Page 11 of 13 FirstFirst ... 2345678910111213 LastLast
Results 101 to 110 of 122
Thread: iDrive Night Red 2.17 Released
  1. #101
    Low Bitrate rjankowski's Avatar
    Oct 2006
    TN/KY Home is Houston
    nope, was loaded with sugar...
    this job sucks sometimes. I cant wait to go home!
    I think I can pull it off today, im going to fart around with something, hopefully the drive itself wasnt damaged cause I have another computer I can stick it in.
    Ok, I think I got everything worked out... Hopefully. Feel free to remove my cheater buttons D and N... still havnt figured a good place for those yet. Ill email you what I have. I think that you should just be able to drop these in the folder (with the exception of changing the top.skin to have the correct color in it) I would test that theory, but I CANNOT find my zipped skin files that I downloaded...
    The 3 skin files replace the ones that are in the folders already. The Gas.exe goes into the roadrunner folder.
    edit: Email sent... and i just noticed something. This form automerges posts if you make two consecutive posts in the same topic... Im thinking this will be bad in the future, but for now... oh well
    It works!!
    Almost all of the time too!
  2. #102
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Looks interesting.
    I will add it to the next release. Green in the next one up and then I will do some updates for the other two. Just trying to get my little night/day switcher exe to work and tidy up a few plugins.
  3. #103
    Oct 2006
    hey, i was beating my head against a wall for this one, but I think I figured it out... For some reason when I use the idriveconfig and change media player to none, it changes the top 2 lines of the top.skin file from:
    Code:
    /DEFINE Selected 255,162,0
    /DEFINE Fore 255,255,255
    to:
    Code:
    I was wondering why all of my labels were dissapearing when I changed it in the config, this appears to be the reason behind it.
    Just a heads up.
    (this was using the program you sent me with the streets option built in)
    It works!!
  4. #104
  5. #105
  6. #106
    Oct 2006
    Just a random update, the Streets and Trips module I contributed works for both 2006 and 2007. Just thought I would add that.
    It works!!
  7. #107
  8. #108
    Low Bitrate Zebel's Avatar
    Apr 2006
    Thanks EnForcer for the great job. I have been using the iDrive skin for over a year with MapMonkey as my Nav. I like to switch to iGuidance. I know how to set up the path to iGuidance but Is there a skin for it? How about full view mode? thanks in advance.
  9. #109
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Which version of iGuidance?
    Set up iGuidance in RRConfig, and then got to iDrive config and choose iGuidance from the drop down menu. If it is 2.1.x then the buttons in the skin should work. If however it is 3 then unfortunately they won't.
  10. #110
  1. iDrive 2.20 Release
    By Enforcer in forum RR Released Skins
    Last Post: 08-03-2009, 05:03 PM
  2. 7-31-06: RKC Big Monday Night GTG: FRISCO
    By Bakushan in forum MP3Car Gatherings
    Last Post: 07-31-2006, 03:23 PM
  3. BMW E30 install with night vision
    By tekta in forum Show off your project
    Last Post: 07-01-2006, 03:41 PM
  4. Night / Day Skin Code:
    By IntellaWorks in forum Coders Corner
    Last Post: 01-06-2006, 03:58 PM
  5. Streets and Trips 2006 released!!!
    By Mattkins99 in forum Road Runner
    Last Post: 10-20-2005, 05:30 PM
