stick a shortcut in your startup folder.
BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
RRTube ==> [View/Download Youtube Videos]
WifiMan ==> [Wifi Manager]
RRec ==> [Audio Capture]
If You Want To Be Given Everything, Give Everything Up ...
Bird York -- In The Deep --
the chop off is a bug in RR, im not sure what the problem is but no matter what the height is the top line ends up being chopped off a bit. Even when you scroll down, it stops with the top line chopped of a little.
you can resize the list to any size u want and it still chops its off, only on the main menu though, all other list in the skin are fine, so im not really sure what the deal is. Its not related to ilist though as it does the same thing with normal list as well. changing font size does nothing either. Ill send it to guino and see what he says.
I actually just fixed this the other day, i noticed it was somewhat broken on my end. The problem is that when it says that its on its actually off and when its set to off its actually on, the commands and labels are backwards. So.... if you set it to off i think it should turn on for you. I had to tweak a few things on my end but i think i ended up only having to swap the labels around. There will be an update posted this weekend that fixes that and all other previous fixes.
beer replenishment fund
mp3car live search
Lol.... perhaps why I was having so much difficulty with AutoLaunch![]()
im certain![]()
mp3car live search
I just wanted to give my 2 cents ... I fixed the issue with the ilist being chopped off on the main menu by making the currentcity text box smaller in the menu.skin file (changed x position from ~300 to ~600 and reduced the width by 300). The text (even if not being shown) was overlapping the top of the ilist for some reason. Anyway, this worked for me.
how did you get the ilist to show up. mine doesnt say anything in the middle.
[::::::::::] 100% - Planning
[::::::::::] 80% - Computer
[::::::::::] 0% - Fabbing
CarPC:SP13000 / 120GB SATA 2.5" / 512MB DDR
8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
Slot load DVDRW / PS3 Wireless Keyboard
well ill be damned. I must of been smoking too much crack last night when i was trying to figure out why it was doing that. Never thought, hey hack *** the label is clipping the list. Kind of weird though cuz when i was testing i deleted both the labels on the right side and increased the size of the text box multiple times. Cocaine is a helluva drug!
Ill make sure to go through the screens with a fine tooth comb before i post the updates this weekend. Also, fyi the screens that have an ilist on them arent even supposed to have the current city dislplay so thats the real root of the problem. Ill prob make some layout changes so these screens can still use the label at its normal size. The autoswitch on/off label/hidden button on the upper left may have to go the way of the dinos.
Thanks for catching this. Ill try to stay away from the crack while im debugging skins.
mp3car live search
mp3car live search
