haha I check everyday!
Printable View
I may have missed this due to the size of this thread but how do I get the compass working?
I have Xport setup like this. Imput - com3, Outputs - com1 for Destinator and com2 for RR but the flash compass just points north.
there may be a problem with that flash compass.
open menu.skin and add or make sure this label is present.
L,0,0,0,0,0,0,0,,,"GPSCompass",
Hi!
I try the skin, but i have a problem...
http://www.kepfeltolto.hu/2007/9/20/59b8.JPG
I don't see the menus etc.. and it isn"t work...
could anybody help me?
I just tried it out.. I think I know the problem he is having because I also had this issue while trying it out.
Basically, there's a ratings script LS made for the skin and it is freezing up when starting the skin -- The thing is, this happens:
ONLY WHEN RR IS NOT IN C:\PROGRAM FILES\ROAD RUNNER\ ...
So bottom line is: If you want to run this skin as a whole, make sure your RR is installed at "C:\Program Files\Road Runner\ (at least until this is fixed).
actually this has been fixed some many moons ago.
I didnt write the ratings script, Sonicxtacy is the author. The thread for it is located here
http://www.mp3car.com/vbulletin/rr-p...gs-plugin.html
There are updated versions of the script that do not use hard coded paths.
The skin as a whole does not use hardcoded paths anywhere just so everyone knows, u can install it to anywhere, of course once u have an updated version of the ratings plugin.
guino:
If you want i can send u want i have now if you want to test the skin. The version i have now is a lot different internaly with the code im using than the 2.x versions.
