Thread: Lsx Void 3.0
  1. #1871
    Low Bitrate TxAxZxZ's Avatar
    Dec 2005
    Ft. Walton Beach, FL
    AVS Spectrum Analyzers for Void 3
    Was here playing with the AVSs in winamp and made a few spectrum analyzers to match LS Void 3 themes. Check them out...
    I made the background black so you could see the AVS better
    EDIT: I made two more types, Wide and glow for each theme
    Jeeputer Project
    - Design <<< 100% >>>
    - Construction <<< 99.5% >>>
  2. #1872
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by MrTrunks View Post
    OK, winamp 5.13 installed. I'll give it a go
    Is there an "onexit" command to execute batch files upon RR closing? I want to added script to check for winamp and if open, end the task. Thanks again
    the ONEXIT command will be added to the newest release. Its something i sent to guino last week. It will defined just like all the other "ON" events in exectbl.ini.
    Live mp3Car Facebook Chat
  3. #1873
    Newbie BReMFoX's Avatar
    Dec 2007
    The Netherlands
    Quote Originally Posted by liquid_smoke View Post
    Didnt get around to the freephone thingy past weekend, i pretty much forgot about it.
    I will take a look at it very soon though
    Cool, thnx.
    Don't rush yourself, i can see you're busy
    One little bug i found....at least, i think it's a bug...
    When playing MP3's in the Main Skin i started up the visuals.
    I went to the Audio Skin to select some other music.
    The Visuals are off now.
    Then when i go back to the Main Skin the visuals are still off......
    But when i change volume, press next or some other button that doesn't change the Skin the visuals appear again...
    Why is this?
    | Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
  4. #1874
    Newbie superman_sean's Avatar
    Jan 2006
    Oklahoma
    Screenlock issue
    I have also posted this in the plug in form, just in case its a plug in issue and not a skin issue.
    I have the screenlock appear on startup, but once I unlock and then try lock the screen, RR freezes. tried this on both my test machine and my car pc.
    Any ideas ???
  5. #1875
    Jdi
    Jdi is offline
    Aug 2007
    Help plaese!! (sorry but my english is not good)
    I cannot select LSX VOID 3 skin! When I select it, RR blocks!!! What is my problem?
    With the other skins no problem...
    I downloaded it in the link of the first page (.exe file) and installed in the directory of RR...
  6. #1876
    Dec 2007
    The Netherlands
    Quote Originally Posted by Jdi View Post
    Maybe re-installing the skin helps?
  7. #1877
    Jul 2006
    please post details of your system configuration, the version of RR you are using, and a post from your debug file. when exactly does it freeze? you'll have to provide more details.
  8. #1878
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Without more info, I'd say you are probably running an older version of RR. Download the newest version from Guino's site. It should be the 12/06/2007 file. Just unzip the binary file to the RR directory.
    If you are using an older version, void 3.2 will lock up the computer just after it starts loading, causing pretty much what you are describing.
    Cheers
    Leonardo Da Vinci
  9. #1879
    Jdi
    Jdi is offline
    Aug 2007
    Quote Originally Posted by greatwhite View Post
    Cheers
    I will try update to the last version of RR...
    I will comment the result!
    Thank's!
  10. #1880
    Nov 2004
    St Louis
    Quote Originally Posted by Sonicxtacy02 View Post
    you do know that weather is now based on your current gps position right? i added this with the localdatacapture option. Unless you wanted to know what the weather is like in one city while you're in another this would serve no purpose.
    But I do. When preparing for my monthly trip to Chicago or Memphis, I like to check the weather ahead of time. The press and hold feature allowing me to change a city was a god-send when I volunteered to drive my sisters to New Orleans for our last cruise cause I was the only one who knew it was going to rain and I made them bring rain gear (all they were thinking about were their bikinis in Jamaica).
    Just today, I realized he's using the GPS based weather, but an option to pick a city is just another of those options we CarPC users can take advantage of. Hell, my personal skin has over 30 radar jpgs and 8 animated radar screens and it saved me from three tornadoes (including the one that destroyed my home in OKC in 99), two ice storms, and one blizzard.
    I take weather forecasts very seriously when I travel. I even had my tablet with me in Hawaii last year and instead of being caught in the freak hurricane there the last three days of my vacation, I was off to Japan. Chuck came up with the original jpg-based RR Code for 6 weather jpgs on a page and I just kept expanding that till I had the majority of my travel destinations covered. But adding realtime animated weather was the real lifesaver. I can see storms around me, plot their movement against my own, and then decide if my needs outweigh the risks.
    The guys at the Chicago MP3Car meet thought it was overkill, too, until I explained to them the different ways its used and with full time internet my animated radar is updated every 5 minutes. I used to show them storm heading across Illinois and say I'll wait another hour so I'll miss the worst of it or leave the meet early to avoid being snowed in with them. Anytime you drive more than 4 hours, an option to see the weather at your destination comes in very handy.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
