Page 18 of 317 FirstFirst ... 891011121314151617181920212223242526272868118 ... LastLast
Results 171 to 180 of 3166
Thread: Lsx Void 3.0
  1. #171
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    Quote Originally Posted by thadude View Post
    I actually found this out this morning. I saw that it was unchecked... not sure how but ya. Thank you though.
    It happened when you installed the latest version of RR.. i think by default the box is unchecked.. maybe it was something new that was just added. but yeah.. glad that worked for ya.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
  2. #172
    Registered User vfinterceptor's Avatar
    Oct 2005
    up-the-hill-turn-left-by-the-big-tree
    Hi LS,
    Skin just keeps getting more impressive as I use it!
    Not sure how I managed before void.
    Couple questions:
    The good morning, good night etc message on start up, what file would I need to modify to change the text in those messages?
    Are you going to make a daytime background for the "clean" option or is this something I'll have to work on PS-ing myself?
    Only one real problem-
    I like the skin so much that my little P3 500 lappy doesn't perform well enough to do the OS justice (ram issue mostly and it's maxed out at 196mg - delays, stability, etc). Time to haul the extra p4 2 ghz desktop system out of the closet that I've been holding onto and make a powerhouse carputer! (guess I'll have to get on the form and play the newb for startup and shutdown options, probably have to go an inverter to feed the beast)
    Again, great skin! Incredibly professional looking and more versatile than any aftermarket packaged solution could be! And Free! You are indeed a gentleman, sir!
    Cheers
    BJ
  3. #173
    Mar 2004
    Quote Originally Posted by vfinterceptor View Post
    You could try tinyxp to get around the RAM slowdown. I'm using tinyxp rev05 and it only uses like 55mb of ram
  4. #174
    Feb 2006
    Quote Originally Posted by liquid_smoke View Post
    flash has nothing to do with the visuals, but if you want the visuals that i use.....
    You will need to use a newer version of winamp, the vis i use wont work with 2.95, i strongly recommend 5.13, the newest versions of winamp have several issues with Road Runner that most may not notice with normal basic skins.
    http://www.mp3car.com/vbulletin/atta...4&d=1151034091
    Extract it to your Winamp\Plugins\avs\ directory. Start winamp manually, select AVS as the plugin. Start the visualization, and then right click on the window and select Spectrum and choose which one you want.
    Verify that you have "AVS window" as your vis in roadrunner (visuname=!Winamp Gen!AVS). Then just startup RR, and click on the vis indicator/date in the top right.
    03 Dodge Ram 1500 QuadCab
    Epia SP 1Ghz cpu, 512mb ram, 40gb 5400rpm hdd, 60gb IPOD
    Xenarc 10" touchscreen
    SIR-ALP1, Opus 150w PSU, Griffin Powermate knob
    RoadRunner, LSX Void 800x600 | iGuidance 3.0
    Zyxel P-330W for borrowing wifi
  5. #175
    Oct 2005
    Quote Originally Posted by dyne View Post
    I've tried tiny xp a couple times and have even shrunk xp down with nlite a couple times myself. It always seemed like I had to give up something I wanted no matter how I cut it.
    It did speed up the system though, just has too many compromises that I don't want to make.
    Thanks for the idea though.
    Cheers
    BJ
  6. #176
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    LS .. again great skin, the more i get use to this newer version, the better i understand it.. and like it...
    I am running this on a laptop and also on my carputer.. I havent seen this problem on the forums, so i am not sure if its something Im doing or something unseen.
    All is fine if I access the internet, or weather/radar... but if i try and access gas by itself (before any other), my cell wont connect. Once a connection is made on any other, gas will work... it seems like the gas selection doesnt promote a internet connection..
    While Im on this topic.. I dont believe this a skin problem, cause it happens with every skin that has a weather option... but on my laptop while trying to select weather (alone) something is preventing the update.. I removed norton, set the win firewall to not, and (with either cell or my house Lan) it still wont work . The only way i can update weather.html is by using a script i found here on the forums, but from what i have read, apparently rr wont show the screen until a connection with weather server is made, any ideas???
    again,,,, thanks
    Dual Lilliput's 70NP/C/T
    Syntax SV266AD KT266A
    AMD Athlon XP 2000
    Viking 256MB DDR
    D-Link Wireless 802.11B
    Seagate 120GB
    OrbitMicro 250W DC/DC converter
    SII Wireless Audio Link
    Digimoto OBD-II
    Earthmate GPS
    BU-303 USB GPS
    D-Link Bluetooth
  7. #177
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Anyone have the latest RR? The beta version is down and I'm having some issues with this skin at the moment. I have one of the Beta versions after the 11/12 release. The latest one released in the forum.
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  8. #178
    Newbie frankrizzo's Avatar
    Jun 2006
    CT
    did i miss something, did the files for D/L go up today and back down?
  9. #179
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by yrean View Post
    Sorry I wasnt around yestarday, but i just seen this post. This has nothing to do with winamp or flash. You should run version 5.13 of winamp so all you visuals in this skin work correctly etc. But thats not the issue. To fix this. Go into RR setup. go down until you see a box called highlight current playlist song on change. Make sure this box is checked That should fix your issue.
    sorry for the typo's... im in traffic on the way to work.
    Thanks for pointing that out yrean, someone was having this same problem in the older release thread and i keep forgetting this can be turned on and off in RRConfig.
    beer replenishment fund
    mp3car live search
  10. #180
    Aug 2003
    Chicago
    Hi LS,
    Couple questions:
    Cheers
    BJ
    Welcome Messages:
    The images used for these are found here
    C:\Program Files\Road Runner\LSTOOLS\welcomeMSG
    if you change the size of the image you also have to update the scripts, everything related to it is in that folder.
    Yes i will make (actually already have) a "clean" option for the daytime skin.
    yeah, i agree 196MB of ram seems to be the biggest problem. Most if not all of that is being sucked up by windows on boot.
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
