Thread: Lsx Void 3.0
  1. #1961
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by montgomeryt View Post
    Hey all
    I noticed that on the main screen the first row or two of pixels on the list gets cut off ? I thought it was just my install so I built several VM's and they all end up the same way. Has anyone seen this before and what do I need to do to fix it ?
    thanks!
    Mine too. Always has.
    RR bug I beleive.......
    Leonardo Da Vinci
  2. #1962
    May 2007
    Quote Originally Posted by kasperuza View Post
    Hey Guys, exists any reason to see the LSX Void 3.0 in Road Runner in this way?
    I can't figure it out why i'm seeing just a little and black bar on my screen.
    Disgregard the background, that face is my san.
    enable gdi+ in config.
    Leonardo Da Vinci
  3. #1963
    Jul 2006
    Quote Originally Posted by greatwhite View Post
    and make sure the .dll is registered by opening up a command window, navigating to your rr directory, like c:\progra~1\roadru~1 and type regsvr32 GDIPlusWrapper.dll
    i donno if the install automatically does it...
  4. #1964
    Feb 2007
    car logo
    How do i change the car logo. I now have the VW logo and would like to change it to the Jeep logo. how do i do this.
  5. #1965
    Newbie MrTrunks's Avatar
    Sep 2007
    Arizona
    Quote Originally Posted by daryldc1991 View Post
    go here: http://download.andgear.com/rr/skins...cks/index.html
    download the one u want and extract it to your road runner/skins/LSX VOID 3.0 folder.
  6. #1966
    Low Bitrate Maddominican's Avatar
    Jan 2007
    Hispaniola
    Daaammmnnn!!! I just used this skin an is off the chain! everything you want, nothing you don't. I'venn stuck with 2 other skins and they don't have the functionality of this one; maybe except the PhoCo, creating a playlist and the logo in the center of the main screen. Since this is my first foray into this skin, I believe that I'll eventually find a way to ge to those.
  7. #1967
    Feb 2007
    Quote Originally Posted by MrTrunks View Post
    thanks
  8. #1968
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Well, been running 3 days in the car now.
    No issues. Running great!
    Thanks LS, fantastic release. had some troubles early on, but it was mostly all on my end.
    3.2 is, without a doubt, the best looking skin out there. And your level of support on it is commendable.
    Well done!
    Cheers
    THANKS!!
    LS, you were right! Even after I installed XP and set everything up. RR+LSX was still freezing when I clicked the Audio button. I was never getting the dxinit problem. I uninstalled my remote software (Radmin3), restarted and voila, LSX Audio button works now!
    I am however experiencing a new problem....When LSX starts up and I have the GPS com port set correctly RR will freeze but if I have the com port of my GPS set incorrectly, I start RR/LSX and then enable my com port using Xport, RR/LSX works fine and display my speed fine.
    My question is this: Is there a way I can set a delay on the initialization of the GPS until the skin has fully loaded by maybe like 5 seconds?
    Thanks again
    not that i know of, i could make a work around for you though, what is ur com port #. But i think the problem may be localdatacapture feature in RR. Do this as a test.
    Open ExecTBL.ini and find this line
    "LSONSKINSTART","ratecheck2||locate"
    make it look like this
    "LSONSKINSTART","ratecheck2||"
    this will set RR to not automatically try to locate your position from zips.dat until after a minute has passed or whatever value you have set for localdatacapture=# in rr.ini
    This feature only affects the city display on the main menu and i believe maybe auto weather update based on zip. So if u completely turn it off its not a biggie and wont screw with other things much.
    Let me know what happens
    Quote Originally Posted by booksix View Post
    Just downloaded LSX 3.2. It appeared as an LSX 3.0 icon on my computer but installed 3.2 (according to the installer) in a LSX 3.0 folder in my skins folder. I used the RR config app to select this skin but when I boot RR it tells me there is not a valid skin in the folder the LSX installer created....?
    make sure you RR install is the very latest.
    The installer does NOT install the latest version, but is needed to setup dll and stuff properly. Download the latest version of RR binaries from here
    http://guino.home.insightbb.com/download.html
    and copy them ontop of your install.
    also make sure resume.ini does not have a bogus path in it. You can delete the file and RR will create a new one with proper info after a successful load.
    Quote Originally Posted by CARLOS_CET View Post
    Did anyone ever get a fix for the problem with appended songs not being there after hibernate?
    pretty sure this is an RR issue. You should post it in the bug tracker so guino knows about it.
    Quote Originally Posted by mnickolson View Post
    I seem to be having a problem getting the Spectrum Analyzers to work like I want. I am using Winamp V5.13. Is this the best or right one to be using. I am trying to get it to show up on the first screen in the flash area I guest you would call it. I have seen this on screen shots he but just can't seem to get it working. It work fine in th Audio window. Thanks for any help.
    5.13 is the correct version, do not update to any version higher.
    make sure you have chosen a main menu layout that supports a visual. I believe they all do though, so never mind that. There is no flash area so not sure about that.
    Sine its working in the audio screen all the other stuff seems setup right.
    There are some bugs in RR right now with visuals though, so i wouldnt spend too much time screwing with it at all now to be honest. Have you hand edited the menu.skin file at all previously?
    Quote Originally Posted by superman_sean View Post
    I have also posted this in the plug in form, just in case its a plug in issue and not a skin issue, but I have not yet received any responses.
    I have the screenlock appear on startup, but once I unlock and then try lock the screen, RR freezes. tried this on both my test machine and my car pc.
    Any ideas ???
    will do some testing, but i believe this is a bug in the screenlock plugin. RR just crashed on me when i tried to lock twice back to back, so ill do a little digging and isolate it. If it its indeed a bug in the screenlock, it will be replaced asap. I may even just write one myself that does a bit more like password protect specific sections of the skin etc.
    beer replenishment fund
    mp3car live search
  9. #1969
    Aug 2003
    Chicago
    Quote Originally Posted by hari-bhari View Post
    i am also getting the error of no skin file found in the directory. only way i can get it to work is to install 3.0 and then 3.2 over it. if i install 3.2 fresh it doesnt work for me. is the main link for 3.2 a different version now than what was originally posted. i am also getting horizontal white lines in between each of my menu items. is this normal? finally i dont have ilists on the main menu by default. were the menu files altered in the installation package? i was under the impression that it worked with rr 12-6 or later.
    ilist were disabled in the install package, but the current download should have the enabled. Ill download it tonite and double check.
    what menu items have white lines? screenshot?
    have to enable GDI+ in rr.ini
    fastmode=-1
    Quote Originally Posted by Maddominican View Post
    all three of those things are possible in the skin.
    To use phoco, since it sounds like u already have it setup in rr.ini etc, just click and hold on any button on the main menu, and choose PHOCO.
    for a logo in the center of the screen,
    OPT>VIS & LOGO> pick a layout that has a logo the default is a VW logo. There is a link a few post back to all the logos made for this skin.
    to save a playlist,
    Load any music and go
    LIBRARY>PLAYLIST>SAVE and type a new name for the playlist.
    mp3car live search
  10. #1970
    Jul 2006
    i just redownloaded the newest package and i think all the problems have been solved. i think in a previous build something was missing because my installation kept stopping due to a missing file in the color picker i beleive, and then the skin wouldnt load. all is working fine now though, white lines are gone, and i just reinstalled everything and it works great including with ig4 which i just tried for the first time (i hope autosw and stuff still works with the new version though!!) thanks ls!! :-)
    i will double check tomorrow, but as far as i could tell the main menu didn't have ilists, and i did try a couple of different layouts...someone please correct me if im wrong.
    on another note, what's everyone use for monitoring wifi and are there any decent plugins or programs (i saw one in the plugins thread but i donno how to integrate it, and plus it doesnt match)? same thing with file syncing over a network, what works best in this skin?
    also, this is more of a RR question, but does the rr library update automatically if i add a file while rr is running? in other words if i copy a file off my jump drive using xplorrer and then goto library, will it be there? last time i tried, it wasnt, but maybe i jus didnt look hard enough. what about the winamp media library? you can have a certain folder monitored but i dont know when it gets chceked. ill probably end up answering my own question,lol.
    i swear this skin needs its own subforum, hahaha. ok bed time
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 01:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 12:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 09:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 01:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 07:00 AM
