This is the patch for the radio player update supporting the new RDS advanced features of the 9-9-07 mod by Robby-BMW for Cinergy... newer RR version will support the mod![]()
Hi Dalailama!
First off all I would like to thank you for making this skin.It is awesome.
Second: I have the same problem as Bassion. The skin worked fine. Then I tryed to do an update or something like that and now It does not work. So I would also like a "final" version to download. Or just and "up to date" version.
Live today like it is your last day, and behave as though you will live forever...
my WEBSITE
MapMonkey Dalai skin-preview-download ITA-email me for ENG
Road Runner CrystalBlue skin-preview-beta release
another update with the PTY and Stereo features added... (sobstitutes the previous one :P)
my WEBSITE
whats the best nav to use with this skin? Im kinda new at all of this. I have 2 GPS Nav softwares I can use, but I am unsure of how to mske it work within a skin. I tried searching but no luck. Thanks in advance for your help![]()
my bet would be garonav/destinator according to the first post.. 100% complete.
2005 Nissan Xtrail
DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
worklog
I am having trouble getting the windows media player 11 skin to apply. When I click apply skin, it doesn't do anything, but the other skins will apply. Any ideas? I tried reinstalling wmp and also downloaded the files again but it didn't help.
I agree with him
[QUOTE=jorgenjl;1126848]I am having trouble getting the windows media player 11 skin to apply. When I click apply skin, it doesn't do anything, but the other skins will apply. Any ideas? I tried reinstalling wmp and also downloaded the files again but it didn't help.
I don't know,
try to delete the others skin (make a beckup before) and let us know how it behaves...
my WEBSITE
hi dalilama
i have a little problem with radio i have copied the file in the directory of the skin but when i push radio in the main menu appears a strange images and non the radio skin
Mi spiego in italiano compare che forse č megliosono della sicilia,
allora ho copiato tutti i file, tranne il menu.skn se no non mi parte piu il rr, appena clicco su radio non mi appare la skin giusta ma una striscia viola e nera e nn si legge niente che cosa puo essere?
e poi ho installato garonav gli ho messo la skin ma quando clicco su gps me lo apre di dietro come lo devo impostare rr? su external? dimmi tu attendo tua risposta
grazie
Pink and black stripe means that probably you forgot to register gdipluswrapper.dll...
you have to overwrite the previous menu.skin... if you don't want to fix the new let me know what is the menu.skin file you use and I'll say you (if I'm able) what is wrong...
...now let's fix this bug than we'll see the navi configuration
Amoninni cumpā!
la striscia rosa e nera denota che molto probabilmente tu non hai registrato la gdipluswrapper.dll....
per un corretto funzionamento della skin devi sostituire anche menu.skin... se ti da problemi (ed hai seguito pedissequamente le istruzioni per installarla) vedimo di farla funzionare insieme... se invece volessi mantenere il vecchio menu.skin postamelo e ti dico se ci riesco cosa nonn va....
...dopo che rr č funzionante vediamo per il navigatore...
my WEBSITE
the menu.skin is this:
if i put the menu.skin that are in pathc radio rr don't runCode:MEDIACAR Skin MEDIACAR MainMenu Skin menu_off.jpg,menu_off.jpg,menu_on.jpg,menu_down.jpg F01,295,127,212,265,"clock.swf" /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B01,0,55,336,138,"AUDIO","Audio player" B02,468,56,331,137,"GPS","" B03,1,196,309,132,"VIDEO","Video player" B04,503,197,296,130,"RADIO","" B05,2,331,359,128,"PAUSE||LOAD;DVD.skin;DVD Player;C:\Programmi\Windows Media PLayer\wmplayer.exe";Windows Media Player" B06,443,330,356,126,"TV","TV" B07,1,467,310,133,"LOAD;TOOLS.SKIN", B08,364,433,75,54,"MUTE","Mute" B09,337,488,127,37,"LOAD;VOLUME.SKIN", B10,317,531,83,70,"VOL-","Volume-" B11,403,530,80,70,"VOL+","Volume+" B12,490,467,311,133,"EXIT","Exit" /, I, x, y, w, h, Code;INDICATORCODES I01,338,490,124,31,"MUTE:b" /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT L01,116,10,570,32,100,213,245,24,"Alien Encounters Solid","TRACKNAME","SCROLL-CENTER" L02,370,488,73,32,100,213,245,30,"Alien Encounters Solid","VOLUME","CENTER" L03,2,2,105,24,100,213,245,18,"Alien Encounters Solid","TIME","Time" L04,0,26,105,23,100,213,245,15,"Parallelo","DATE","" L05,339,57,127,39,100,213,245,30,"Alien Encounters Solid","CURRENTTRACKTIME","CENTER" END
in inglese sono una ciofeca cmq dicevo
il menu.skin č quello, mettendo quello che ci sta dentro a alla pacth della skin per la radio rr non parte dandomi errore numero 13
la dll l'ho scaricata da uno zip che c'erano altre cose, pero ho preso solo la dll l'ho messa nella cartella dove sta installato rr
e da esegui ho dato
Regsvr32 "C:\Programmi\Road Runner\GDIPlusWrapper.dll"
mi dice correttamente registrata ma nn va lo stesso
cosa puo essere?
EDIT
forse ho capito il mio problema ho una versione di rr vecchia, ho scaricato l'installer dal sito e anche l'updater ma l'installer non mi mette l'exe di rr quindi l'updater nn va mi potresti passare solo l'exe di roadrunner? sifer@LEVAMIPERLOSPAMemail.it
