Thread: Lsx Void 3.0
  1. #2041
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by BReMFoX View Post
    Any luck with the bluetooth-driver issues?
    Have you got any news about the freefone integration?
    Maybe you could tell in a quick way how to embed freefone the right way?
    I have no clue where to start...
    Am i asking too much?
    ill post something tonite, blutetooth issues are cleared
    Quote Originally Posted by lowis View Post
    Hi @ all ..first: realy a great skin. so many work u have dons LS ... THX
    my question is : how can i edit the recording path for "notes" ? i get an error that the path is not found for the recording file .. this could be a great feature for "option>mediapath>notesrecordings
    greetz lowis
    small oversight. Ill prob have to setup something like what you suggested. For now, create a folder in the root of your music path named this -{VOICE_RECORDINGS}- with the dashes etc. See if that fixes the no path. Ill take a look at the code for this feature and step through it and see how the paths are setup, i wrote this a very long time ago. I know that it tries to save the audio file based on the date.
    Quote Originally Posted by Charly View Post
    Thanks for your reply LS here's a pic of how the embedding looks like there is not bottom menu for the skin. and if that is the case I rather have the app full screen so the album covers show up a little bigger.
    what is that app that you are embeding? It looks like its embeding fine but seems like the application may be fighting to be resized to the area RR wants it. What is the smallest space you can resize that app to? Does it prevent you from resizeing it to really low.
    Also, just curious cuz that app looks like a media player. Just seems odd to embed a media player into a media player.
    Quote Originally Posted by AllThingsEnd View Post
    wow that helped thanks alot. now that i finally have the newest version working now i have a few little problems. now whenever i open rr or play a song my volume goes back to 0%. it wasnt doing that before with the previous versions. and with the ilist at the end of the playlist or the browse section i get a pink line separating the last item and the first item. why is that? thanks in advance
    for the pink line, make sure you have regestered all the proper .dll files that RR needs. This should of been done with the RR installer. Also, check in RR.ini and make sure you have
    fastmode=-1
    Ill post my rr.ini file a little later that people can use as reference or even as a starting point.
    Quote Originally Posted by Iceman_jkh View Post
    Any way to put a space or some kind of visual separator between different albums/directories in the playlist view?
    Any way to make the ilist continuously scroll? Horizontal swipe (like in coverflow) or something, so that it slowly scrolls continuously until find the song title and press it or FF/RWD/PLAY.
    there is a space/separator on all list at the end of the list. There is no grouping within a list for separate albums (that would be cool though), this can (and should) be requested as a feature or RR to guino.
    The list can continuously scroll, by setting CircularList=true in RR.ini although it will eventually stop.
    Quote Originally Posted by TeamRSX View Post
    I have got freefone to work with lsx void as an external applications which i did by holding down one of the buttons on the main window then i picked a empty button to set a command for freefone.
    I have attached a jpg of what is happening, freefone is loading, but not embeding into lsx void and it keeps asking me to 'Click Setup button to set application to embed." I have already done this, but its not embeding or is this how its supostue work?
    Here is what i put to embed the application:
    Application Name: FreeFone
    Path to Application: C:\Program Files\Road Runner\Skins\LSXVOID\FreeFone.exe
    Window Name: ;FreeFone (is there something else i should be putting here??)
    Also, here is the contents of my freefone.skin file:
    MEDIACAR Skin
    MEDIACAR "FreeFone" Skin
    I,0,0,0,0,"ONLINE"
    I,0,0,0,0,"MASTERMUTE"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,10,3,100,25,255,255,255,15,"Arial Narrow:B","TIME","Time"
    L03,231,10,0,0,255,245,000,22,"Tahoma:B","TRACKNAM E","scroll-center"
    L06,710,40,0,0,128,255,128,18,"Arial Narrow:B","CUSTOMFREEFONE", ""
    L,0,0,0,0,0,0,0,0,"Arial Narrow:B","TRACKNAME","SCROLL-CENTER"
    L,0,0,0,0,0,0,0,0,"arial","VOLUME","CENTER"
    L,0,0,0,0,0,0,0,0,"arial","DATE","RIGHT"
    L,0,0,0,0,0,0,0,0,"arial","TIME","CENTER"
    L,0,0,0,0,0,0,0,0,"arial","STATUS",
    L,0,0,0,0,0,0,0,0,"arial","TRACKNUMBER",
    L,0,0,0,0,0,0,0,0,"arial","LISTTEXT"
    L,0,0,0,0,0,0,0,0,"arial","TAGARTIST",
    L,0,0,0,0,0,0,0,0,"arial","TRACKTIME",
    L,0,0,0,0,0,0,0,0,"arial","ALBUMART",
    L,0,0,0,0,0,0,0,0,"arial","TODAY",
    L,0,0,0,0,0,0,0,0,"arial","PICTURE",
    L,0,0,0,0,0,0,0,0,"arial","GPSSPD",
    L,0,0,0,0,0,0,0,0,"arial","GPSSAT",
    L,0,0,0,0,0,0,0,0,"arial","CUSTOMPL",
    L,0,0,0,0,0,0,0,0,"arial","CUSTOMDL",
    L,0,0,0,0,0,0,0,0,"arial","PLAYLISTCOUNT",
    L,0,0,0,0,0,0,0,0,"arial","COVERART",
    L,0,0,0,0,0,0,0,0,"arial","LISTPOS",
    L,0,0,0,0,0,0,0,0,"arial","CUSTOMCOLOUR",
    L,0,0,0,0,0,0,0,0,"arial","CUSTOMTITLE",
    L,0,0,0,0,0,0,0,0,"arial","RRSCREEN",
    L,0,0,0,0,0,0,0,0,"arial","TAGALBUM",
    L,0,0,0,0,0,0,0,0,"arial","KBPS",
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B,734,505,65,91,"NEXT",
    B,668,503,65,95,"PLAY",
    /, A, x, y, w, h, color R;RGB, G, B
    A01,20,100,760,298,000,000,000
    /, F, x, y, w, h, Movie name
    F3,0,0,800,100,"top.swf",SOLID
    F2,0,398,800,82,"bottom.swf",SOLID
    END
    Any help would be appreciated.
    will be looking into FreeFone when soon as i click the submit button .
    beer replenishment fund
    mp3car live search
  2. #2042
    Aug 2003
    Chicago
    ENABLE FreeFone
    extract the attatched files into the skin, overwrite any files present.
    you do not have to download FreeFone its included
    edit settings.ini and put in your com port# for your phone
    Use the existing "PHONE" button to load FreeFone
    If you do not see a "PHONE" button, click and hold any button on the main menu, or secondary main menu's (left right arrow buttons) and choose "PHOCO" from the list.
    DONE.
    This update will DISABLE PhoneControl.net If you use PhoneControl.net do not apply this update.
    Note: If you have made custom edits to ExecTBL.ini in the skin folder, this will overwrite your changes. If you want to preserve your custom edits, do not overwrite this file. Instead add this line to the end of the file.
    /,------------------FREEFONE---------------------
    "PHOCO","LOAD;freefone.skin;FreeFone;$skinpath$Fre eFone.EXE;FreeFone"
    if you have not made any custom edits, this step is not necessary.
    note2: for future reference
    until a new full update is posted this update should be applied last, unless a newer update is posted in which case the newer update should be applied after this one.
    download updated 1/3/2008
    fixed incoming/outgoing calls screen.
    mp3car live search
  3. #2043
    Aug 2003
    Chicago
    forgot to add the second file, if you downloaded the enable_freefone update already, grab the second file in the post above this one and put the phonepics folder in the skins folder
    mp3car live search
  4. #2044
    Variable Bitrate AllThingsEnd's Avatar
    Jan 2006
    Ft. Bliss, TX
    i just checked my rr.ini and fastmode=-1 but i am still getting that pink line. what .dll am i supposed to register? i didnt register any before this newest one.
    [::::::::::] 100% - Planning
    [::::::::::] 80% - Computer
    [::::::::::] 0% - Fabbing
    CarPC:
    SP13000 / 120GB SATA 2.5" / 512MB DDR
    8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
    Slot load DVDRW / PS3 Wireless Keyboard
  5. #2045
    Newbie BReMFoX's Avatar
    Dec 2007
    The Netherlands
    Thnx LS!
    Freefone works great now!
    Is it possible to place the incoming and outgoing calls skin in front of the normal skin.
    Now road runner minimizes and i can see parts of my ugly desktop, because the skin is not on the whole screen...
    Can Freefone be auto started when the skin loads? Now you have to click on PHONE to enable freefone.
    Can images only be used when using the phonebook.txt?
    | Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
  6. #2046
    Aug 2003
    Chicago
    Thnx LS!
    not sure i understand what you mean by placing the calls skin in front of the normal skin?
    why does RR minimize? Is this being done by FreeFone on a incoming call?
    im sure it can be autostarted in a hidden state, ill look into it.
    what images are you speaking of?
    mp3car live search
  7. #2047
    Aug 2003
    Chicago
    i believe the dll is GDIPlusWrapper.dll im sure its allready registered though.
    I think there is a different line in rr.ini to check sorry for the last one i said to check.
    Check this.... wait that may not work either but try it anyway
    enableclipping=true
    i just turned it off on my end and I didnt notice any pink lines, but i did just find a fix for a vista issue
    ive seen this happen before though, just cant fully remember the resolution. I know its related to ilist and also related to older code (clipping) The dlls for all the new fancy features in RR are GDIPlusWrapper.dll and dx7vb.dll the latter should allready be present on your machine if your using XP, if your using vista the file is not included with the OS but it comes with the skin so you should have it no matter what.
    Ill try to break it on my end so i can remember what the fix is, in the meantime give the above a try.
    EDIT:
    just found this thread, Pink Ilist,,, BAD
    mp3car live search
  8. #2048
    Dec 2007
    The Netherlands
    Quote Originally Posted by liquid_smoke View Post
    First of all Happy New Year!
    When i have an incoming or outgoing call, the music pauses, RR minimizes and the fonecall.skin appears.
    This skin is now in front of my desktop and not full screen.
    I don't know if thats the way it has to work, but i think it's nicer if this fonecall.skin appears in front of RR if possible?
    About the images.
    I meant the images in the phonepics folder.
    If they can be used with only phonebook.txt or also with the phonebook from my mobile phone.
    But i think i have the answer now, they can be used with both phonebooks, but the name of the image has to be exact the same as the number.
    I'll search for it some more, because it's not really the thread for this issue.
  9. #2049
    Aug 2003
    Chicago
    About the images.
    ok, i understand, FreeFone must be hard coded to use Load; instead of Menu; for the incoming & outgoing call. RR isnt actually minimizeing though, the screen its calling was designed as a popup screen, but FreeFone is calling it a different way. Ill just have to redesign the screen is all. No biggie. Ill post a update for it later tonite.
    mp3car live search
  10. #2050
    Constant Bitrate digeratix's Avatar
    Sep 2007
    Im the image, you will notice that the song is chopped off at the top. How do I edit to fix this?
    Also the song thats playing, its not in BOLD. (which is number 2)
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
