Page 4 of 13 FirstFirst 12345678910111213 LastLast
Results 31 to 40 of 122
Thread: iDrive Night Red 2.17 Released
  1. #31
    Variable Bitrate Bimmerstyle's Avatar
    Sep 2006
    Belgium
    Yes, it's pretty simple. I use paint shop pro, so I don't know the photoshop terms. Sorry.
    I just took the magic wand. Set it to colour, tolerance about 50, selected them, set the saturation to 0 and lightness to -15. It takes about 15 minutes for all the screens.
    BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
    Bezel Worklog-My Install -iDrive F01 RR Skin
  2. #32
    May 2005
    Germany
    Could you make a .zip-file?
    So everybody who wants it could download it.
    Ti-ejtsch
  3. #33
    FLAC sama's Avatar
    Feb 2006
    London, UK
    looking good E. when I rebuild the system soon, I think I'll start using your skin... you might even get a tan since I'll be s'boarding over xmas.
    I have to agree with some of the suggestions about purple. perhaps yellow or amber?
    here's a few quick photoshop'ed examples.
    I think yellow is the furthest away from red (amber is yellow with red) so yellow would be my choice. These colours are also used in the BMW dash for things like engine light etc. The other option is pale blue, like the high beam light. That's a very sharp contrast and would achive a similar effect to the purple.
    anyhows, food for thought.
  4. #34
    Sep 2006
    Belgium
    I have to check with enforcer and find someone to host it for me because my webspace is a bit limited at the moment..
  5. #35
    Sep 2006
    Belgium
    This said there is only one little bug I wanna show you. When in the Audio Player on the album art there sometimes is a black spot. When you open a folder and start to play it it isn't there but when you exit RR and reopen it it's there. See pic: (btw, this is the new colour I've made)
    Found it. The repeat and shuffle indicators covered a part of the albumart. Changed the wide of them from 100 to 70. Problem solved!
    Also changed the Visuals button in the audio player to Equalizer. I don't use visuals and going directly form the audio player to the equalizer seems handy.
    One question, How do I get the Picviewer to work? I guess there has to be a path set somewhere, can't find where..
  6. #36
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Bimmerstyle View Post
    Found them! However I don't have a "fulltop.skn" file? I've changed the other 3 and it seems to work. Just put it in the car and now it matches the dash lights perfectly. Here are the values, maybe they are usefull:
    -On the screens I've changed the Hue to +6
    -The colour of the labels I've changed to 223,67,23
    I also have redone the sidebars again since I didn't really liked them red. Now I just made them grey. This way the skin doesn't look all red and the grey matches the red nice. (sorry for the purple ones but I really didn't like them )
    Will give this a look see, Getting the right orange/red balance was mainly what held this skin up, I thought I had the right balance to match the OBC and climate control on my E36. Maybe the more orange will suit other E numbers. Will try your colours in mine though.
    Oh, it was gpstop.skin not fulltop.skin, I was doing it from memory. my bad
    Other changes I've made so far:
    -Changed the behavior of the BMW logo from "Minimize" to "Dayskin" (and "Nightskin" for the day version)
    -Added "Minimize" button in the exit menu
    -Changed the layout of the Radio screens display so it works a little better with the HQCT
    Did you even read the readme.txt?
    Quote Originally Posted by readme.txt
    Pressing the time in most screens will swap between Day and Night skins in rr.ini
    I'd be interested in seeing the changes you have made to the radio skin for HQCT as I can't test the radio so it's maninly guesswork.
    Something I'm gonna change is replacing a button I don't use a lot (don't know wich one yet) in the iGuidance GPS screen by "Day/Night". Since day and Night are two different commands for iG I'm planning to devide one button in two halfs. So when you press left it's Day and right it's Night. This way I don't need two different buttons for it.
    I did start to look at adding more to the iGuidance commands, and one of them was the day/night change, but When I tried using the sendkeys to do it, it would get to the menu where it was on, but then would ignore anymore commands. Might have to try and stick a wait in the command line.
    I just wanna say that it's not I don't like the skin because I always start changing it the moment I have it. I like it a lot! Thank you for it.
    I just change some little things to make it a little more to my taste. And I also learned my lessons now. So there isn't gonna be a "Play Screen" with spectrum analyzer anymore since I didn't use it. Also the BMW logo stays in place this time because I hardly ever used the functions of the iDrive button I've made before. Also everything I change this time I do it in notepad so I don't mess up the functionality of the config program.
    Het I started this by cutomising BTBE's orginal to my taste, so I have no problem people changing versions to suit themselves. In fact I welcome any suggestions to improve it, some I may impliment, some I may not
  7. #37
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Noted. actually changed it to 60, as that's all the Indicators need.
    in rr.ini
    picspath=<path to pics>
  8. #38
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by sama View Post
    How the fook do I get a tan if you are going snowboarding?
    I knew the purple would be controversial, but hey it had to be tried. Bear in mind the colours used are supposed to work in the car (with the monitor I have). So although it might look bad on the desktop it may look different in the car.
    Also I am doing this to match the OBD and Climate control displays as these are what it is near and in-line with. Not the Instrument cluster colours.
  9. #39
    FLAC sama's Avatar
    Feb 2006
    London, UK
    Quote Originally Posted by Enforcer View Post
    'cos I'll be using your skin
  10. #40
  1. iDrive 2.20 Release
    By Enforcer in forum RR Released Skins
    Last Post: 08-03-2009, 05:03 PM
  2. 7-31-06: RKC Big Monday Night GTG: FRISCO
    By Bakushan in forum MP3Car Gatherings
    Last Post: 07-31-2006, 03:23 PM
  3. BMW E30 install with night vision
    By tekta in forum Show off your project
    Last Post: 07-01-2006, 03:41 PM
  4. Night / Day Skin Code:
    By IntellaWorks in forum Coders Corner
    Last Post: 01-06-2006, 03:58 PM
  5. Streets and Trips 2006 released!!!
    By Mattkins99 in forum Road Runner
    Last Post: 10-20-2005, 05:30 PM
