Thread: Lsx Void 3.0
  1. #1101
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by DeltaBi View Post
    Greatwhite, thanks for your help. However I still can't make it work.
    My setup is the following:
    1) Winamp 2.95, base skin, avs visualization
    2) screensaver.ini in the root RR directory:
    AvsTransparent=True
    FadeOnIdle=False
    SecondsToFade=300
    FadeInterval=10
    DefaultOpacity=70
    MaxOpacity=255
    3) in the rr.ini I've got the following statements (among others ):
    avstransparent=true
    visuname=!Winamp Gen!AVS
    The visuname is confirmed by the RRConfig
    I've tried using Winamp alone and one strange thing is that selecting one of the Spectrum analyzer visualization provided by LS the visualization actually show just a tiny bar at the extreme left of the AVS windows, instead other original winamp visualization works as expected.
    What's wrong with it ?
    Please help!
    Hmm.....
    Looks correct to me.
    The only difference is I use wnamp 5.13 as per LS's instructions for what works best with void................
    NOt sure what else you can try.
    Leonardo Da Vinci
  2. #1102
    Newbie DeltaBi's Avatar
    Aug 2007
    NW Italian Alps
    Quote Originally Posted by greatwhite View Post
    Hmm.....
    Thanks. I'll check the setting notes by JohnWPB and maybe I'll upgrade Winamp to 5.13 (I had 2.95 because it looked like it was recommended for Roadrunner).
    Regards.
  3. #1103
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Regards.
    An important note, the transparent AVS will not work with Winamp 2.95. I have tested 5.13 as well as Liquid Smoke and a few others, and find it to be very stable, and fully Road Runner compatible. A couple of the versions prior to 5.13 as well as newer ones, do not work with RR well. The visu will not embed properly. Winamp 5.13 seems to be the magic one
    Sorry to traipse all over your thread LS I was bored!
    My Fiero Build Thread
  4. #1104
    Aug 2007
    NW Italian Alps
    Visu not working
    Ok. So I follow JohnWPB's hints (thanks!) and upgraded Winamp to 5.13.
    No difference: LSXVoid still does not show visualizations in the main menu.
    Then I've installed Shock Skin 3.0 and got it working! I reverted back to the BMV2 skin and even there visualization works correctly.
    So now I'm thinking something is wrong with the LSXVoid skin in my installation/configuration.
    One more note: if I click the visualization icon in the upper right corner of the AUDIO page, the skin does show the spectrum visu (not trasparent, however!)
    Someone can help me troubleshoot this? It's a pity I can't take full advantage of this nice skin!!!
  5. #1105
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    Quick recap: So the VIS works correctly outside of RR (just winamp 5.13). Works correctly and transparent in other skins. Nothing happens when you click the VIS in the main screen of LSX VOID 2.0.
    I've run into some strange VIS issues while swapping skins....exit from rr and restart rr with lsx void as the default fixes it (or tapping the VIS button a few times to stop/start the VIS). Which VIS and Logo options are you using? It seems the usual problems with this have been covered...
    Skins are pretty easy to reinstall...I'd try that. Or let someone on your machine using logmein to take a look.
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  6. #1106
    May 2007
    Hey ls:
    Any chance of adding speed sensitive volume control?
    IE: faster speed= increase in volume (user definable)
    I seen to recall RR has this capability........
    I'm off to search........
    Leonardo Da Vinci
  7. #1107
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    Hey ls:
    I thought that this was already going to be included, but I might be wrong?
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  8. #1108
    May 2007
    Hi LS,
    Don't know how I missed this before, but would it be possible to incorporate this rr config editor RR Config Updated - Blue ZX3 instead of the default one when settings is selected in LS void?
    It seems to be much more versatile than the default RR one.........
    Cheers
    Leonardo Da Vinci
  9. #1109
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    gps speed attenuation:
    this may already be simi setup. cant remember, but i do remember using it.
    I think all you really have to do is add a few lines to rr.ini and its done.
    There arent any settings in the UI for the skin to turn on/off ect, but i can easily add them in.
    I think the above VIS issue is cleared up? If not a small recap.
    The spectrum vis only works with winamp 5x 5.13 being the only recommended (by me) version of winamp 5 to use with RR.
    On the main screen the vis is turned on/off in the top right corner. also note, since there are about 10 different layout options for the main menu, make sure you are currently using one that supports a vis ( i think they all do but there may be one that dont)
    Make sure you have winamp set to use classic skin or no visuals will embed no matter whta you do.
    transparency is only supported in winamp 5, use screensaver.ini and rr.ini to set options for this, there is a guide on the first few post.
    codebase
    i dont mind you posting the files at all. If you want me to take a look at them send them to me at liquidsmoke at gmail dot com
    Deltabi
    dynamic backgrounds are only supported in lsxvoid 3.0
    you currently have 2.2
    3.0 is currently unreleased
    beer replenishment fund
    mp3car live search
  10. #1110
    Aug 2007
    NW Italian Alps
    liquid_smoke,
    Your comment was enlightening!
    I knew the problem was something easy I was missing, and your sentence "On the main screen the vis is turned on/off in the top right corner. " cleared it up.
    I completely missed the fact the the VIS are activated by a click in that zone of the screen! Now everything is all right! Thanks a lot.
    This episode however makes me thinking about a documentation of your skin; as someone suggested, it is not only a skin but more like an addon for RR and, as such, I think it would deserve a rather consistent manual: have I missed that too?
    About dynamic background I'll stop trying to do something that cannot be done: I'll simply and eagerly wait for LSXVoid version 3
    All the best.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
