Thread: Lsx Void 3.0
  1. #1781
    May 2006
    Simi Valley, CA
    Maybe I'll PM him tomorrow if I get no help. There are instructions here but I just don't know how to use a hex editor. I tried and I got an owee in my head.
  2. #1782
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    Quote Originally Posted by liquid_smoke View Post
    the color picker is exactly the same as it was in 3.0. Are you picking a color? What exactly happens when you try to go to that screen, does the screen ever show up? Or it locks after teh screen shows?
    As soon as I click on the color picker button, the screen locks up. I don't know what's going on but if I do the same thing via logmein, I don't have that problem. Same goes with the Audio button. With logmein, the system locks up with an InitDX error. If I press the Audio button while sitting in the car, I have no problem. Anyway, I'll get you a debug readout.
    For IG, go the OPT>GPS options and choose a layout. I believe the default layout is fullscreen mode so thats why you see the buttons. They should leave when you exit. But if the layout wasnt selected correctly (prob my fault on resetting the skin defaults) it may not know to close them. Just choose a gps layout and retry, that should work it out.
    That fixed the problem. Thanks.
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  3. #1783
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by CARLOS_CET View Post
    you will likely get dxinet errors if you are using a type of remote desktop like logmein, thats why it locks on the audio screen because there is an ilist and i dont think any remote desktop apps support direct x, they usually dumb down the number of colors on screen and turn things off to increase performance.
    so if im correct, when you use logmein, you can click the color picker fine, but not in the car and u cant click audio when using logmein but you can in the car.
    ill take another look at the color picker, and see if theres is anything i can see that would cause any problems.
    beer replenishment fund
    mp3car live search
  4. #1784
    Aug 2003
    Chicago
    Quote Originally Posted by GiODi View Post
    FYI: There is a IG4 mod on its way.
    mp3car live search
  5. #1785
    Aug 2003
    Chicago
    Quote Originally Posted by hari-bhari View Post
    did you register your gdipluswrapper dll?
    i had no idea it was an online search, i thought it was local. what database are you searching?
    i tried your above suggestions, and like i said, the drive E shows up in the list but nothing happens when i click it. ill just use the workaround from now and test with another drive if i can
    when you manually added the drive to skin.ini did you list the drive letter
    like this
    DISK4=E:\
    or like this
    DISK4=E
    the first one is the correct way.
    mp3car live search
  6. #1786
    Aug 2003
    Chicago
    an updated download will be posted tonight. Fixes a few oversights, like some of the settings were not reset to there defaults, disabling ilist on the main menu screens,fix for seeq screen where it will continue to play audio when u exit, possible colorpicker fix, search button removed from bbaa screen (should not have been there), and a few small tweaks.
    and also fix for the fm or hd radio setting option
    mp3car live search
  7. #1787
    Newbie MrTrunks's Avatar
    Sep 2007
    Arizona
    can someone tell me how to remove a song from the current playlist using lsx3.2?
    I can't seem to figure out how to remove individual items only add them or clear entire list.
    Jul 2006
    like this
    DISK4=E:\
    or like this
    DISK4=E
    i have it the first way correctly. it was actually already listed there, i guess the last instance of checkdriveletter or whatever had logged it. but still, nothing happens when i click it. ill let u know when i get a chance to try another drive, but it may be a while.
  9. #1789
    Aug 2003
    Chicago
    Quote Originally Posted by MrTrunks View Post
    You cant.
    If you just want to prune a list but not actually delete the song, you cant do this in the skin.
    BUT... If you actually want to DELETE the song that is playing then just click and hold the "Delete Track" button.
    This button will either immediately delete (GONE FOREVER) the currently playing song or it will send it to the recycle bin.
    To configure witch action it will do, edit the file delete.ini found inside of the "deletecurrent" folder.
    By default the action=recycle, to delete forever without sending the file to the recycle bin, change it to action=delete
    what you want to do isnt a bad idea, so ill look into adding this feature. If i weren't actually in the middle of uploading an updated release, id add it now.
    But since its so easy to add, just follow these steps to enable it.
    open audio_player.skin in notepad or any other text editor or use rrskineditor.
    find this line
    B01,715,298,86,62,"",@DELETE_CURRENT@
    and replace it with this line
    B01,715,298,86,62,"MINUS1",@DELETE_CURRENT@
    so now after doing that, when you click the delete track button, it will just remove the item from the playlist and nothing else. Click and hold the same button if you want to physicaly delete the track from your hard drive.
    ill prob upload an updated audio_player.skin file with the above changes for those that dont want to dig around in the .skin file.
    mp3car live search
  10. #1790
    Sep 2007
    Arizona
    I did what you said and I also changed the text from Delete Track to Remove Track
    Thank you for your help with the current workaround
    Can you tell me what the Play Selected button does when browsing the Library? When I click it it doesnt do anything except clear my current playlist and winamp continues to play the current song it was playing before.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 01:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 12:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 09:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 01:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 07:00 AM
