ok.. when i press gps, it loads external skin and launches ig4. Ig4 runs as i see on the task bar but I don't see ig4 in the skin. I think someone had a same problem before. I checked rr setting... ig native= true... external option set... path to ig is correct. it embeds fine with other skins, so i know setting is cool...
I did some testing.. i copied other ext. screen file from other skin and modified exe_tbl.ini...
/,"MENUBUTTON3","BYVAR;MENUFUNCTION3;$ALLMENUFUNCTI ON$"
"gps","LOAD;GPS_half.skin;$gpsname$;$gpspath$;$gps name$"
This does the embedding fine with that skin....
Any idea? thanks.
LinkBack URL
About LinkBacks
incorporating RRearth is another cool stuff.. I just found out about that ^^
