Thread: Lsx Void 3.0
  1. #1411
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    I have it installed on 3 machines. 1 locks up when I click audio (of course my carpc), that's the only button I tried...
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  2. #1412
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Did you guys with lockup issues actually remove everything from the previous LS skin (INCLUDING LSTOOLS in RR's folder) -- that is, BEFORE installing the new one ?? He was pretty clear about that, and I myself have had lock up issues because of that in the past.
    Ride Runner RR's Myspace
  3. #1413
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by d0tech View Post
    Same problem here...Let me know if you've found anything
    Also this is on a clean RR install...
    LS mentioned something about about setting up links for images or something like that.
    I've found a way around it for now. I go to "photo", "local", pick an image, click "more", the "wallpaper" and my image is set.
    You have to set up the path to your images though. I just stay away from the "images" button for now. Can't set walpaper from Flickr though as there is no "more" button option on that page.
    Still digging around.......
    Have to wait for LS to "weigh in" on the rest.
    Leonardo Da Vinci
  4. #1414
    Oct 2005
    I uninstalled LSVoid 2.02, uninstalled RR, deleted the RR folder...basically I wiped everything out.
    Install RR
    Install LSVoid 3.0
    locks up
    I must have did something wrong...Will report back if I find anything
  5. #1415
    May 2007
    Quote Originally Posted by guino View Post
    Yup.
    Even rooted around for any remaining folder that might have been left over...........
    Leonardo Da Vinci
  6. #1416
    May 2007
    Install RR
    Install LSVoid 3.0
    locks up
    Does it lock up right away?
    I had that issue but it seemed to clear itself after a few startups. I'd only get one thin black bar down the middle of the screen, then it would lock up with no text in the buttons, and then it started working. Just an intemittent lockup now and then when I click something (I probably still have some settings to sort out. getting there, slowly)
    You did add the lines to RR.ini that is in the existing readme file for the button text, right? (or everything might say "audio")
    LS's readme file should sort things out. Usually does.
    Leonardo Da Vinci
  7. #1417
    Oct 2006
    small town nebraska
    Yeah I removed the old void before installing the new. It works on 2 of the computers, just not the carpc...so I assume it just something in the setup. It's in the parking lot so I can't try anything else for a while.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  8. #1418
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    I know when installed, changed directory on where locations where. Changed where my music location was and where my playlist was saved. after fixing this Audio worked fine. I'd verify all locations for folders are rechecked in RRconfig.
  9. #1419
    Apr 2006
    Richmond, VA
    i know before i changed background and pics path in rrconfig, it would lock up as well when trying to get wallpaper and colors changed.
  10. #1420
    Constant Bitrate slvrsol's Avatar
    Mar 2007
    I had a lock up problem too and it went away. If I remember correctly, i removed all the LS2 files and settings manually (LSTools, Skin folders, files in RR folder, LSX settings in rr.ini) and added the settings from the 'add to rr' and then ran RRConfig again.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
