Thread: Lsx Void 3.0
  1. #1631
    HJC
    HJC is offline
    Apr 2007
    California
    3.0 running on an Intel D201GLY (Little Valley)?
    Anybody sucessfully got 3.0 running on an Intel D201GLY (Little Valley)? 3.0 works well on my desktop computer but freezes on "AUDIO" in the D201GLY. I've updated RR to the Nov 2nd release, and ran DXDIAG sucessfully.
    Debug reports the same DXinit automation error as a poster a few pages ago reported. Guino says it's a DirectX problem. I've got all the latest drivers but still no go. Running XP Media Center 2005.
    If you got it running on this board can you tell me which version of XP and the driver dates for the audio and video?
    BTW, Void 2.02 runs perfect on this board.
  2. #1632
    Apr 2007
    I have this skin?.........please....
  3. #1633
    Dec 2006
    Atlanta, GA
    Quote Originally Posted by kyds3k View Post
    ok, i tried changing the background and got the greyed-out problem . . . and i did add the lines to the rr.ini as the installer told me to. what gives?
    i'm a goof. i posted this in the wrong thread . . . sorry!
  4. #1634
    Sep 2006
    Richmond, Tx: USA
    download link in the first post not working
  5. #1635
    Dec 2006
    Atlanta, GA
    Quote Originally Posted by ajamils View Post
    disabled while people are working the kinks out. believe me, i check it every day too!
  6. #1636
    Jul 2006
    might as well only check on Sunday's because it won't be posted any other day.
  7. #1637
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    LS can you edit your first post stating the file is not available temporarily. This way every other post is not asking about the dl link.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  8. #1638
  9. #1639
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by hari-bhari View Post
    Actually I prefer the main window not to have an ilist because the ilist causes the visualization to run a lot choppier in the audio screen (at least I assume its because of the ilist), so i usually leave mine in my main screen where the visualization runs way smoother. If you are intending on making the main screen have ilists, is there going to be an option for this, or will it be automatic? Just a thought...
    For the same reason as above, I like each window to remember its on/off status. Right now, I have it working that way (I think its only working because of a bug), but I
    1) turn my vis on in the main window
    2) go to audio where it's now on and turn it off
    3) go back to the main screen where it is now off and turn it back on.
    This basically enables the vis to stay active on the main screen and not in the audio window where it runs very choppy and obscured my ilist. On ocassion when I switch back to the main screen the vis doesn't show up until I touch the screen, but in about 90% of the cases it does show back up.
    In regards to the top of the first line in the playlist being cutoff on the main screen, I am having that issue as well. I just thought it was intended...but I guess that wouldn't make a whole lot of sense.
    In regards to the video issue mentioned earlier where the playlist is not updating with the newly selected files, I did check my RR version and it is 11-2. I will try fully uninstalling and reinstalling the skin now that my path is set up correctly, and I am assuming it access the new files just fine. I'll update when I test it out.
    *New Question*: Sometimes when I open up the navi screen and then close it, and switch to several different screens in between, the navigation screen seems to have been closed out. So when I click navi again, it loads up the screen from scratch as well as iguidance. Normally this is no problem, except when navigating where it could be a problem if you were waiting on the next turn and didn't know iguidance had shut down. Is there any way to make sure the navi screen and iguidance remain loaded? Maybe it's something I overlooked, but I would assume that once navi is started up, it should remain active in the background.
    Other than the above issues with the video and navi screens, the skin is working great. I went on a long roadtrip this weekend, about 10 hours total, and had no lockups or freezes. On occasion RR crashed when I tried to load an entire genre, so I went through each of the albums in there and noticed one of them is having trouble being read (no track list in RR), so I'll look into that. I also had difficulty clicking items in the ilist and oftentimes I had to click 2-3 times on an item before it was selected, but I will post that issue in the RR release thread. Thanks again!
    ilist on main menu:
    actually, it already IS an option, 14 options. There are a few main menu that dont have the playlist. There will be a new main menu option to replace the last 2 that are in the list that are duplicates, so i guess one of them can be a version with a standard list. All the other list are already converted to ilist.
    The top of the list being cut off is a bug in RR, not really anything i can do about it.
    But this doesn't happen with the ilist, so really wont be an issue in the future except for the one standard list mentioned above.
    Navi:
    When you load navi and it loads IG. If you close the screen and immediately go back, does it relaunch IG? Or only after you go to several different screens? Have you tried to increase the number of screens RR will hold in memory, in rr.ini (screenlimit=12). Also, what version of IG?
    beer replenishment fund
    mp3car live search
  10. #1640
    Aug 2003
    Chicago
    Quote Originally Posted by Quattro View Post
    For some reason i though i did that already, but i guess i didnt. Lotta things going on at the moment. Ill edit it now while im thinking about it.
    Quote Originally Posted by Enforcer View Post
    maybe johnwpb could do it for him
    why would i need that?
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
