Page 10 of 317 FirstFirst 123456789101112131415161718192060110 ... LastLast
Results 91 to 100 of 3166
Thread: Lsx Void 3.0
  1. #91
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by djmickyg View Post
    something else i noticed..
    the install deleted all the info from the rr.ini file
    and put the custom LSX info into. but
    i think it has put it in 2 times.. there was 2 lots of the same info and only one set semeed to change with the changed made in the skin?
    i have deleted one whole set of information and the skin still works fine
    you have to make sure before you run the install that rr.ini does not have any previous setttings from older versions of the skin as well as if you are reinstalling this version, clear the lsxvoid settings from the rr.ini. If you run it back to back the rr.ini will have duplicate entries.
    The next version of RR (i was kind of waiting for before release) will make it so this step is not ever needed again as the settings will be stored in a different file unique to each skin so no need to ever have to worry about it.
    but until then...
    beer replenishment fund
    mp3car live search
  2. #92
    Aug 2003
    Chicago
    UPDATES:
    ive updated the first post links with
    2.01 full version of the skin
    fonts installer that automaticly fixes the font italic issue as well as the manual font if you want to fix it yourself using directions in above posts.
    the updated 2.01 includes a few small bug fixes, 1 new main menu layout called "clean" only avail for night skin and of course the font fixes.
    There will be link to a version that only includes the changes/fixes very shortly so those with the skin already installed no need to redownload the full install again.
    mp3car live search
  3. #93
    Newbie zuratharamon's Avatar
    Oct 2006
    Athens Greece
    Hi LS.
    Hails from Athens, Greece.
    I just installed yesterday your skin... Fabulous IMHO!
    Though i have some questions.
    When i am in the audio screen, how can i see the directory structure that i have my mp3s (instead of the ipod like Album - Artist - Genre) ?
    And my last one, by clicking the button to change directory, up or down i get the following message
    What about the visualization? I see in the previews that it is embedded in the main screen. Though i cannot enable it. Any clues?
    Thanx man
    Keep up the gooooooooood work
    Panos
    Keep on rocking in the free world!
    Zuratharamon @ www.ibizamania.gr
    (Πάνος)(ΜΟΡΣΙΜΟΝ ΗΜΑΡ)
  4. #94
    FLAC djmickyg's Avatar
    Feb 2004
    i think u need to install the font fix update in the first post
    whats ur MP# directory structured like? and have you updated ur rr.ini COnfig after installing LSXVOID?
    LS: I have another issue.. in the day skin the phone popup is all to one corner and the icons don't show, also in the day skin in the phone bit where u type the numbers, the back ground is black and the text is black..
    thanks
    EDIT: looking it to it a big more.. looks like the call_off.jpg image is wrong in the day version. night seems ok
  5. #95
    Newbie Eugene120's Avatar
    Mar 2006
    Moscow/Russia
    Hi.
    Just installed the skin and the result is that RR loads and hangs on this:
    Is that an "invalid Flash installation" problem or what?
    LSXVOID1.6 worked great.
    Another moment: everything including RR and windows is installed on drive F... may be that is the sticking point...
  6. #96
    Jul 2005
    Quote Originally Posted by Eugene120 View Post
    Does your system tray show an icon associated with the AutoIT scripts? I had a similar problem, and it was corrected by:
    1.) installing RR into the default directory of C:\Program Files\Road Runner
    2.) installing the LSX Void 2.0 skin into the SKINS folder in RR
    Not sure if this helps any... just trying to reduce LS's post count
    1997 Mustang GTS "Jenna"
    VIA SP13000, 7" Xenarc TSV, 200GB, 'modified' M2-ATX, 1GB DDR400/3200, BU-353. RoadRunner + LSXVoid
  7. #97
    Mar 2006
    Moscow/Russia
    Quote Originally Posted by Miles View Post
    Yes there are such icons. And the number of them is equal to number of unsuccessful attempts to start RR
    So, I think, I'd try installing RR to drive C (partitionmagic will help to enlarge it)...
    Thanx for advice. I'm gonna try it in about 10 hours... (it's almost 03.00 in Moscow now )
  8. #98
    Low Bitrate raphizzz's Avatar
    Brussels - Belgium
    Hi, i just installed this great skin and evrything is working pretty good! thank you liquid smoke!
    The only thing is i lost all my rr.ini but that's not so important.
    is it possible that since installed lsx, i lost both video and DVD resume?
  9. #99
    Jul 2005
    Microsoft Streets & Trips Skin for LSX Void 2.0
    With liquid_smoke's approval, here is my attempt at providing skin(s) for Microsoft Streets & Trips 2006.
    The attached zip contains 4 files:
    GPS_Streets1.skin
    Skin with streets app in the middle, surrounded by the commonly used buttons. By clicking on the 'FS' button in the top, it loads GPS_Streets2.skin.
    GPS_Streets2.skin
    Skin with streets app larger, covering up the top buttons. By clicking on the 'FS' button in the top, it loads GPS_Streets3.skin.
    GPS_Streets3.skin
    Skin with streets app filling entire screen except time, song title and 'FS' button. By clicking on the 'FS' button in the top, it loads GPS_Streets1.skin.
    GPS_Streets_POPUP.skin
    When using Streets1/2/3.skin, clicking on the 'MENU' button will open up this popup screen with a few more additional buttons.
    Here are the settings I've added to Exectbl.ini within both the day and night version of the skin:
    /MICROSOFT STREETS & TRIPS START
    /MICROSOFT STREETS & TRIPS Support
    "GPS4","LOAD;GPS_STREETS1.SKIN;RUN;C:\Program Files\Microsoft Streets & Trips\Streets.exe;Microsoft Streets & Trips||GETFOCUS||GETFOCUS"
    "MSStreets_Night","ACTIVATE;Streets||SENDKEY;%VMN| |GETFOCUS"
    "MSStreets_Day","ACTIVATE;Streets||SENDKEY;%VMR||G ETFOCUS"
    "MSStreets_ZoomIn","ACTIVATE;Streets||SENDKEY;%VZI ||GETFOCUS"
    "MSStreets_ZoomOut","ACTIVATE;Streets||SENDKEY;%VZ O||GETFOCUS"
    "MSStreets_POI","ACTIVATE;Streets||SENDKEY;%TN||GE TFOCUS"
    "MSStreets_FindLocation","ACTIVATE;Streets||SENDKE Y;%EF||GETFOCUS"
    "MSStreets_Planner","ACTIVATE;Streets||SENDKEY;%UR ||GETFOCUS"
    "MSStreets_Directions","ACTIVATE;Streets||SENDKEY; %UI||GETFOCUS"
    "MSStreets_Guidance","ACTIVATE;Streets||SENDKEY;%T V||GETFOCUS"
    "MSStreets_GPSData","ACTIVATE;Streets||SENDKEY;%TP ||GETFOCUS"
    "MSStreets_ClearRoute","ACTIVATE;Streets||SENDKEY; %UL||GETFOCUS"
    "MSStreets_LocateMe","ACTIVATE;Streets||SENDKEY;%T M||GETFOCUS"
    /MICROSOFT STREETS & TRIPS END
    Note: you will also need to edit the line that ties AP03 to GPS4
    "AP03","GPS4"
    These skins use the existing images in LS latest release of the skin, so no need to add anymore jpg's.
    Feel free to customize as you see fit, and a huge kudos to LS again for making such a well laid out and designed skin.
  10. #100
    Constant Bitrate rigg419's Avatar
    Apr 2006
    Behind the Orange Curtain
    best. skin. ever.
    for any program of any kind. Blows the doors off the standard Centrafuse skin, and is so much more....awesome is the only word I can think of...... than any of the other rr skins. I know there are some good ones, but this is just amazing. I'm switching back to rr from cf just so I can run this skin
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
