Thread: Lsx Void 3.0
  1. #1981
    Jul 2006
    is there currently any way to search for a song by its title? i.e. if the song is named 'good morning', is there any search feature where i can type part of the name and itll bring me a list of songs containing the text. someone pleaaaaaaase enlighten me.
  2. #1982
    Mar 2004
    Quote Originally Posted by montgomeryt View Post
    For the past day my RR started to crash when loading 3.2. When I look at the report it wants to send to Bill Gates it says Roadrunner.exe crashed on zipcodefinder.dll (I believe that's the correct name). If I disable my XPort the skin loads fine but obviously no GPS. Any one Anyone ?
    I have the exact same problem but, I've asked several questions and am having a hard time getting any answers in here.
    I did the same thing as you, tough. I turned off the GPS functionality in RR but still have iGuidance running. I don't think XPort has anything to do with it. I think its the option where it shows you what city you are in (which is always usually 20mi off for me for some reason anyway so its pretty useless) on the main screen or it has something to do with the fuel finder. My RR is running but I have no speed or compass in RR because its all disabled.
  3. #1983
    Newbie MrTrunks's Avatar
    Sep 2007
    Arizona
    Quote Originally Posted by liquid_smoke View Post
    THANKS!!
    not that i know of, i could make a work around for you though, what is ur com port #. But i think the problem may be localdatacapture feature in RR. Do this as a test.
    Open ExecTBL.ini and find this line
    "LSONSKINSTART","ratecheck2||locate"
    make it look like this
    "LSONSKINSTART","ratecheck2||"
    this will set RR to not automatically try to locate your position from zips.dat until after a minute has passed or whatever value you have set for localdatacapture=# in rr.ini
    This feature only affects the city display on the main menu and i believe maybe auto weather update based on zip. So if u completely turn it off its not a biggie and wont screw with other things much.
    Let me know what happens
    My exectbl was empty besides like 5 lines that didnt look like they did anything anways...I used the exectbl.ini that you posted for the muted preset bug in its place and removed the locate like you said.
    I'm using com port 5. I also checked my rr.ini and localdatacapture is set to 0. I am guessing that this means disabled. I'll let you know what happens tomorrow.
    Thank LS
    EDIT:
    I just noticed there is an exectbl.ini in the road runner root folder and also in the lsx skn folder....Which one is being used? Should I delete one of them?
    EDIT 2:
    I couldn't wait...I went out to my truck and tried what you said. By removing locate from the exectbl.ini, this fixed the problem, I am able to exit and then open RR again and it starts fine whereas before when I exited and tried to start RR it froze at the locate command!
    Do you plan on making the locate command on initial start to be an option to be turned on and off in setup? I'm not sure if others had this same problem as me but having a toggle button is much easier and also having it set to off by defaulted lsx install. This all make sense? Thanks LS!
  4. #1984
    Newbie hugenius79's Avatar
    May 2006
    New York
    Delete ziplocator.dll inside RR folder...
  5. #1985
    Dec 2007
    ok.. searching this thread, i think i found a solution to one of my own problems.. Running Korean version xp was the problem... I hope that will fix my other problem too.... only buttons that seem to be working now are side arrow buttons to toggle the different menu view.... None of the buttons are responding to my clicks.
  6. #1986
    Jul 2006
    Quote Originally Posted by hugenius79 View Post
    But isn't this DLL needed for find location for things like the Gas finder and so on ?
  7. #1987
    Aug 2007
    Can someone tell me were the 2 presets are stored to get the band button to work. I have tried and tried and am to the point of just giving up. I got to thinking if I knew were it was stored I could just put them in I think.
  8. #1988
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by mnickolson View Post
    http://www.mp3car.com/vbulletin/rr-s...-download.html
    The jpg showing the exact location of the buttons is in the download. It should already be in your hd folder in void.
    Noticed the same problem with xport and rr today while setting up the speed and direction arrow in void. Thanks, I'll give it a try.
    Leonardo Da Vinci
  9. #1989
    Dec 2007
    man.. i love all these skins.... can't make up my mind which one to go with... I guess i am just gonna rotate the skins every week.. ^^ by the way.. setting everyting to all English solved my problems.. Thanks..
  10. #1990
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by MrTrunks View Post
    Thank LS
    EDIT:
    EDIT 2:
    what i figured, seems the locate bug is still around. Ill talk to guino about it.
    There are 2 Exectbl.ini files. One is local and one is global.
    The local one is the one that comes with a skin, so all code that is in the local version will only work with that skin. The global one (inside RR root) works across all skins.
    It is safe to delete the global file, only if you havnt edited it with your own stuff.
    It is NOT safe to delete the local version. Its the glue that binds RR, my skin and my custom code together in a happy 3 way action.
    in light of the locate issues lingering around, i think i will set it up as an option that can be turned on/off and off by default.
    If your location is off by 20 miles or so, you need to update your zips.dat file with more recent data. There is a thread around here somewhere with links to newer versions of this file.
    i dont think that dll is needed by RoadRunner for a while now. I do not have it and everything still works.
    Quote Originally Posted by hari-bhari View Post
    YES AND NO
    The code for searching is there, but the button is not visible to the user. If you disable ilist on the audio_browser.skin you will see the search button.
    It was not intentional to remove the search feature from being accessed, but as it is now there is no way to search for anything. What i think ill do is post a new audio_browser.skin file that will split the playlist button in half and put search on the right side of that button. I may do this in the next 5 min or so, so look below or on the first page for the link.
    Quote Originally Posted by bobbykokinos View Post
    see above
    band button?
    beer replenishment fund
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
