Thread: Lsx Void 3.0
  1. #1731
    Jul 2006
    only thing i can suggest is reinstall your video card drivers, download and reinstall directx, and reboot your machine. are you running on a virtual machine by any chance or is this directly on your carpc in windows? i know dx wont work on my mac while running windows in parallels.
  2. #1732
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    Quote Originally Posted by hari-bhari View Post
    This is directly on my pc. I just downloaded Directx 9c. I'll install and reboot. The weird thing is that pressing the audio button worked the first time and that was it. Looks like no music in the car tomorrow.
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  3. #1733
    Jul 2006
    thats weird, when i tried, it wouldnt even work once. go figure. hopefully guino finds a way to make the code more robust, but i dont even know if its in his hands. try visiting the video or gps screen see if that freezes too. it shouldnt. only conclusion i can draw is that its something to do with the ilists.
  4. #1734
    Low Bitrate TxAxZxZ's Avatar
    Dec 2005
    FWB, FL (but currently in Belgium until 2016)
    I had LSX 3.0 installed and was working ok. I uninstalled 3.0, installed 3.2 and now I can't get any music to load. I load an album but the playlist will stay empty. I tried a different skin and still can't get any music to load. I open winamp locally and it plays the music I loaded. I updated road runner to 11/4/2007 install, re-installed winamp 5.13, and re-installed LSX 3.2.
    Any thoughts why I can't get music to play in road runner, but it plays in winamp locally?
    JeepTablet Project
    - Design <<<100%>>>
    - Construction <<<70%>>>
    View My Worklog
  5. #1735
    Jul 2006
    did u check your rr.ini and make sure its pointing to the correct folder for winamp and your music library?
  6. #1736
    Dec 2005
    just checked...all paths show correctly in rr.ini
    JeepTablet Project
    - Design <<<100%>>>
    View My Worklog
  7. #1737
    Dec 2005
    here's a snap shot of my menu after I load an album (from library).
    I also have album art that was working before I installed 3.2
    JeepTablet Project
    - Design <<<100%>>>
    View My Worklog
  8. #1738
    Dec 2005
    Hari,
    I tried your trick of uninstalling 3.2...re-installing 3.0, and then installing 3.2 over 3.0. My problem has been solved also. There is something definitely missing in the install file of 3.2.
    EDIT: I spoke too soon. Everything was working fine, but now I get the 438 error.
    JeepTablet Project
    - Design <<<100%>>>
    View My Worklog
  9. #1739
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    humm, cant say ive ever seen that error before. Have you guys tried re-registering your dlls?
    For the guy who cant get audio to play, it sounds like u need to register the winamp.dll.
    I dont know if the RR installer does any of this for you or not, i dont use it cuz it has bad defaults.
    If people are finding installing 3.2 over 3.0 works better, ill have to take a look at the 3.2 installer and see if anything is not right. Installing 3.2 ontop of 3.0 is fine as its not like 2.x at all which had significantly different core parts.
    beer replenishment fund
    mp3car live search
  10. #1740
    Aug 2003
    Chicago
    Quote Originally Posted by BReMFoX View Post
    Same here.
    Also the Error 438.
    Found something, maybe is has to do something with it?
    BTW, really nice Skin!
    Had it working for a while untill this error appeared.....
    This is what i think the problem is also.
    and when i think about it more, i did remove the GDIplusswrapper.dll file from the install because i felt this is something that RR should handle itself. So if you uninstalled 3.0 via the uninstaller it probably unregistered the dll as well. Which is why i removed it to begin with, its not really my place to include that file. But was originally included in an effort to prevent having to do it manually which is a pain in *** in the car.
    A fresh RR install should restore the dll.
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
