Page 40 of 88 FirstFirst ... 303132333435363738394041424344454647484950 ... LastLast
Results 391 to 400 of 877
Thread: CrystalBlue Skin
  1. #391
    Maximum Bitrate Dalailama's Avatar
    Jan 2006
    Novara Italy
    Answers
    First of all there were some files missing in the previous zip...
    Quote Originally Posted by treetop777 View Post
    Tried the preview > went back to the original.
    Computer froze on the first launch, had to reboot.
    Pressing and holding buttons DO NOT bring up a menu.
    This new backround look to busy - (i know it can be changed).
    Computer seems to be running slow now
    The missing files don'd cause PC freezing anyway so it is due to the new RoadRunner.exe or to RR.ini configuration...
    The background is changeable, I used that picture for develop it and not for useing...
    ...and if it seems to you that PC runs slow it's a problem because with the new version pictures are lighter and pc should run faster...
    Allow me to show something
    http://www.mp3car.com/vbulletin/rr-s...new-style.html
    Remmember? Sometimes we work to hard and end-up overdoing it!
    I don't understand what you mean... I remember the post and it seems to me I'm doing what I promised...
    Quote Originally Posted by Fooch View Post
    The holding button does not work because of the ExecTBL...there are paths in there that have "Programmi" instead of "Program Files". I changed these and with a nice background. I love the front screen. I just wish the buttons at the top switch to next and previous track instead of info types. But I will deal. LOVE the skin, keep it up.
    Quote Originally Posted by nemo1 View Post
    I have installed and here are the results:
    5. Tried to configure the menu but it did not work. Maybe the folder path to program files is not the same....just guessing. Tried to change all Programmi to Program Files but still the same.
    Oh and I found looking through the files that it is trying to execute a file SELECT_FUNCTION.SKIN....this file was not in the .zip I downloaded....that is why it isn't working. That is missing.
    The holding didn't work for the files missing.
    The Programmi or Program files depends on the OS language... I'll fix it in future to let it be language indipendent
    I'm thinking on add previous and next track button in the menu also...
    I have notice another thing, maybe its just me or maybe I am wrong. To register the GDIPlusWrapper.dll file, I first go into dos mode and change from c:\ to C:\Program Files\Road Runner and then type REGSVR32.EXE GDIPlusWrapper.dll and a successful message appears. Previous attemps have failed, don't know if that is the way to register the file.
    As for the registering the dll I just did START...RUN... and typed REGSVR32.exe "C:\program files\road runner\GDIPlusWrapper.dll" and it worked...wouldn't work without the quotes around the location.
    No problem. I am trying to find a good picture to fit in that background nicely. The circle in the midle blocks so much that you need something that shows good images outside the middle picture.
    Ya...the middle circle is not transparent thus blocking the image...maybe a pattern image will work well.
    I'll change the big circle with something more little and transparent, is it OK?
    The skin preview you posted yesterday had a RR.exe and replace the existing one, guino had released a new version of RR. Which RR.exe file do I use?
    The RoadRunner.exe in the zip is the last uploaded by Guino at the moment...
    Dalailama,
    I have mod the DVD skin to work with WinDVD 7(love the video desktop function) and everything is working except for the time slider and also the remaining time and chapter display. Any idea how to make those 2 work?
    Give me more time before analyse that matter...
    I am using the clock you made....I am not sure when it was release but it has two files(clock and prova). Please refer to image below, a portion of the number 12 is cuted off.
    Don't mind I have to change the graphics of the clock to match the new style...
    Live today like it is your last day, and behave as though you will live forever...
    my WEBSITE
    MapMonkey Dalai skin-preview-download ITA-email me for ENG
    Road Runner CrystalBlue skin-preview-beta release
  2. #392
    Variable Bitrate nemo1's Avatar
    Jun 2006
    Quote Originally Posted by Dalailama View Post
    Tested it out and it works now......great job!!
    Possessing Outstanding Quality
    Understand...Thanks
    Sure....I can see that you are busy developing the skin...love it.
    ok....cheers
    This skin is getting better and better....Thank You Dalailama and Guino
  3. #393
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    First let me say that it's amazing what you do, i myself can't begin to understand the coding behind making your skin look and work so good
    I'm pretty sure many of us would have been jumping for joy if those diffrent colors (as in that post i quoted) had been released; instead, you are working hard to implement transperancies and different backrounds that i suspect is much more difficult to code.
    For such a great skin like this one, maybe the KISS principal is the way to go.
    IMHO.
  4. #394
    Jan 2006
    Novara Italy
    I'm pretty sure many of us would have been jumping for joy if those diffrent colors (as in that post i quoted) had been released.
    Make different colors is a simple set of action I have to do, but I need a solid set of pictures to start from, If I make different colors set and then want to add transparency I have to redo it again...
    ...I know that I'm delaying the release too much, but I want it to be the more configurable I can to let you match your interior car the best and I think that having a skin in different colors but without a changeable background or a configurable menu is not what you really want ,
    I would like to let you choose the theme color as you choose the background , but it's not possible at the moment with a non flash based skin.
    my WEBSITE
  5. #395
    Jan 2005
    First let me thank you for a great skin.
    However, I find the Image Viewer 3 a little difficult to use especially with image path pointing to DVD drive. It just doesn't work. How hard would it be to modify picture.skin to use picture viewer built into RR itself? You must have considered this option when choosing picture viewer, can you share your reasons not to do it? And by that I don't want to disrespect your decision at all.
  6. #396
    Jan 2006
    Novara Italy
    Quote Originally Posted by BadWave View Post
    When I choose ImageViewer, picture viewer was not developped at the actual state, it was just at the beginning...
    ...I think it's not so difficult to adapt .skin to work with it, and I think I'll do it in future...but I have first to finish the first version of the skin..
    my WEBSITE
  7. #397
    Jan 2006
    Novara Italy
    Too much transparent or is it right enought?
    I tryed a little circle, but I didn't like it really... so increased the transparency... do you think is transparent enught now?
    Comments are welcome
    my WEBSITE
  8. #398
    Jun 2006
    Ya they are great.
  9. #399
    Jan 2007
    looks awesome, i like the option of changing the colors of the skin. that would be great.
    i have a couple questions though. when i go into tools and try and launch the browser, phone, picture, or camera, i cant get anything to load. i set the path to firefox in config, but it still isnt loading. i couldn't find anywhere to set a path for pictures either. its not too important, i'm just testing rr out before i put the carputer together.
  10. #400
    Jun 2006
    The yellow and red box area doesn't looks transparent....not the same as the clock area.
    Quote Originally Posted by elimenohpee View Post
    when i go into tools and try and launch the browser, phone, picture, or camera, i cant get anything to load. i couldn't find anywhere to set a path for pictures either.
    Do you have image_viewer 3 embedded. You change the image path there. For phone currently crystalblue only have phoco skin available, you'll need to have it in the crystalblue skin folder.
    I am interested to know the ans as well.
  1. Beta Release Black Vinyl on Aluminium
    By kpjuk in forum RR Skins
    Last Post: 07-31-2006, 10:34 AM
  2. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 08:48 PM
  3. nLite 0.99.9 beta just been released!
    By Gobby in forum WinNT Based
    Last Post: 04-14-2005, 03:45 PM
  4. Skin Error with new beta
    By sim in forum Media Engine
    Last Post: 04-05-2005, 10:19 AM
  5. designed my own skin (beta version) whacha think?
    By multiplexor in forum Software & Software Development
    Last Post: 04-21-2004, 11:10 PM
