Page 67 of 101 FirstFirst ... 17575859606162636465666768697071727374757677 ... LastLast
Results 661 to 670 of 1006
Thread: Blue Devil Skin RELEASED
  1. #661
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Originally posted by JohnWPB
    If there is something else more in depth you are wanting to do, drop me an email (address is in the help file) and I will see what I can do about emailing the PSD that you need.
    I did a quickie mod to the MAPPOINT_MENU_VIEW skin so I had a place to toggle MapPoint's Night Mode. If you could add one more button to that skin for that function it would be terrific, if not then maybe I could get the PSD from you for that skin so I could add it.
    Thanks, Z
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  2. #662
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    MS STREETS RR Setup, etc.
    Okay for MS Streets as an external GPS (note make sure external GPS is checked in RR.ini file)..
    Make a button call it "GPS" to call from various skins...
    OPTION 1:
    You can add the line below in the ExecTBL.ini file either in the RR folder or the skin folder depending if you want it in all skins or only one skin..
    NOTE!! after the semi-colon of Streets.exe MAKE SURE to have a space before and after the hypen of - Microsoft Streets & Trips..
    "GPS","LOAD;EXTERNAL_GPS.SKIN;STREETS;C:\Progr am Files\Microsoft Streets & Trips\Streets.exe; - Microsoft Streets & Trips"
    OPTION 2:
    add to the RR.ini file (Note see the screen capture "rr_config_streets.jpg" inside the zipped file posted earlier).
    The later option works, if speech is enable it says "external gps"... the first option says "Streets"...
    I preferred option #1
    Now I tried to find the focus of the window when I saved templates and then trying to load them again but something with the hypen and space wouldn't load competely/correctly.
    Like: "map1 - Microsoft Streets & Trips" or "map1.stt - Microsoft Streets & Trips" which in the later, wininpector show as the active window under the called template. Still No luck.
    So what I did was to setup a running instance of MS streets, changing the map type, font size, zoom level, route options " like gas mileage, etc and then saved it under "C:\Program Files\Microsoft Streets & Trips\Templates" as "New North American Map.stt". Or wherever your MS Streets is installed to. This then became my default map for Streets.
    This works on two different PCs..
    Last thing to do is to auto-start GPS probably an AutoIt script of sometype..
    Hope this helps someone in the future as I went through this throughly..
    Note: My Street skin has changes in some of the command buttons instead of ALT+ in the sendkeys I used CONTROL+ as this embedded and had less flashing (popups) inside the skin. Not all buttons have a CONTROL+ function key available or Microsoft didn't show them in the help files..
  3. #663
    Jun 2002
    Virginia
    Quote Originally Posted by SangreDeThor View Post
    what the toggle names does is, rotates the format of file name to
    1). Track
    2). Track-Asrtist
    3). File name
    It may not be in that order. or exactly that but that is what it does in my experience. does not work with *.m4a
    Thanks, Sangre. I now see what's going on. For me, pressing the toggle button does nothing to the current playlist; however, when I load a new playlist the names in the new playlist are toggled. I thought it would impact the existing playlist, but that doesn't seem to be the case.
    Also Sangre/John, since we're (I'm) on the subject of wish lists it would really be neat if there were some way to randomize the current playlist. I would love to be able to load my 20,000 song list, hit a button to sort it into random order, then turn off random play. That way, the list would be playing in random order, but I could see what songs are coming up next. B8bboi's CFX skin had that functionality and I really became addicted to it. Perhaps an extra click or a hold down of the toggle button could send a command to randomly sort the list.
  4. #664
    Jun 2002
    Virginia
    Quote Originally Posted by ajamils View Post
    Mine never worked . It neither pauses the music nor switches screen.
    I had the same problem as you. I did a clean install of RR and BD, downloaded the current version of VBRuntime and messed around with the volume settings of Iguidance and RR and all of a sudden it's working perfectly. I wish I could tell you what did it, but I don't know.
  5. #665
    Sep 2006
    Sabattus, ME
    some suggestions for people having issues with the switch.
    make sure RR doesnt do all volume.. just master volume. and as a test set main to 100 and wave to 50. and see how that works.
    CarPuter: 900Mhz P3 with 256 MB Mem, 160 Gig HD (Thanks kbreeden), Iguidance 3.0 GPS, Logitech PS2 keyboard, Bluetooth, WIFI.
    Powered By Road Runner & DigitalFX Skin and Playlist Conveter
  6. #666
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    New Visulization
    Ok, I have been working on adding a nicer visualization to the skin. I found a nice spectrum analyzer, and want to know what you guys think. It is semi transparent, and you can see the album art underneath it.
    It's a few steps to configure, but would be covered in detail in the help file. SangreDeThor was nice enough to beta test it for me, and he got it working. I also want to thank Liquid Smoke for helping me out with this! We were IM'ing back and forth for a few hours working on issues with his skin and mine. Without his help this would not have come to be.
    Let me know if this is something that I should include in the skin or not.
    Here is a screen cap:
    My Fiero Build Thread
  7. #667
    A Brit in Las Vegas
    YES YES and just in case YES
    RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
    Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
    Webmaster for the European Ford Scorpio Site
  8. #668
    Oct 2005
    Arkansas
    @John
    John, I didn't offend or upset you by posting some Streets files?
    I was merely adding some input and thought you might want them for future..
  9. #669
    Jun 2002
    Virginia
    John,
    I think it would be great as an option. I can see that there will be some times I'll want the viz with the album art and sometimes just the album art.
  10. #670
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    PLEASE.
  1. Open Source Skin Editor for RR
    By lbooker in forum Road Runner
    Last Post: 04-16-2007, 02:51 AM
  2. Can you tell I was bored today: Take a look.
    By Sweet05 in forum RR Skins
    Last Post: 08-17-2006, 04:25 AM
  3. new skin 'Blue'
    By CdRsKuLL in forum RR Skins
    Last Post: 09-25-2005, 06:48 PM
  4. Cool Blue skin
    By Rireal in forum ME Archive
    Last Post: 01-31-2004, 07:53 PM
  5. Nissan Blue skin final
    By SpeersSV in forum ME Archive
    Last Post: 01-06-2004, 07:00 PM
