I spent already 3 hours trying to make it work.. did anybody get any success?
beer replenishment fund
mp3car live search
mp3car live search
Set every language thing in English, that should do it. Had same problem with French windows. It did the trick.
with the latest RR, having to delete the resume.ini each time before i load RR else all the buttons load with no text labels and RR hangs.
95 Mustang GT + Mach 460 Audio
Lilliput EBY701 7" TS LCD w/ 4-way arm
BU353 USB GPS
iGuidance 3 + Road Runner + LSX Void2
200W Inverter
Intel Core Duo 1.6GHz T2050, 1GB DDR2, 80GB, DVDRW
Leonardo Da Vinci
thats very odd.
double check your rr.ini and make sure the correct version of the skin is set for day and night and also what the path is set to resume.ini
It sounds like you had void2 installed previously and its still in teh path for either day or night.
Also, it is HIGHLY not recommended to try and use the day version of void 2 and void3 for night if u were doing that.
mp3car live search
this was a clean install on a new machine.
theres no other skin apart from lsxvoid3.2 installed, and no other RR apart from the latest one.
when i downloaded it, it didnt come with a RRconfig.exe and running RR would not generated a rr.ini, i had to grab webmaster's rrconfig and used that to setup the rr.ini.
BU353 USB GPS
200W Inverter
Sadly I have been too busy with other things to deal with this issue the last few days but.... I am using the proper resolution. I was concerned that somhow that had changed and opened the ini file to check. But the show resolution was set for 800X480. Right where I expected it to be. Normally I change it to the 800X600 using the opt button but either way I can at least see the whole screen. With my current problem I can't even view the portion of the skin with this OPT button.
sounds like u dont have a full install going.
There are a number of files not included in the updates cuz it expects u to already have them.
you should prob grab the installer version of RR then copy the latest update ontop of that. Youll prob have to reinstall the skin also as for some reason the RRinstaller deletes any previous skins. The installer also comes with the BMV2 skin but for some reason the default skin is alpine which isnt included. But it definately sounds like a RR problem as you shouldnt have to delete resume.ini everytime u load RR. Could be a bad setting in rr.ini also, ive had not to great experiences in the past using any rrconfig not made by guino.
mp3car live search
