Page 32 of 88 FirstFirst ... 22232425262728293031323334353637383940414282 ... LastLast
Results 311 to 320 of 877
Thread: CrystalBlue Skin
  1. #311
    Oct 2006
    you say web browser put its phoco skin LOL. still its a good update.
    95 Mustang 5.0
    Custom Case, VIA m10000, 512 MB, 80gig, M2-ATX, Slot Load DVD, 7" LCD Touchscreen
    80% done
  2. #312
    Maximum Bitrate Dalailama's Avatar
    Jan 2006
    Novara Italy
    Quote Originally Posted by Dan95five0 View Post
    now the link is correct
    Live today like it is your last day, and behave as though you will live forever...
    my WEBSITE
    MapMonkey Dalai skin-preview-download ITA-email me for ENG
    Road Runner CrystalBlue skin-preview-beta release
  3. #313
    Oct 2006
    thanks for both lol.
    how much more do you feel like doing for this skin? what percentage do you think your at?
    keep up the good work
    95 Mustang 5.0
    80% done
  4. #314
    Jan 2006
    Novara Italy
    I think the total percentage is about 90%... but you can monitor the complete work on the first post... with all the plans
    ...I'm lookin' for a cinergy 600 so I can do the rest of the skin, which I can't do now..
    Then I'll release a first version... and then I'll start to add some flash features I'm working on
    my WEBSITE
  5. #315
    Jan 2006
    Novara Italy
    TV skin, is there someone who can test it?
    Here is a picture of the TV skin for CrystalBlue.
    I'm waiting for the Cinergy 600, util it arrives is there someone who can test it for me?
    my WEBSITE
  6. #316
    MAH
    MAH is offline
    Newbie MAH's Avatar
    Feb 2007
    Quote Originally Posted by Dalailama View Post
    BUG & FIX
    Flash Clock problems...
    The clock appears like
    and sometimes needles don't work.
    It's a flash plugin problem, probably installation missing or wrong version installed:
    uninstal the wrong flash player (if installed) with this exe and then install this version
    I used your recommended uninstall. I tried all 8.XX versions of the flash plug in. Same result. Clock does not work and is in a white box. I tried another clock from another skin. That clock actually shows the time, but it is also in a white box. Your clock shows the time in Firefox but not in Roadrunner.
    I'll accept that the white box is a flash quirk. However other flash authors are getting their clocks to work consistently.
    This is a favorite skin. Thank-you for the work you have put into this. I hope you get get rid of the bugs (and this white box).
  7. #317
    Dec 2006
    Thumbs up MM Skin
    This skin rocks,
    Finally got my MAC Mini and 7" Screen and are starting to set everything up.
    I have the same font issue as metioned, it appers to clip all the fonts, main ones are volume, time and play time at the toi when for eaxmple 2.32 where 2.31 looks fine.
    When can I get a copy of the MM Skin. Tested the Garo and it is ok but would really like to test MM as what I have found is the address area gets squshed by the keyboard making it har to use. Plus if the fonts are two small for City Street Number. they are really hard to click.
    Also the clock does not work. I will look through the forum to see if the is a fix.
    I would not worry about a day skin, the current look it brilliant.
    BTW, I found a neat Aluminium DIN2 frame that is designed to put a Lilliput 7" Monitor straight in to a 2din Stereo Space, not cutting, no fabrication.
    Can not wait till this is released.
    Cheers and your guys rock.
    Firebird
  8. #318
    Dec 2006
    Quote Originally Posted by nemo1 View Post
    Compare the text for time shown in the image below. The ones circled in red seems to be clipped off.
    I have the same issue. What is the fix.
    Cheers Firebird
  9. #319
    Dec 2006
    Hi Firebird2,
    the hibernate feature is added from the first time I uploaded the skin...
    ...just check the second post on the first page I started for all the reported bugs...
    For the blue screen... which instructions are you refearing to?
    What appears in RR?
    Anyhow try to go back and try again (without any modification) if the same error occurs... because it seems to me the error doesn't appear as a skin error... ...it seems as some program is working wrong with the paging...
    BTW the blue screen appears in theme with CrystalBlue so you don't have to worry about it!! (I'm joking)
    Let me know additional info and which instructions are you refearing to and we will try to solve the problem
    Hey guys, the issue was the build of XP. Patched to SP2 and resolved the issue.
    Cheers Firebird
  10. #320
    Variable Bitrate nemo1's Avatar
    Jun 2006
    Quote Originally Posted by Firebird2 View Post
    Cheers Firebird
    You have to use the RR skin editor(easier). For each text there is a box, kind of like those you use in MS word (insert text). All you need to do is increase the size of the text box. BTW where did you find the aluminium frame for liliput screens?
    Cheers
  1. Beta Release Black Vinyl on Aluminium
    By kpjuk in forum RR Skins
    Last Post: 07-31-2006, 10:34 AM
  2. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 08:48 PM
  3. nLite 0.99.9 beta just been released!
    By Gobby in forum WinNT Based
    Last Post: 04-14-2005, 03:45 PM
  4. Skin Error with new beta
    By sim in forum Media Engine
    Last Post: 04-05-2005, 10:19 AM
  5. designed my own skin (beta version) whacha think?
    By multiplexor in forum Software & Software Development
    Last Post: 04-21-2004, 11:10 PM
