Just to be certain, you installed RR and than placed the updated binaries in the RR directory.
What's the process that you do to select the LSXVOID skin?
Printable View
RR directory being that rr.ini file? I don't think I had any updates for it... Idk...? I use the rr config app to change skins...
When you install RR, that installs an older version of RR. Than you have to download the binary files and place them in the C:/program files/road runner (or whatever the default install directory for Road Runner is). Did you do that? When you startup Road Runner, it has the date on the splash screen.
ok, thanks .. I'll check it out.
Why don't they just include the new binaries in the lastest installer?
I have also posted this in the plug in form, just in case its a plug in issue and not a skin issue, but I have not yet received any responses.
I have the screenlock appear on startup, but once I unlock and then try lock the screen, RR freezes. tried this on both my test machine and my car pc.
Any ideas ???
yeah, I'm sure it'll be cake... I was just curious... Thanks!
