Thread: Lsx Void 3.0
  1. #2051
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Happy new year all.
    LS,
    I have a request for the gps screen. Would it be possible to have the screen in the first option (audio player on the bottom, IG embedded) with only a simple full screen button in the upper LH corner and no fly out menu?
    The fly out menu functionality is very nice, but most of the functions I need can be reached through the "menu" button in the program, except for full screen. The Upper LH corner would be best for the fullscreen arrow button as there is nothing in that quadrant right now. The "directional arrow" resides in the upper rh quadrant where the fullscreen button is in the current program.
    Thanks.
    Leonardo Da Vinci
  2. #2052
    Jul 2006
    Quote Originally Posted by digeratix View Post
    Im the image, you will notice that the song is chopped off at the top. How do I edit to fix this?
    Also the song thats playing, its not in BOLD. (which is number 2)
    The top being cut off is an RR issue according to LS. also i don't think the playing song is in bold, its just in the center
  3. #2053
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    what image?
    eitherway, the chopped off top is an issue in RR.
    songs also are not in bold and there is no setting for this when using ilist, but there maybe something i do with the colors that will make the current playing song stand out more even when the selection bar is focused on something else.
    Quote Originally Posted by greatwhite View Post
    Happy new year all.
    LS,
    Thanks.
    the fullscreen button in the right corner is there and not on the left because when you have a route set, the next turn direction arrow is on the top left corner as well as distance to the turn. I sacrificed slightly covering up the heading arrow on the right as i deemed it slightly less important than the next turn and there are also heading arrows (currently broken in latest RR) on all of the other screens in RR. But... the location of the button is editable and i believe the location is sent to the button from a command in RR. So you could modify this in your version easily. Ill post what line to edit after dinner, ill have to dig through the code to find it. Also, fyi those buttons can be dragged around the screen. Soon ill add some code that will auto save the position off the button/s so after you move it, it will always start at that position.
    The flyout menu is nearing its expiration date and will likely go away all together and be replaced with something else thats more customizable. Something with a list of commands you could choose from. None of the functions are things that cant be done from the main menu button, they are just shortcuts mainly so you dont have to traverse down 3-4 menus deep to get to things.
    There will be a lot of work done to the GPS support, specificly a lot of ripping out and redoing and such. There are a lot of scripts that are redundant and or have multiple versions that do the same thing based on what version of gps software you are using.
    I need to simplify everything thats going on with GPS, even if it means dropping default support for some gps apps like freedrive etc and provide them as add ons, cuz im almost certain that most people use IG with this skin. And also remove special code for older versions of IG, most should have upgraded to IG4 by now. There will also be a IG4 mod coming soon too.
    so there will a lot of changes under the hood to all things gps related in the near future.
    beer replenishment fund
    mp3car live search
  4. #2054
    Aug 2003
    Chicago
    FreeFone update
    updated the links for the freefone intergration. Check the link on the first post to update.
    Everything is included in one file now, also if you are updating the only file you need copy over after you unzip is Fonecall.skin all other files are the same.
    mp3car live search
  5. #2055
    Aug 2003
    Chicago
    i can see your image now, i see the list on your screen is not an ilist. I still havnt gotten around to double checking the available download but by default they should be ilist now. Im assuming they arent though, ive been told by default its not but it should be. Using ilist will fix the text cut off i believe, but im not 100% sure.
    Ill try to make sure i post an updated full download this weekend.
    mp3car live search
  6. #2056
    Constant Bitrate digeratix's Avatar
    Sep 2007
    its 3.2 download and it uses ilists everywhere. I was just wondering why the chop off and if there was an edit in a skin somewhere I can make to adjust. Maybe a height somewhere to match the album cover height?
  7. #2057
    Constant Bitrate slvrsol's Avatar
    Mar 2007
    skin editor.. learn it, love it, use it.
  8. #2058
    Newbie Bildonia's Avatar
    Dec 2007
    Illinois
    hey,
    I am having a difficult time figuring out how to autoplay a cd or DVD. I tried editing the autolaunch.ini in the LSXVoid folder but still nothing. It doesnt even attempt to go to the "Video" screen for a DVD or "Audio" for a CD. I have it set so it checks my E: drive which is my cd drive and thats all the farther I get. Can anyone help me out with this??
    1st CarPC
    Plans --> >>>>>>>>><
    Parts --> >>>>>>>><<
    Install -> <<<<<<<<<<
  9. #2059
    Dec 2007
    Sounds cool LS.. Can't wait for gps mod.. ^^ Shortcut is always good, having to press button 3 times while driving is such a pain. I rather have everything on so, i can configure the map easily and go to full screen. Something like gps skin from John's Dfx. Makes life a lot easier that way..
  10. #2060
    Newbie MrTrunks's Avatar
    Sep 2007
    Arizona
    Anyway to preload the gps app (iGuidance) so when I finally click the gps button it loads FAST and I don't have to wait for the app to actually load?
    Thanks!
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
