thanks for all the tips.
-in regards to your question whether the default menu contains an ilist, the answer is yes. i had it up and running for a few minutes before i got the error and it was purty
-in regards to your question about the jumpdrive, i have a simple kingston datatraveler drive, with no fancy or proprietary security or encryption
software, and i have reformatted the entire drive to fat32 in mac and pc more than once. ill give a shot to your custom drive letter solution, but its just weird that it was working and then stopped. also, just to clarify, the drive letter E:\ shows up in the list along the bottom, but when I click it, nothing happens.
-also in regards to the SEND2 button, what you described above sounds like the function of the COPY2 buttons for sending files directly to your most used folders. i still dont get what SEND2 does.
-in regard to google maps, the sidebar did not close even when i manually typed in several addresses or locations in the search box. not the end of the world, just something to note as you move forward i suppose.
-also i noticed several things which are mostly insignificant and don't affect functionality much. numbers 1 and 2 are bigger, the remaining ones are minute.
1) in your seeq function, if you preview a file the audio player stops. however if you exit the seek skin and start playing a song again, the audio file being previewed does not stop, and both play simultaneously. also, for some reason, sometimes when i exit the seeq screen and go back to audio, it just cycles through my playlist, playing each song for 2 seconds. i have to go back into seeq and hit 'stop' to fix it.
2) in BBAA, using search seems to bring up a list of files containing the search word. however, the files are listed with no picture above them (not even an empty folder icon) and the full path of the file is displayed rather than the file name, making it necessary to wait for the text to scroll across before you can actually see the name of the song. also, using this search somehow breaks the album art icons above each of the albums, so that even in BBAA view, the entire list is displayed without any album art, only the text (i can upload a pic if need be)
2)also, your seeq function allowed me to find files on another computer on my network which i dont even have the password for or access to. how is this possible? maybe im just going crazy, but i disabled the network card and the files did not show up, and then when i re-enabled it and re-searched, they showed up again.
3)the blackout screen has the
wifi icon in the upper right corner showing.
4) the triple dot graphic between the end of an ilist and the beginning is not there anymore like it was in 3.0
5)rolling over the DEL button in xplorrer shows the wifi icon in the background.
last question, is there a day skin included or on the way?
