Thread: Lsx Void 3.0
  1. #1931
    Newbie MrTrunks's Avatar
    Sep 2007
    Arizona
    Quote Originally Posted by greatwhite View Post
    Well, been running 3 days in the car now.
    No issues. Running great!
    Thanks LS, fantastic release. had some troubles early on, but it was mostly all on my end.
    3.2 is, without a doubt, the best looking skin out there. And your level of support on it is commendable.
    Well done!
    Cheers
    I'm still working on mine... XP is installed, I'm installing my other stuff right now. I'll keep you posted
  2. #1932
    Sep 2007
    Arizona
    Quote Originally Posted by liquid_smoke View Post
    yes, this is something i forgot to mention also. Sometimes just having 3rd party remote software installed it will screw with things. I had the same problem with other software failing to run because of a mirror display driver that was turning off my hardware acceleration. Unfortunately this sucks big time if you ask me as using remote software to administer the carpc in my book is a requirement.
    also to those who have tried everything and are about to reinstall xp because of the direct x init error, personally i would NOT do this. There is likely nothing wrong with your directx install or your OS. Run dxdiag (start>run>dxdiag) and if your system passes all the test, then your setup is fine. This is an issue with RoadRunner. There is nothing i can change inside the skin that will fix the direct x init error except for removing the ilist from the skin completely, which is what i think im going to do. There are just far to many people having issues or unable to run the skin because of the ilist. So there will be another version of the skin that does not use it at all.
    LS, you were right! Even after I installed XP and set everything up. RR+LSX was still freezing when I clicked the Audio button. I was never getting the dxinit problem. I uninstalled my remote software (Radmin3), restarted and voila, LSX Audio button works now!
    I am however experiencing a new problem....When LSX starts up and I have the GPS com port set correctly RR will freeze but if I have the com port of my GPS set incorrectly, I start RR/LSX and then enable my com port using Xport, RR/LSX works fine and display my speed fine.
    My question is this: Is there a way I can set a delay on the initialization of the GPS until the skin has fully loaded by maybe like 5 seconds?
    Thanks again
  3. #1933
    Dec 2007
    Boulder, CO
    Just downloaded LSX 3.2. It appeared as an LSX 3.0 icon on my computer but installed 3.2 (according to the installer) in a LSX 3.0 folder in my skins folder. I used the RR config app to select this skin but when I boot RR it tells me there is not a valid skin in the folder the LSX installer created....?
  4. #1934
    Newbie BReMFoX's Avatar
    Dec 2007
    The Netherlands
    Well done!
    Cheers
    | Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
  5. #1935
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    Did anyone ever get a fix for the problem with appended songs not being there after hibernate?
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  6. #1936
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by CARLOS_CET View Post
    Sorry, I don't use hibernate...........
    Leonardo Da Vinci
  7. #1937
    Dec 2007
    Boulder, CO
    Can anyone help? I realy want to check this skin out but everytime I install/try to use it RR tells me there is not a valid skin in the LSX folder created by the installer...
  8. #1938
    Aug 2004
    NH
    Quote Originally Posted by booksix View Post
    What version of RR are you running?
    What OS are you running?
    Where is RR installed?
    Where did you install LSXVOID?
    Car PC Progress
  9. #1939
    Aug 2007
    I seem to be having a problem getting the Spectrum Analyzers to work like I want. I am using Winamp V5.13. Is this the best or right one to be using. I am trying to get it to show up on the first screen in the flash area I guest you would call it. I have seen this on screen shots he but just can't seem to get it working. It work fine in th Audio window. Thanks for any help.
  10. #1940
    Dec 2007
    Boulder, CO
    ok, bear with me... Haven't been on windows in years...
    I'm testing front ends/skins on a friends compaq laptop rnning XP pro. RR is the latest version, installed in the default location (I find it in program files) and the skin is installed in the skins folder (defaulted by the lsx installer)
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
