LS, any thoughts on my Sirius ideas?
yes you can disable it now also.
Find and Edit the ExecTBL.ini file in the skins folder.
Find the GPS sections and choose the section that matches the version of IG you are running.
The below code (example) is for IG3 Native
/IG3 NATIVE
"GPSFS","LOAD;external_gps_full.skin;RUN;;iGuidance||RUNQ;LSTOOLS\SB2.9_IG3\iGuidance\EXIT_FS.exe||RUN;LSTOOLS\SB2.9_IG3\iGuidance\IGCONTROL_FS.exe"
"GPS3","GPS||RUNQ;LSTOOLS\SB2.9_IG3\iGuidance\IGCONTROL2\IGCONTROL2.exe||SETVAR;isigopen;1||SAVETOSKIN;isigopen;1"
"GPSADV","LOAD;EXTERNAL_GPS_ADV.skin;RUN;$GPSPATH$ ;iGuidance||RUNQ;LSTOOLS\SB2.9_IG3\iGuidance\IGCONTROL2\IGCONTROL2.exe"
remove the parts in red to disable.
Note, if you are using IG3 there are other lines of code in the same section that need to be edited also. THe above is just an example of what line in the code actually calls up the flyout menu.
beer replenishment fund
mp3car live search
mp3car live search
its controlled by USB but the audio line is on Line in
and is there anything that will explain all the buttons that are currently on that page.. not sure what half do.
LS,
I hate to bother you, but I am. I just wanted to know if you were able to incorporate the delete function into the new skin?
Car PC Progress
(>>>>>>>>>>>>---) 90%
"Don't speak about it, be about it"
A while back you had asked about whether or not people would like to have an installer and I think the general consensus was yes. So today I had a thought about it which might help some folks out. I have my RR install in the C: and have never had problems because your defaults always work for me. I do recall that some people who installed elsewhere had to change some of the commands in the skin to match their actual locations. So I was wondering if it would be possible to have the installer ask questions about where certain things are and then rewrite the code appropriately. Just a thought.
mp3car live search
actually the only thing in the skin that was path dependent was the ratings plugin, which was pretty much out of my control. In the thread for the plugin there are various updates that fixed the path issue.
The skin will still be an installer cuz its so much easier to just click,click,click, finish than to open folders and copy and paste. But there will also be a copy & Paste version availabe for those that may have had trouble with the installer in the past.
Im prob not going to use the installer i used before, but yet write my own, which should be bullet proof and very car friendly.
mp3car live search
I have two problems with the skin. the second is more major.
1.
i have searched for spectrum analyzer problems and come up with nothing that matches my problem - there is nothing there but white space. Right clicking reveals that flash is running - the right click menu has "movie not loaded... | about flash 7".
I have tried winamp 5.13 and 5.31.
Am I missing something? I can't find much info about your spectrum analyzer at all. Is it a winamp plugin I am missing?
Fixed - Updated to Flash 9 (I use mozilla, and keep it up to date, I had to fire up iexplore and update the flash player in that). But there is no longer a white space, but theres no spectrum analyzer either.
2.
Also, after changing versions etc, the play directory function is playing up (it worked before). it sometimes moves to the next folder, sometimes just restarts the current directory. When double clicked quickly i can sort of provoke it in to going to the next directory.
I uninstalled RR, cleaned its folder, and uninstalled winamp also. Then reinstalled winamp 5.13, and then RR 4-11-07. That didnt solve the problem and neither did changing to 5.31.
I will try going back to the january version i was using before.
