ok after much more subsequent
testing, reinstalling dx, and updating all my
video drivers, and upgrading to RR 11-2, I am pleased to announce that 1) the previous issues of the ilist not appearing after resume has been
solved, 2) the issue with the ilist not reappearing after the album art automatically shows up is
solved 3) the issue with the visu not appearing until clicking on the main screen after switching to another screen and back has been
mostly solved (it seems to be fine after going through a couple on/off cycles, although the very first time i goto to the audio screen and back, it mimicks the on/off setting from the main screen rather than remembering its own), and 4) unfortunately, the issue with google earth screwing up is
not resolved but i have been able to shed some new light on it that may help in diagnosing.
i have noticed that when using the GE plugin, everything functions fine as long as i
only go to screens that i have previously visited. for example, if i have also loaded up the audio library screens, and then load up the GE plugin, i can navigate to those screens without any problem and revisit the GE screen whenever i want. however, as soon as i visit a screen that i had
not loaded previous to starting GE, i get this weird issue.
the best way i can explain it is that it seems that GE is getting confused somehow and several screens popup simultaneously. as soon as i switch to a previously unvisited screen in RR, the GE window pops into the main view, the sidebar shows up, and several toolboxes appear layered on top of one another, however they all only appear with a gray background and no material inside (text or buttons). rr then takes main focus back and the GE window becomes hidden after 2-3 seconds. if i click the GE button in RR, the GE window is no longer embedded in the frame.
if i exit RR, it can be seen that GE is still running. the foremost window has to do with gps settings, which gives me an error box stating that 'this feature is only available in GE plus'. when i hit ok, there are still several toolboxes behind such as ruler, but i can click the file menu and hit exit to quit GE completely. through all of this, the window has no title bar (as if it is embedded) and the main screen shows no imagery. in fact, none of the toolboxes or the sidebar show any buttons or text, just gray backgrounds. so my guess is that this either has to do with a gps port issue (maybe switching to a new screen steals the port temporarily, how does RRearth manage the port? i have xport running, but i dont think i ever specified one for RRearth to use), OR this could be a dx issue.
maybe guino has some ideas about this? i would just embed GE myself and run goops in the background for mapping, but the GE window won't embed (presumably because the splash screen appears then disappears so RR loses it). whew, sorry for the long post, but i hope it makes sense!
p.s. on another note, can you post the exe for the little
iguidance menubar that you used in 2.0. i actually need the zoom + and - buttons that were included in there rather than the left and right arrows in this new release (not sure what they do), because i got rid of my zoom buttons with reshack
