not really sure what the issue your having is (video related) i have to dig through some of these threads.
But one thing to note, because of the new video preview feature, you should set RR to use the internal player in rrconfig.
beer replenishment fund
mp3car live search
mp3car live search
mp3car live search
new info on my video issue.
The steps:
OPen video with skin button, no mpc visable in the taskbar, no video, screen flashes back and forth between fs and controls, select file browser, select preview video, mpc opens in the taskbar, video plays in preveiw window.
Go back to main screen, mpc closes in the taskbar, no video, no mpc in the task bar. It appeared winamp tried to open on one occasion but hasn't repeat this behavior.
LS, which files in the skin should I look at to see if there is something wrong with the mpc start path? It has to be in the skn somewhere, mpc works wthout a hitch in other skins and in stand alone mode...........
I have config set to internal player also.
Actually, it seems like MPC is not opening when the main screen comes up. It opens in the task bar when preview is selected, closes when stop preveiw is selected. when I go back to the main screen, mpc doesn't open in the task bar then either. Is it possible I'm missing a bit of code (or crrupt download maybe) to open mpc on video start?
The more I think about it, and the more I watch it do it's thing, the more I'm beginning to think that 3.0 is just not opening mpc in the main video window. I just don't know what code to check........
Oh well, time to put it all aside, bedy-bye time (long past it actually)
Cheers
Leonardo Da Vinci
1. what was ur issue with this? One thing i do know is you cant have any non standard objects in your MyComputer folder, most users will not, but i had an issue a very long time ago when i had a program installed that let me put shortcuts to files and other directories in the MyComputer list.
2. i havnt checked the thread for that plugin in a while, so ill check it out again and see whats new. The version included in the skin has been edited though.
3. Turn on "Show ...." in RRConfig, its pretty much a requirement as there are other areas that do not have a back button (most do) due to space. Also, when selecting a path, you want to select the root folder you want to use as a path, not go into the directory as then you will be selecting the contents of that directory as the path and not the directory itself.
4. Not for me, looking at the skin in the editor now and there definitely is a button there. Unless your talking about some other screen. The only screen i have that is close to what you typed is SETMEDIAPATH_3.skin (there is no setmedia_3.skin) so i assume u mean this screen.
also, ( i think it was you that posted this) i dont see any issues with the new skineditor screwing up the skin if you edit it with it with popup screens etc. I used the new editor heavily and its been working fine for me.
mp3car live search
the driveletters script sets "DISK1" to the first drive that is found, in my laptop i have a floppy drive, which is A:, so when i try to set the paths using the skin, i had the lock up issue, there was no floppy disk present, so i modded the script to set DISK1 to the main drive. that fixed the issue.
i build a video preview script just for the void based in my new script, and is been working good so far. i haven't uploaded the new version, which is way different than the original, and works like a charm in my skin.
all the other things are my bad. sorry.!!
BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
RRTube ==> [View/Download Youtube Videos]
WifiMan ==> [Wifi Manager]
RRec ==> [Audio Capture]
If You Want To Be Given Everything, Give Everything Up ...
Bird York -- In The Deep --
wow, i havent seen a floppy drive in a long time
you can prob get pass that issue by using tweakui (for windows) and set the floppy drive to not show up in my computer. Ill prob add some more error checking to ignore floppy drives.
id like to take a look at your new version of the video preview.
mp3car live search
whenever resuming from standby, the playlist in the audio screen does not show. it does however show what track number i am on, and the total number of tracks in the playlist. on the main screen, the playlist is still there, so i know its not a winamp problem. and if i click library, the iList still works for browsing through my folders, so i know its not an iList problem. if i reload the skin by changing the vis or gps options, for example, then go back to audio, the playlist displays fine. can anyone confirm on this?
Hello,
Great work as usual LS....worth waiting for.
Just a small problem: I m running a foreign Win xp (French), for some screens, instead of having regular Icon (especially Play, Rewind, Forward), I have either figures (4,8) or ponctuation (,appearing. I tried both Fr and En win xp and no problem in the En version. However, I really got to use my French version cause of major BT issues. Any idea how on to solve that pls?
I was also wondering if there was a comprehensive guide to LSXVOID. So many customizable items and so many posts about it(between the 3 threads)
