editor, and just can't find a reference to it anywhere. Maybe the version on rrdownloads.net is an older version?
    I am no electrical engineer, but can certainly give you an idea of what to do. If you already have the 12v lead there when the lights are on thats a good start. You need to get a 12v relay at Radio shack or other supplier. Then follow the diagram for the relay on how to set it up. You will put your 12v and a ground on the 2 input pins. Then when power is supplied to that relay, it will close 2 contacts on the other side of the relay. Then it's just a matter of hooking 2 wires from one of the game pad's buttons and hooking them to the relay. So basically when the relay closes when it gets power, it will close the contact and "Push the button". The next is just to set up the game port plugin, so that when that button is "pressed" it will send a command to RR to dim the screen/switch the skin or whatever other RR command that you want to send.
    This same exact thing can be hooked up to the reverse lights on your car, then when they come on, RR could switch to a back up camera skin for example.
  9. #639
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Busy Day :)
    Well I have been pretty busy today, first the New EQ, and now a new configuration screen for GPS based volume.
    Guino just released a beta that supports changing these values at runtime, without having to restart Road Runner. This allows the volume of the audio to be based on the speed you are driving. My head unit has this built in, and I got spoiled using it. When driving on the highway, and then come off and stop at a light, ever notice you find yourself turning the volume down? Well this will do that for you automatically. Just put the volume you want the audio at for low speeds, and set the volume at high speeds, usually 100%. Then tell it what speed to start increasing the volume based on the noise level in the cabin of your car. In a Jeep or convertible I would recommend setting it to say.... 30 Mph It is pretty neat to see the volume level on the screens adjust itself as you drive along!
    Here's a screen capture. I hope to have all this put together and posted tomorrow in an update.
  10. #640
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Great work John! If you need something else to improve on (LOL), I'd love it if you wanted to make an improve RREarth + GooPs skin. See my post here. I'll PM you my e-mail and if you want to check out what I have for RREarth + GooPs Freedom skin I'll send you a beta. This for BlueDevil would rock!
  1. Open Source Skin Editor for RR
    By lbooker in forum Road Runner
    Last Post: 04-16-2007, 02:51 AM
  2. Can you tell I was bored today: Take a look.
    By Sweet05 in forum RR Skins
    Last Post: 08-17-2006, 04:25 AM
  3. new skin 'Blue'
    By CdRsKuLL in forum RR Skins
    Last Post: 09-25-2005, 06:48 PM
  4. Cool Blue skin
    By Rireal in forum ME Archive
    Last Post: 01-31-2004, 07:53 PM
  5. Nissan Blue skin final
    By SpeersSV in forum ME Archive
    Last Post: 01-06-2004, 07:00 PM
