actually the link can be found here: www.stfu.com
He didnt took the file offline just to **** everyone out.. he took it offline because he wanted to do some bugfixes, so everyone wouldnt be posting that they have probs etc.
We just need to wait for him to give it a green light, upload a new version, and we all be happy again![]()
ideally you should create a folder that is inside of your media library, and use that as the place where all your playlist files are stored. For my setup the name of the playlist folder is "-{saved list}-" with the dash and bracket so its always at the top of the list in the audio browser, as not every skin will support a playlist view screen like my skin does.
IMO using nlite or any other utility to gut windows is a bad idea unless you really know what your doing. And i suspect most dont, cuz if they did they really wouldn't need nlite to do it. It sounds like a great idea on paper, but im willing to bet the most users with any problems with any software are those with gutted windows installs. But the boot up time savings arent worth it for me personally when you take into account the amount of time you have to trouble shoot any said piece of software that isnt working correctly. Is it not working correctly because of my setup? Or because of a bug? Its hard to tell even on a stock xp install, and when its not stock it just compounds the problem.
So if you are having direct X issues thats the first place i would look. Install Road Runner and the skin on another machine that is not gutted and see what happens.
beer replenishment fund
mp3car live search
in your rr.ini file you have a number of things not setup or setup wrong.
your background = line is not pointed to an actual image but just a path.
If you set the background using my skin, it saves the info into the skin.ini file so you maynot even notice or have a problem.
are your videos really stored in mydocuments?
no music path set
no playlist path set
launch path incorrect
i notice you are using iGuidance
your gpspath should look like this
gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe|nowarning
you also want to set
ignative=TRUE
i dont even see that line in your file
your video settings look ok to me, but you are getting all those MCI errors in your debug file (only guino knows what the codes mean) but it looks like MPC is crashing on just starting. Have you ran it stand alone and configured it at all?
What version of MPC do you have? the one im using is 6.4.8.2
Do you have any other skins to test video on? If you were having problems going to the videobrowser thats definitely a skin issue, but the video player hasnt changed since the last version.
I would try to find out exactly what the MCI errors mean and go from there.
mp3car live search
the first thing i see wrong in your bebug is this line
Error loading plugin: RREarth (ActiveX component can't create object)
if your not using google earth i guess ignore it, but if so it seems you have some issues with activeX and or DirectX since GE also uses DirectX.
now for the radio.
Since i do not have any radio hardware i dont know what any of those buttons really do in practice. But lucky for you when i click the Function button it also appears to hang RR on my end. Its not really hanging though, if you press the ESC key RR will come back. So it looks to me that its either waiting for something to load (thats missing) likely missing on my end also since i dont have any radio hardware. Or its failing to do something. Ill look in the skincommands and try to see what exactly is supposed to happen when u click that button.
OK, looking at the Skincommands, the function button is supposed to show the RADIO_MENU_FUNCTION.skin as a pop up screen.
The .skin file does exist and its just a standard popup with buttons. It looks exactly like the pop up you get when you click the top left button.
Doing some more testing , it seems there is an issue with this screen, i cant load it either. So im looking into it more right now, so stop looking into it on your end. This looks to me like an issue with the skin or RR, will know more in a bit.
mp3car live search
problem fixed, ill have a file you can download that will fix the issue.
mp3car live search
mp3car live search
