Have you tried any other skins? If not, can you try another skin and see if you get the same problem.
10/7/05 is the date on the RR splash screen. I updated the binaries.. same problem...
Car PC Progress
(>>>>>>>>>>>>---) 90%
"Don't speak about it, be about it"
nm, did a series of unistall/reinstalls and got it working. Now I just need a faster test computer!
Car PC Progress
Anyone know how to delay the GPS init in RR/LSX?
EDIT:
I figured out why my RR/LSX was hanging....in the GPS tab in RRConfig, I had use GPSserv and get zip code data from mapmonkey! I'm using iGuidance. After I unchecked those 2 options, RR/LSX starts up fine.(maybe this will help those who did the same thing I did)
Can anyone tell me how to change the logo in LSXVOID 3.2
i am also getting the error of no skin file found in the directory. only way i can get it to work is to install 3.0 and then 3.2 over it. if i install 3.2 fresh it doesnt work for me. is the main link for 3.2 a different version now than what was originally posted. i am also getting horizontal white lines in between each of my menu items. is this normal? finally i dont have ilists on the main menu by default. were the menu files altered in the installation package? i was under the impression that it worked with rr 12-6 or later.
Hey Guys, exists any reason to see the LSX Void 3.0 in Road Runner in this way?
I can't figure it out why i'm seeing just a little and black bar on my screen.
Disgregard the background, that face is my san.
Check this post.... http://www.mp3car.com/vbulletin/1153240-post1909.html
Car PC Progress
Hey all
I noticed that on the main screen the first row or two of pixels on the list gets cut off ? I thought it was just my install so I built several VM's and they all end up the same way. Has anyone seen this before and what do I need to do to fix it ?
thanks!
