Page 16 of 317 FirstFirst ... 6789101112131415161718192021222324252666116 ... LastLast
Results 151 to 160 of 3166
Thread: Lsx Void 3.0
  1. #151
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by kolemieux View Post
    LS -
    I assume this is since you are using Var's for the fonts - but is there any way or trick you found to have Skin Editor understand the .txt file so it shows the fonts vs odd characters --- I am using the new RR Skin Editor and need to see if the old version did this too.
    Just curious - or perhaps we need to live with this one.
    Thanks ---
    no there is nothing i can do about the skin editor showing false fonts, since the values for all the fonts are located in a txt file. The only thing that could be done is for the skineditor to load the INC files that have the font data.
    I usually work with RR and the skineditor side by side so its really not an issue for me, i just reload RR (F5) when i want to see changes.
    beer replenishment fund
    mp3car live search
  2. #152
    Aug 2003
    Chicago
    Quote Originally Posted by thadude View Post
    I just want to say that I love your skin.
    But I am having one problem. When listening to music, the play list doesnt switch to the song I am listening to unless i change screens, ie if i am at the main menu and select audio it will reflect the correct song, otherwise it will have the wrong song selected.
    I am guessing this is a flash issue, but I have did the flash work around, (flash.zip) I have also lowered my video hardware accelaration.
    I am using a sp13000 mobo
    Thanks,
    what version of winamp are you running?
    There was at least one other person with this problem in the last version. Ive never seen it happen on my end.
    I dont think its related to the skins though, but just to check try to load any other skin not by me and see if the tracks changes update in the list.
    Let me know what happens.
    Also note, by all means this is NOT a flash skin. There are some flash elements, mostly just logo clocks and a flash compass both of which are off by default and optional. So no flash performance hacks are needed. You can turn your hardware acceleration back up to full.
    mp3car live search
  3. #153
    Aug 2003
    Chicago
    also for all those downloading the latest crop of updates, let me know if you run into any odd new issues. It was pretty late when i packaged all that stuff up.
    If you run into problems with the manual install, try the automated (installer) one first.
    mp3car live search
  4. #154
    Jul 2006
    Quote Originally Posted by liquid_smoke View Post
    I was running the latest version of 5.0, but I uninstalled and reinstalled 2.95 i think.. which ever one was the lastest of the 2. series.
    I was using the Blue Devil skin prior and the list would change accordingly.
  5. #155
    Aug 2003
    Chicago
    so which version do you currently have installed? The latest 5.3x versions of winamp have issues with road runner.
    I would not recommend going any higher than winamp 5.13 (this is the version i use). Every version ive tested above 5.13 has issues, some you may not notice right away.
    mp3car live search
  6. #156
    Jul 2006
    2.95
  7. #157
    Aug 2003
    Chicago
    ill grab that version and see if i have any issues with that version.
    mp3car live search
  8. #158
    Newbie Eugene120's Avatar
    Mar 2006
    Moscow/Russia
    Some wishes for the "Clean" main screen mode, since i find it really useful.
    1. The "-" character at the GPS speed... you must have forgotten to delete it since the previous version of skin
    2. The only thing this screen lacks in the name of the song currently playing.
  9. #159
    Jul 2006
    I am going to try 5.13 tonight and turn the hardware acceleration back up to full.
  10. #160
    Feb 2006
    Only one other small bug I found... My main screen seemed to autoswitch to a different screen after being idle for a bit (I believe I saw the option to disable this, but I kinda like it). This is ok, except that it was going to that dark screen again during the day.
    Just wanted to try to help you get it all fixed in one shot
    Thanks!
    03 Dodge Ram 1500 QuadCab
    Epia SP 1Ghz cpu, 512mb ram, 40gb 5400rpm hdd, 60gb IPOD
    Xenarc 10" touchscreen
    SIR-ALP1, Opus 150w PSU, Griffin Powermate knob
    RoadRunner, LSX Void 800x600 | iGuidance 3.0
    Zyxel P-330W for borrowing wifi
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
