Thread: Lsx Void 3.0
  1. #1261
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    This is an absolutely incredible skin, with so much thought put into it. It simply oozes professionalism and turns a clumsy mass of PC components into a really sleek looking package. Thank you so much for the hard work.
    But I'm SO confused about the Audio manager - is there any way of ADDING files or folders to an existing playlist? At the moment adding a directory clears all the other files out of the playlist.
    If I thought I could keep up with the updates, I'd try to write a user manual for this wonderful piece of software.
  2. #1262
    Feb 2006
    Could it be today?? :O
  3. #1263
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by Grrrmachine View Post
    thanks.
    the SEL PLUS button in the audio player will add the selected item/s to the current playlist.
    beer replenishment fund
    mp3car live search
  4. #1264
    Newbie MrTrunks's Avatar
    Sep 2007
    Arizona
    Is there a way so the visualization overlay comes back on top when going back to home screen? It loses focus when I browse other screens and doesn't want to come back to top unless I click top right to stop vis then click it again to start.
    Thanks.
  5. #1265
    Aug 2003
    Chicago
    FEATURE CHANGE:
    area affected:
    AUDIO PLAYER
    feature: preset changer
    Currently in the audio player there is a preset button on the top left, it has 2 arrows and save directly under the arrows.
    The way this feature works is it will save up to 5 playlist files and allow you to cycle between them on the fly. The playlist that it saves have to be currently loaded in RR as the actively playing playlist. When you click the button (left or right arrow) to cycle between them, it also saves the track and song possition so when you return to that list it will resume exactly where you left off at.
    The core function of the feature i believe is good. The way its exposed to the user i think can use a lot of work. To save a playlist you have to first make sure RR is playing some music, then click and hold the preset right arrow button, OR click and hold the preset left arrow button. The right arrow will auto save whatever is playing to the preset slot thats currently active. The preset left arrow button will let you pick which slot to save the list to.
    To me thats a lot of work, and confusing if you really dont fully understand what the feature is or does and how it works.
    Changes:
    First i would like to change the name of the feature. Preset changer IMO is kind of weak and really doesn't do a good job of explaining what it does. The new name will simple be called History.
    Why History? Because the other changes will put the feature more in line with being just that, the history of the last 5 things you listened to. NOT the last 5 songs, but the last 5 playlists. So whenever you go to the audio library to load up some music, right before you load your choice it will automatically save whatever is currently loaded to a playlist file.
    The preset button will then say HISTORY instead of PRESET and the save text below it will be removed as well as the option to manually save to any of the slots.
    It will ultimately work exactly as the back and forward buttons work in a Internet Browser.
    This to me is much more intuitive and requires nothing for the end user to configure.
    If you want to manually save whats playing to a playlist, you can always do this by going to the playlist manager (PLIST button) and click SAVE.
    I just wanted to post this up to get any feedback on this change from anyone whos using this feature.
    I do not plan to make it an option to enable the old behavior, as it will require too make a duplicate of the code, make changes to that and also make sure the changes dont affect the old code. Its far easier to just modify whats there.
    So before i pull out the shovel and start digging into the code, voice your opinions now.
    Thanks.
    mp3car live search
  6. #1266
    Aug 2003
    Chicago
    Quote Originally Posted by MrTrunks View Post
    Thanks.
    That is how it will work in V3.
    If you turn the visuals on, on the home screen and go to the audio player, they will stay on. And vice versa.
    mp3car live search
  7. #1267
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    so when will be able to test out these new feature?
    there's still a few hours left for this sunday.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  8. #1268
    Low Bitrate taylorgauss's Avatar
    Feb 2007
    Seattle
    Sunday.. Someday
  9. #1269
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    Quote Originally Posted by liquid_smoke View Post
    FEATURE CHANGE:
    area affected:
    AUDIO PLAYER
    Changes:
    Thanks.
    I have no objections. Not sure how anybody else feels about it. It sounds like a good idea. I never got much into the presets. I used them once or twice.
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  10. #1270
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    I wouldn't have much use for a playlist 'history'. Maybe a 'previous playlist' and remember the last one. I like the current numbered playlists...even better would be a button for each playlist on the audio screen.
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
