Page 19 of 88 FirstFirst ... 9101112131415161718192021222324252627282969 ... LastLast
Results 181 to 190 of 877
Thread: CrystalBlue Skin
  1. #181
    Nov 2006
    KIA logo
    Quote Originally Posted by Dalailama View Post
    Thanks mizio, Opel logo added to the TO-DO list!
    Dalailama,
    appreciated 1. KIA logo 2. Naza logo be add in to the list. Thanks!
    Beautiful skin!!! Keep it up.
  2. #182
    Maximum Bitrate Dalailama's Avatar
    Jan 2006
    Novara Italy
    Quote Originally Posted by nemo1 View Post
    I need your help in making the image and I will try my best or as much as I could for coding. As you said the skin you made for garonav is different from RR skin.
    [...] are of 2 seperate files. If I were to make the skin in RR, these two files should be in one right....correct me if I am wrong.
    you're right...
    No don be sorry. You have help me a lot....Really appreciate your help.....Thank You Very much..... better get some sleep ==> .....Wish I could help you on developing this skin(share some )
    Ok, let's do it in this way, you know the software, so draw down (even in a handmade way) the draft of wath you want to be the skin, then I'll make it with photoshop, finally (if you like it) you can use to write the code...
    What do you think?
    When I put your skin in another computer I get this:
    Anyway to fix it?
    Quote Originally Posted by bmsgaffer86 View Post
    I get the same problem except my needles dont work either. I have installed the latest flash but to no avail.
    ...I made a for you and have found this post 4 in which there's descibed the same problem solved, it suggest to uninstal the wrong flash player installation with this exe and then install this version. Let me know
    Another thing how can I make the needle rotate in RR? I know how to make it display like time or date but don't know how to make it rotate.
    Again Thanks
    I think this could help you...
    Quote Originally Posted by alpha8 View Post
    Dalailama,
    OK, consider it done!
    Live today like it is your last day, and behave as though you will live forever...
    my WEBSITE
    MapMonkey Dalai skin-preview-download ITA-email me for ENG
    Road Runner CrystalBlue skin-preview-beta release
  3. #183
    Variable Bitrate nemo1's Avatar
    Jun 2006
    What do you think?
    You're the best bro.. .... I am thinking to embed like this:
    and put like what you made for the skin shown below ontop as the skin (background as above). Maybe replace ETA and ETR with other features in RR because I think I am limited to these commands only:
    "GPSLAT"
    "GPSLON"
    "GPSSPD"
    "GPSHDG"
    "GPSALT"
    "GPSSAT"
    After following the link that you gave, I made a clock (see attached file)
    I am thinking of using these features ("GPSSPD" and "GPSHDG") in RR for the two round indicators. What code do I put in the action window of the action layers in flash? or should I use the flash movie feature in RR? For example if I use GPSSPD, I am only able to make it display like time or date but not rotating. Is it Flash have to get the values from RR or from GPS mouse(RR is getting info from GPS mouse for functions like stated above)? Can it be done? (maybe I'm wrong )
  4. #184
    Jun 2006
    This is considered coding right...I'll
    Edit: Found the answer and tested. It works
  5. #185
    Jun 2006
    It worked
  6. #186
    Nov 2006
    if you want i've a map monkey skin with crystalblue style... it's not good (i haven't image source) but work.....
    and some mapmonkey skin
  7. #187
    Jan 2006
    Novara Italy
    It worked
    Quote Originally Posted by febelus View Post
    "When did I made this?" is the first thing I said when I saw these pictures!!!
    The best "copy and paste" work I've ever seen!!! !!!
    (I'm workin' on the MM skin... and it's not so far from what you've done!!)
    my WEBSITE
  8. #188
    Nov 2006
    if you want i can help you on mm skin!!no problem!!!
  9. #189
    Jun 2006
    can sent me a copy...nice work febelus or Dalailama (joking) pls don't flame me.....
  10. #190
    Jan 2006
    Novara Italy
    Web skin
    Web skin ended...
    soon available for download
    my WEBSITE
  1. Beta Release Black Vinyl on Aluminium
    By kpjuk in forum RR Skins
    Last Post: 07-31-2006, 10:34 AM
  2. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 08:48 PM
  3. nLite 0.99.9 beta just been released!
    By Gobby in forum WinNT Based
    Last Post: 04-14-2005, 03:45 PM
  4. Skin Error with new beta
    By sim in forum Media Engine
    Last Post: 04-05-2005, 10:19 AM
  5. designed my own skin (beta version) whacha think?
    By multiplexor in forum Software & Software Development
    Last Post: 04-21-2004, 11:10 PM
