Thread: Lsx Void 3.0
  1. #2241
    Jul 2006
    Quote Originally Posted by liquid_smoke View Post
    Void doesn't come with the net.kml or net.skm.ini because those files get created by the plugin itself. If you delete them and launch RR, it will recreate them. Sometimes, for no reason i know of, the kml file and or ini file gets screwed up by RR and RREarth wont work right till u delete them and restart it.
    actually i tried deleting the files and restarting RR several times. it does not work because the files that get regenerated just come up empty. the only way that i could get it working was by downloading the above package, and believe me, i tried every uninstall/reinstall combo possible on two different systems with the exact same results.
    if it wasnt the net.kml and net.kml.ini files that were missing, maybe the dll that generated them got corrupted. but whatever the reason is, they definitely kept coming up empty until i installed the rrearth package. maybe someone can test by deleting their kml and ini files and seeing what happens?
  2. #2242
    Low Bitrate Twinsen's Avatar
    Apr 2006
    Memphis, TN
    Here is my Debug...to get this, I set the COM to 0 in iGuidance and to the proper port, 3 in RR. Still crashes as you can see!
    2/5/2008 9:11:03 AM: Start -- Version: 12/13/2007
    2/5/2008 9:11:04 AM: Master Vol: Volume Control/4
    2/5/2008 9:11:04 AM: GetLineControl Failed: 401
    2/5/2008 9:11:04 AM: No Treble Support
    2/5/2008 9:11:04 AM: No Bass Support
    2/5/2008 9:11:04 AM: No Master ON/OFF
    2/5/2008 9:11:04 AM: Source: Wave=&H1008/1
    2/5/2008 9:11:04 AM: Source: SW Synth=&H1004/2
    2/5/2008 9:11:04 AM: Source: Front=&H100A/3
    2/5/2008 9:11:04 AM: No Mute for Source
    2/5/2008 9:11:04 AM: Source: Subwoofer=&H100A/4
    2/5/2008 9:11:04 AM: Source: Center=&H100A/5
    2/5/2008 9:11:04 AM: Source: Rear=&H100A/6
    2/5/2008 9:11:04 AM: Source: 3D Depth=&H100A/7
    2/5/2008 9:11:04 AM: Source: SPDIF=&H1001/8
    2/5/2008 9:11:04 AM: Can't Open Source
    2/5/2008 9:11:04 AM: Source: Aux=&H100A/9
    2/5/2008 9:11:04 AM: Source: TV Tuner Audio=&H1000/10
    2/5/2008 9:11:04 AM: Source: CD Player=&H1005/11
    2/5/2008 9:11:04 AM: Source: Line In=&H1002/12
    2/5/2008 9:11:04 AM: Source: Microphone=&H1003/13
    2/5/2008 9:11:04 AM: Source: Phone Line=&H1006/14
    2/5/2008 9:11:04 AM: Source: PC Speaker=&H100A/15
    2/5/2008 9:11:07 AM: Sim.WMSGs: 1
    2/5/2008 9:11:07 AM: Enter Exec: False, menu.skin, , False
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, ONLINE, False
    2/5/2008 9:11:07 AM: Executing: NLIN
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "ONSKINSTART", False
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPANTISTATUS||SETTOPAPPSALL||SETUPMENULABEL01| |SETTOPLABELALL||LSONSKINSTART||SETMPATH||NOTESTAT ||RUNSETUP||CHECKDRIVELETTERS||AUTOPLAY||PLAYSOUND ||", False
    2/5/2008 9:11:07 AM: Executing: SETVARBYCODE;VSTATUS;STATUS
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "EVAL;B_ANTISTATUS;strcomp("PLAY";"$VSTATUS$")||BY VAR;B_ANTISTATUS;ISNTPLAYING<<ISPLAYING", False
    2/5/2008 9:11:07 AM: Executing: EVAL;B_ANTISTATUS;strcomp("PLAY";"STOP")
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "BYVAR;B_ANTISTATUS;ISNTPLAYING<<ISPLAYING", False
    2/5/2008 9:11:07 AM: Executing: BYVAR;B_ANTISTATUS;ISNTPLAYING<<ISPLAYING
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "ISNTPLAYING", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;ANTISTATUS;PLAY
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETVAR;STATUSSYM;1", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;STATUSSYM;1
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETTOPAPPSALL||SETUPMENULABEL01||SETTOPLABELALL|| LSONSKINSTART||SETMPATH||NOTESTAT||RUNSETUP||CHECK DRIVELETTERS||AUTOPLAY||PLAYSOUND||", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;TOPAPPS;AP01<<AP02<<AP03<<AP04<<AP05<<AP06< <AP07<<AP08<<AP09<<AP10<<AP11<<AP12<<AP13<<AP14<<A P15<<AP16<<AP17<<AP18<<AP19<<AP20<<AP21<<AP22<<AP2 3<<AP24<<AP25<<AP26<<AP27<<AP28<<AP29<<AP30<<AP31< <AP32<<AP33<<AP34<<AP35<<AP36<<AP37<<AP38<<AP39<<A P40<<AP41<<AP42<<AP43<<AP44<<AP45<<AP46<<AP47<<AP4 8<<AP49<<AP50<<AP51<<AP52<<AP53<<AP54<<AP55<<AP56< <AP57<<AP58<<AP59<<AP60<<AP61<<AP62<<AP63<<AP64<<A P65<<AP66<<AP67<<AP68<<AP69<<AP70<<AP71
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL01||SETTOPLABELALL||LSONSKINSTART|| SETMPATH||NOTESTAT||RUNSETUP||CHECKDRIVELETTERS||A UTOPLAY||PLAYSOUND||", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP01LB;=Audio
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL02", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP02LB;=VIDEO
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL03", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP03LB;=IG3
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL04", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP04LB;=DVD
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL05", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP05LB;=PHOCO
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL06", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP06LB;=SAT
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL07", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP07LB;=EXIT RR
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL08", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP08LB;=.NET
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL09", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP09LB;=MIXER
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL10", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP10LB;=GAMES
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL11", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP11LB;=PHOTO
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL12", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP12LB;=CAMERA
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL13", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP13LB;=NOTES
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL14", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP14LB;=WIDGETS
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL15", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP15LB;=CALENDAR
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL16", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP16LB;=WEATHER
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL17", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP17LB;=POWER
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL18", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP18LB;=RADIO
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL19", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP19LB;=XM
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL20", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP20LB;=SIRIUS
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL21", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP21LB;=Ext Apps
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL22", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP22LB;=RRCAM
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL23", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP23LB;=RIP CD
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL24", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP24LB;=SENSOR
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL25", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP25LB;=JOOST
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL26", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP26LB;=CONFIG
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL27", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP27LB;=VOID
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL28", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP28LB;=OPERA
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL29", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP29LB;=MAPMONKEY
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL30", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP30LB;=FREEDRIVE
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL31", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP31LB;=IG2
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL32", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP32LB;=IG MENU
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL33", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP33LB;=MENU
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL34", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP34LB;=RATINGS
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL35", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP35LB;=LOCKSCREEN
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL36", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP36LB;=BLACKOUT
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL37", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP37LB;=GAS
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL38", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP38LB;=NEAVE TV
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL39", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP39LB;=WEB
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL40", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP40LB;=MINIMIZE
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL41", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP41LB;=LIBRARY
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL42", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP42LB;=BBAA
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL43", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP43LB;=MINI
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL44", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP44LB;=AUDIO old
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL45", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP45LB;=IG2 MENU
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL46", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP46LB;=TRIP LOG
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL47", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP47LB;=SHUF/REP
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL48", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP48LB;=PLIST
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL49", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP49LB;=EMU
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL50", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP50LB;=EMPTY
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL51", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP51LB;=EMPTY
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL52", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP52LB;=EMPTY
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL53", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP53LB;=EMPTY
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL54", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP54LB;=EMPTY
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL55", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP55LB;=XPLORRER
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL56", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP56LB;=GEARTH
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL57", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP57LB;=TRAFFIC
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL58", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP58LB;=BROWSER
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL59", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP59LB;=EMAIL
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL60", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP60LB;=IM
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL61", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP61LB;=VIDEO
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL62", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP62LB;=FLICKR
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL63", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP63LB;=SYNC FOLDER
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL64", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP64LB;=RSS
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL65", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP65LB;=MAPS 2
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL66", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP66LB;=MAPS 3
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL67", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP67LB;=TASKS
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL68", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP68LB;=TOKBOX
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL69", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP69LB;=MOVIES
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL70", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP70LB;=OPERA
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETUPMENULABEL71", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;AP71LB;=SULLR
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "SETTOPLABELALL||LSONSKINSTART||SETMPATH||NOTESTAT ||RUNSETUP||CHECKDRIVELETTERS||AUTOPLAY||PLAYSOUND ||", False
    2/5/2008 9:11:07 AM: Executing: SETVAR;MAINLABELS;=AUDIO<<=VIDEO<<=NAVI<<=DVD<<=PH ONE<<=SAT<<=EXT<<=.NET<<=MIXER<<=GAMES<<=PHOTO<<=C AMERA<<=NOTES<<=WIDGETS<<=CALENDAR<<=WEATHER<<=POW ER<<=RADIO<<=XM<<=SIRIUS<<=APPS<<=CAM<<=RIP CD<<=SENSOR<<=JOOST<<=OPT<<=VOID<<=OPERA<<=NAVI<<= NAVI<<=NAVI<<=IG MENU<<=MENU<<=RATINGS<<=LOCK<<=BLACKOUT<<=GAS<<=NE AVETV<<=WEB<<=MINIMIZE<<=LIBRARY<<=BBAA<<=MINI<<=A UDIO<<=IG2 MENU<<=TRIP LOG<<=SHUF/REP<<=PLIST<<=EMU<<=EMPTY<<=EMPTY<<=EMPTY<<=EMPTY< <=EMPTY<<=XPLORRER<<=G EARTH<<=TRAFFIC<<=BROWSER<<=EMAIL<<=IM<<=VIDEO<<=F LICKR<<=FLDER SYNC<<=RSS<<=MAPS<<=MAPS<<=TASKS<<=TokBox<<=MOVIE TIMES<<=OPERA<<=SULLR
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "LSONSKINSTART||SETMPATH||NOTESTAT||RUNSETUP||CHEC KDRIVELETTERS||AUTOPLAY||PLAYSOUND||", False
    2/5/2008 9:11:07 AM: Executing: RunQ;C:\Program Files\Road Runner\Skins\LSX VOID 3.0\Ratings\ratecheck.exe|
    2/5/2008 9:11:07 AM: Shell: "C:\Program Files\Road Runner\Skins\LSX VOID 3.0\Ratings\ratecheck.exe"
    2/5/2008 9:11:07 AM: Que Exec: True, menu.skin, "locate", False
    2/5/2008 9:11:07 AM: Executing: locate
  3. #2243
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    ratings will be supported again in an update.
    as for the volume slider, i dont see that being changed, its on every single screen in the skin. I do think there is something i could do to remove the 5 star button but not the purpose of having it. There are 5 dots on the top that are used to set any song playing to a specific rating as well as display its current rating. I could change it so clicking any dot or star will load the playlist for that rating, and click and hold to set a rating. That way i can remove the 5star button and replace it with something else. Or make it custom like the Navi and BBAA buttons and u can choose what u want it to do.
    I wasn't implying to get rid of the slider volume control. I was just saying that it's hard to get the volume all the way down by using the slider control. It's great that the ratings plug-in will be supported again. Did you give any thought to the modified ratings plug-in that I suggested in an earlier post? As for holding the button down, that might get messy when driving. I can see not holding the button down long enough and accidentally rating a song or the other way around. If the rating plug-in is going to be supported again, than the button should stay where it is. Thanks again.
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  4. #2244
    Jul 2006
    @Twinsen, there were some posts many, many pages ago about deleting some dll that pulled up your location for display on the main screen. it was causing some people to experience crashes, i believe. i really dont know exactly what dll or file it is, but basically removing it may get rid of the call to display your location on the main screen and hence get rid of your crash. it is a POSSIBILITY, and i could be COMPLETELY off, but its worth a shot since ur at a dead end. also, make sure ur running the latest void downloaded off the front page along with the patch.
    edit: read somewhere around this area: http://www.mp3car.com/vbulletin/rr-s...ll#post1155571 (both before and after) about ziplocator.dll and see if that provides any insight. i never had the issue so i never paid much attention.
  5. #2245
    May 2006
    Houston
    but i can run it in the car (when i had a carputer). chance?
    ?!?!? All this work and you don't have a carputer? I hope its just a choice (or time?) issue, not financial one!
    Thanks for all your hard work and answering everyones (including my) questions no matter how many times they have been answered or how dumb they turn out to be!
    -GK
    2009 Scion XB
    Mac Mini Intel Core Solo
    RoadRunner w/LSX Void
  6. #2246
    Apr 2006
    Memphis, TN
    Quote Originally Posted by hari-bhari View Post
    I will check this out, I was actually in the process of reading through this entire thread from page 1. I'm up to 35 I think.
  7. #2247
    Apr 2006
    Memphis, TN
    Also, in case this ziplocater solves my issue and I get a fully working GPS, how do I enable the Flash Heading image? I DO have the latest Flash installed, and on some of my re-installs of RR/Void, it would show, then others, like now, it doesn't show. Any ideas on this?
  8. #2248
    Apr 2006
    Memphis, TN
    Welp! Deleting the ziplocater.dll did it! Finally! Now on to my most recent addition to issues! The Flash Heading indicator. Any ideas on what could disable this? Again, I do have the latest video drivers, flash, direct X, the whole shabangabang. Sometimes it would show up, and now it won't at all.
  9. #2249
    Jul 2006
    i know when i had 3.0, i turned the flash compass off once and it wouldnt turn back on after that. are you running the newest version with the patch? if you are unsure, do one last clean install, make sure u delete the skin inside the skins folder AND the lstools folder in the road runner directory. then install 3.2 and the patch off the main page (there has been more than one version of 3.2 on the main page, so redownload it along with the patch) no need to uninstall and reinstall rr though. make sure u redelete the ziplocator file. if it was a flash issue u would get a white box. my guess is that the compass got turned off and there is a bug in turning it back on. look through the ini files (rr.ini and exectbl) to see if there is a parameter for the compass. LS will need to provide more input here.
  10. #2250
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    LS
    love the skin thus far. but a question that i have, how difficult would it be to implent in the skins for fusion brain?
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
