Thread: Lsx Void 3.0
  1. #2231
    Jul 2006
    reinstalling every single time is NOT the proper way to debug. reformat windows, update all your drivers, get a clean install going, and stick with it. make sure u have the latest version of RR (12/13 i beleive). where are u setting the comport for RR? ensure that you are not accidentally setting soemthing else. if you give RR a valid gps comport there is no reason your speed and heading shouldnt work. also please specify what you mean by 'crashing'. what exactly happens? clear out your debug file, launch rr, let it crash, and then post the results
  2. #2232
    Constant Bitrate smp4488's Avatar
    Oct 2007
    Louisville, KY
    Twinsen, to explain you audio problem.... when ever you run winamp by itself when you close it is saves all of the settings such as volume. I had the volume problem too but i ran it alone and changed the settings now it is all good.
    As for your crashing, i am having the same problem. I believe i have narrowed it down to the gps. Its very inconsistent though. Sometimes it works others rr crashes over and over. As a temp fix open iguidance and winamp THEN open rr and see if that works. If you are still crashing start messing with xport. Like i said it is very inconsistent and im trying to figure it out.
  3. #2233
    Jul 2006
    Quote Originally Posted by hari-bhari View Post
    sorry to bump my own question, but any info on this? i looked into the net.kml file and it is empty, as though no data is being entered. this is what is causing the parse error in GE. Is it possible some file is missing from this package? I was looking for anywhere to configure the port or location, etc. but I don't see any rrearth or GEearth ini files anywhere??
    also are we supposed to manuall add the commands into exectbl or something? i know i had it working great on my last computer with void 3.0, im not sure why its not working now.
    EUREKA!! I redownloaded the RRearth files from post 350 of the RRearth thread, found here: Needed: BETA Testers for Google Earth Plugin
    Now it seems to be working.
    @LS: your installation package either does not contain a net.kml.ini file or contains an empty version of the file. Without this ini, the net.kml generated to feed the coordinates to GE is empty. I downloaded the above package, unzipped all the contents into my main RR path, overwriting the current net.kml and net.kml.ini and now it seems to be working (i will test with actual gps tomorrow, but the error is gone). just something you may want to address in your next build.
  4. #2234
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    So, downloading and extracting the files from the above link is all that is required to get GE to work with RR/LSXVoid?
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  5. #2235
    Dec 2007
    hari-bhari, do you cache the map? I tried something called earth google voyager something like that.. Didn't do anything.. Ran it for 6 hours 0% completed and google earth locked up.... Any suggestion, recommendation?
  6. #2236
    Low Bitrate Twinsen's Avatar
    Apr 2006
    Memphis, TN
    I will do a clean reinstall whenever I order my drive, this is more of a "get used to having a CarPC" again with this small 160GB that I have in it now. I do have the latest version. I have set the COM port in RR both in the config, and within the GPS section in RR. Both crash. And by crash, "Windows encountered a problem..." The PC is currently in the car, I may go get it shortly if it isn't raining to post the debug.
  7. #2237
    Jul 2006
    Quote Originally Posted by CARLOS_CET View Post
    Correct. I beleive no net.kml.ini has been included in the void package.
  8. #2238
    Jul 2006
    Quote Originally Posted by brandensin View Post
    yes i do, i forgot the program name. i'll edit this post when i figure it out, check back later.
    edit: google 'ge cacher', i think that's what i used. it has parameters for upper left corner, then the width and the length of the total area you want to cache. also has a parameter for altitude so you can see how high up you want to get, and the width and length of each box u make. you'll have to play with the parameters a bit before you get the altitude to match each step's box size, but you can watch it as it goes along to verify.
    a few pieces of advice:
    -make sure ur cache level is set to 2000mb in GE which is the max if u want the map as much as you want.
    -MAKE SURE that when you copy it over to the carputer you have it set to 2000mb as well, otherwise when you copy the cache file over itll basically wipe out part of the file and the index and ull have to do it over
    -copy over your ge cache AND the index file, the cache file is useless without its index and ull have to start over if u lose it.
    -if you have multiple areas you would like to cache, do it in one run of GE (you can still use the cacher multiple times, but leave GE open) and monitor your cache file to ensure its not exceeding 2000mb or you will wipe out your initial cached area. i found that if you exit in between sometimes, the areas u had before disappear from the index file even though the cache file size still shows as the same. you may also want to just backup the cache and the index file incrementally on the way to be safe in case it gets messed up along the way.
    -make sure in your carpc you have run GE at least once with internet access before you load in your cache file or it wont work.
    hope all this helps
  9. #2239
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Thanks to those who've been helping out answering questions!
    Void doesn't come with the net.kml or net.skm.ini because those files get created by the plugin itself. If you delete them and launch RR, it will recreate them. Sometimes, for no reason i know of, the kml file and or ini file gets screwed up by RR and RREarth wont work right till u delete them and restart it.
    Quote Originally Posted by Twinsen View Post
    xport may just not like your system or gps device or both. I cant run xport on my main machine either because it causes IG4 (but not 3) to crash windows, but i can run it in the car (when i had a carputer). It may seem to work fine with splitting the ports, until u try to connect something to both ports. Unfortunately there isnt another free com port splitter that i know of.
    I suggest setting up RR without xport and test to make sure its not RR causing the crash or xport causing it. I have rarely, if ever seen RR actually cause windows to crash.
    also, turn debugin on in RR via RRConfig and post your debug.txt file.
    also, just curious, your not running a stripped down version of windows by any chance?
    beer replenishment fund
    mp3car live search
  10. #2240
    Aug 2003
    Chicago
    Quote Originally Posted by greatwhite View Post
    HI Smoke:
    i know this has been gone over a couple times and you're not a big fan of it, but...........
    Will there be a daytime skin release for void 3.X or is that a "dead" issue?
    While the dark skin is very pleasing visually, it's just too dark for the daylight and sometimes is completely overpowered by the light. Window tint is not legal around here (wouldn't want it anyways) and there's no other way to lower the ambient light in the cabin. The overall black theme just suppresses too much of the backlight and the result is poor visability on a regular touchscreen LCD. Throw in the natural reflective qualities of the touchscreen overlay and things get worse still.
    I know you don't like the "washed out" appearance of a light skin with black lettering, but it sure would be useful in the day where the black skin often become dim or useless due to ambiant light conditions.
    It's the main feature I miss from 2.02.........
    Cheers
    its not dead, there still will be a day version coming. Time just hasnt been as nice to me as in the past. Lately im finding a hard time to even sit in front of my home pc cause im allways at work.
    x2
    Also, since the Ratings plug-in is no longer supported, is it possible to turn the button in the Audio screen with the 5 on it, to up and down volume buttons like in 2.02? It's difficult to get the volume all the volume button on the bottom right.
    ratings will be supported again in an update.
    as for the volume slider, i dont see that being changed, its on every single screen in the skin. I do think there is something i could do to remove the 5 star button but not the purpose of having it. There are 5 dots on the top that are used to set any song playing to a specific rating as well as display its current rating. I could change it so clicking any dot or star will load the playlist for that rating, and click and hold to set a rating. That way i can remove the 5star button and replace it with something else. Or make it custom like the Navi and BBAA buttons and u can choose what u want it to do.
    Quote Originally Posted by noreason View Post
    I'm having trouble with this skin freezing roadrunner after hitting the audio button. I can use other functions but sometimes hitting the audio button freezes things. The music will still play but i cant do anything. I have to use ctrl alt del to end the task and start rr over. Any ideas?
    you are having direct X errors. Your system either has poor support for direct x via a embeded video card, bad drivers, old DX install, RR not setup properly for GDI+ mode or similar. If you turn on debug mode in RRConfig, it will generate a debug.txt file. Run RR and im pretty sure you will see an error that says, error active x init DX error or something very similar.
    Im working on the skin now to have it setup so u can choose between using ilist or standard non direct X powered lists, for those with direct X issues.
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 01:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 12:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 09:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 01:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 07:00 AM
