Page 5 of 13 FirstFirst 12345678910111213 LastLast
Results 41 to 50 of 122
Thread: iDrive Night Red 2.17 Released
  1. #41
    Variable Bitrate Bimmerstyle's Avatar
    Sep 2006
    Belgium
    Did you even read the readme.txt?
    Yes but since I did it in the previous version I got used to it that way so I changed it again.
    I'd be interested in seeing the changes you have made to the radio skin for HQCT as I can't test the radio so it's maninly guesswork.
    Here is the part from the skn file I've changed. I just slashed away your lines so they're still there. I've made the RDS text smaller since with the HQCT this is flikkering all the time. When it's to big it start to be annoying after some time. Also the the frequency I made a little smaller and the biggest part is the name of the preset. I like it this way best.
    /DISABLED!! Original layout by En4cer
    /, I, x, y, w, h, Code;INDICATORCODES
    /I,530,060,80,050,"STEREO"
    /I,540,100,70,050,"LOCAL"
    /I,550,140,60,050,"SCAN"
    /I04,148,440,25,31,"MUTE:b"
    /I05,470,290,130,25,"TOPPL"
    /I06,470,570,130,30,"BOTTOMPL"
    /REPLACED!! Edited layout by Bimmerstyle
    I,530,60,80,23,"STEREO"
    I,540,100,70,25,"LOCAL"
    I,550,140,60,24,"SCAN"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    /L,270,90,160,60,#Fore#,36,"LCD Display Grid","FREQUENCE","RIGHT"
    /L,430,103,70,60,#Fore#,24,"LCD Display Grid","=MHz"
    /L,230,140,150,025,#Fore#,15,"Tahoma:B","RADIONUMBE R","Radio number"
    /L,360,50,300,25,#Selected#,15,"Tahoma:B","RDSTEXT" ,""
    /L,230,50,100,25,0,#Selected#,"Tahoma:B","RDSNAME", ""
    /L,380,140,150,025,#Fore#,15,"Tahoma:B","RADIONAME" ,"Radio name"
    /L05,311,24,142,38,#Fore#,16,"Arial Narrow:B","STATUS","Status"
    L,211,54,88,28,#Fore#,15,"Tahoma","FREQUENCE","RIG HT"
    L,284,54,70,34,#Fore#,15,"Tahoma","=MHz",
    L,224,98,35,29,#Fore#,18,"Tahoma:B","RADIONUMBER", "Radio number"
    L,222,145,321,25,#Selected#,15,"Tahoma:B","RDSTEXT ",""
    L,387,53,100,25,#Selected#,15,"Tahoma:B","RDSNAME" ,""
    L,262,92,275,47,#Fore#,25,"Tahoma:B","RADIONAME","Radio name"
    Oh, it was gpstop.skin not fulltop.skin, I was doing it from memory. my bad
    in rr.ini
    picspath=<path to pics>
    Found it! Thanks!
    BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
    Bezel Worklog-My Install -iDrive F01 RR Skin
  2. #42
  3. #43
    Sep 2006
    Belgium
    That's a bit of a problem. I only have the HQCT in my car and there I don't have the ability to screencapture. I could make aa screencap of the one on my desktop but since I have no radio there it would be the same as when you open it.
    I will try to make an actual picture of the screen in my car and post this later tonight.
  4. #44
  5. #45
    Sep 2006
    Belgium
    Oh? Didn't know that one.
    Gonna give it a try, Just have put an original skin on my USB stick and put it in the car for the before pic. Will be back in a sec.
  6. #46
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Alt prt-scr will put the active window into the clipboard, then just paste it into your favourite image editor (mspaint, paintshop or photoshop).
    ctrl prt-scr does the whole screen.
  7. #47
    Sep 2006
    Belgium
    Got it!
    Original
    Modified
    The RDS text wasn't as big as I tought in your version. I did it bigger in a first modification but changed it because of the reasons stated above. My bad.
    As you can see the RDS text is a bit blurry with the HQCT. You need really good reception to get it right. Unfortunatly really good reception is rare.
    As you can see I made the frequency smaller and the preset name bigger. Also changed the layout a bit because things where sitting on top of eachother. The Stereo, Scan and Local indicators were not in the right place and the RDS info was on top of the Stereo indicator.
    It's all personal but I like it the way I did best. Maybe you can switch the preset name and frequency. Also on the night version I would make the RDS text in a darker colour because now it's white and as I said, it's flikkering all the time and blurry and when it's white it just draws too much attention.
    Also in the Funcions skin the frequency label isn't big enough. When tuned on Frequency "102.5" for instance it displays "02.5"
    Hope this is usefull.
  8. #48
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It's all useful information.
    You got a picture of the Functions skin as well.
    I will look at it and see if we can get a nice balance for HQCT and normal radio.
    Anyone else have any comments on the radio skin and have pics to illustrate?
  9. #49
    Sep 2006
    Belgium
    The Functions skin:
  10. #50
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok after doing a bit of testing I have made some changes.
    download the following files and extract them to your iDrive folder, these will overwrite the top.skin, gpstop.skin, cdrip.skin and launch.skin and will correct the slider problem and the 'missing' satelite symbol if RoadRunner is selected. Also they correct the no selection and applications covering up the buttons in the application/launch screen.
    There is one manual adjustment to be made and that is to rename the slider folder
    slider_PHOCO_signal
    to
    slider_phone_signal
    A similar correction file has been posted for the classic skin and is in the classic skin thread
    http://www.mp3car.com/vbulletin/show...d=1#post967689
    Cheers E.
    Attached Files Attached Files
  1. iDrive 2.20 Release
    By Enforcer in forum RR Released Skins
    Last Post: 08-03-2009, 05:03 PM
  2. 7-31-06: RKC Big Monday Night GTG: FRISCO
    By Bakushan in forum MP3Car Gatherings
    Last Post: 07-31-2006, 03:23 PM
  3. BMW E30 install with night vision
    By tekta in forum Show off your project
    Last Post: 07-01-2006, 03:41 PM
  4. Night / Day Skin Code:
    By IntellaWorks in forum Coders Corner
    Last Post: 01-06-2006, 03:58 PM
  5. Streets and Trips 2006 released!!!
    By Mattkins99 in forum Road Runner
    Last Post: 10-20-2005, 05:30 PM
