I think that prob is the issue also, i never thought all the stuff you loose with tinyxp and nlite type stuff was worth it to shave a few secs. You end up spending more time with compatibility issues.
Here is a rar file with all the fonts i use.
It may even be a good idea to uninstall everything and start over.
I really cant see why the fonts wouldn't install only for you though, even with tinyxp.
Did you download any versions of the skin before the date posted on the last update? In previous versions of the file, there was a button at the end of the install that you had to click to initially setup the
skins default vars. At first this was done automatically, but then i made it a button , then i changed it back to automatic. Is it possible that you skipped this step in setup?
In either case i would recommend downloading the version thats there now, and reinstall it. That goes for anyone who downloaded the skin before the links were taken down. The version number is the same but things are changed and fixed a few bugs, including one crash bug.
