Thread: Lsx Void 3.0
  1. #1471
    Jul 2006
    Quote Originally Posted by kbreeden View Post
    I guess this is a noob question, but how do I get it to hibernate when I hit "Sleep" on the power menu? Currently, it goes into standby. I have CMOS set to S1 & S3, have enabled hibernate in XP and have set power options to hibernate upon hitting the sleep button on the computer.
    i think you have to set it to hibernate upon hitting the 'power' button not 'sleep'
  2. #1472
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    i think there is also a setting in rrcong called force shutdown options or something like that
    beer replenishment fund
    mp3car live search
  3. #1473
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    open "exit_menu.skin" and just change the button code, from "SLEEPCPU" to "HIBERNATE"
    EDIT:wow a lot of us are watching the threat very closely.
    @LS did you see my post about the DriveLetters script?
  4. #1474
    Jul 2006
    Okay, now that I know where to look I think I can figure it out. Thanks. By the way, wonderful job on the skin!
    did you find those instructions? i have picked through this thread and havent been able to find them...
  5. #1475
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Stil no joy on the video. Applied elcamino's patch and at least now I get a MPC error screen:
    media player classic could not render some pins in the graph, you may not have the needed codecs or filters installed on the system.
    The following pin(s) failled to find a connectable filter:
    c:\program files\road runner\videos.m3u:: output
    Stream 0
    Media Type 0:
    AM_MEDIA_TYPE:
    majortype: MEDIATYPE_Stream {E436EB83-524F-11CE-9F53-0020AF0BA770}
    subtype: Unknown GUID Name {A98C8400-4181-11D1-A520-00A0D10129C0}
    formattype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
    bFixedSizeSamples: 1
    bTemporalCompression: 0
    lSampleSize: 1
    cbFormat: 0
    Media Type 1:
    AM_MEDIA_TYPE:
    subtype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
    lSampleSize: 1
    cbFormat: 0
    I've set my paths evrywhere I can find to the d drive, I even ripped a movie to a folder on the c drive. The player will play the files, but it just pics a random file for a start point. (this was before the patch, now I get the error message)
    Any ideas?
    Anyone?
    It's all I have left to get working......................but I just can't figure it out.
    There must be something in the skin code. MPC will play the video in preveiw mode (embedded in the small window), but when in the "full screen" skin it won't play and flashes back and forth from a total black screen to a black screen with the controls on the bottom.
    I've tried this on three machines so far and multiple installs. Same result everytime. But the strangest part is everythin is fine when I use the old brushedmetl skin. I'm baffled......
    @Elcamino- thanks for the patch, but it doesn't seem to be my issue.
    Leonardo Da Vinci
  6. #1476
    Jun 2002
    Virginia
    Quote Originally Posted by hari-bhari View Post
    I didn't look for any instructions once LS told me where the commands are. I just opened exectbl.ini in the skin folder, found a button on the menu screen that I wouldn't be using, in this case "Sirius," and changed the command from Sirius to:
    "LOAD;businav_full.skin;Businav;C:\Program Files\Road Runner\BusiNav\businav.exe;Busi Nav"
    Now the plugin loads whenever I hit the Sirius button. The only problem is that the button still says Sirius, which I don't think can be changed. As long as I have the functionality I can live with the mislabeled button.
  7. #1477
    Jun 2002
    Virginia
    GW, I haven't closely followed your travails as described in your previous posts, but are you able to get video to play in other skins?
  8. #1478
    May 2007
    Yes. Worked fine in 2.02, works fine in brushed metal. MPC willplay dvd's outside of 3.0 but won't when run from 3.0
    I'm baffled, must be something in the skin, or maybe my 3.0 download was corrupted............or I coul dstill have a setting screwed up somewhere.
    I just don't know anymore after going at it for 2 days straight.
    Does video work for everyone else?
    Leonardo Da Vinci
  9. #1479
    May 2007
    Press and hold the button, select one of the buttons that says "empty" and you will be able to type what you want it to say, when you define it's function...............
    Leonardo Da Vinci
  10. #1480
    EL CAMINO's Avatar
    Jul 2005
    get the latest kazaa codec pack(seeing the error you having), and use the latest mpc version, if not just try the built in player and see if that makes any difference. i have zero issues now.(including the video player, and preview)
    lastly post your rr.ini, also open up the videos.m3u with notepad and post it.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
