Thread: Lsx Void 3.0
  1. #2271
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Quattro View Post
    If someone great person has the time they can make up a FAQ using all the questions in this thread so LS and just post that in the new thread and it would solve the problem of the questions being asked over again.
    Only problem is who is willing to do this?
    There is an entry in the MP3Car Wiki for just that, if you have any info go edit that.
  2. #2272
    GTO
    GTO is offline
    Newbie GTO's Avatar
    Jul 2007
    Hey LS I'm having a problem using the free buttons.
    When I search for the .exe I want I can't find it. I've added .exe to the file types (.mp3,.wav,.exe) but when I go to the root of my C drive I can only see Documents & Settings and no other folders.
    Any ideas?
    Thanks.
  3. #2273
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by Gurukarma View Post
    Saw an LSX Void user cruising down Bay Area Blvd in Clear Lake Texas last night. Any of you guys?!?
    -GK
    thats cool, i think i saw someone using the skin a long time ago but couldn't really confirm.
    Quote Originally Posted by hari-bhari View Post
    on resume from standby, the first time u visit the audio screen the current song isnt highlighted. the list just stays at the top. then after going to the main menu and going back to audio, the current song is highlighted properly.
    any issues that come up that have to do with hibernation, standby etc and resuming are all RR issues. Not really anything i can do about those issues unless its something that doesn't happen in another skin.
    Quote Originally Posted by venealis View Post
    Sorry for the late reply. But here's a link
    http://www.mp3car.com/vbulletin/fusi...uncements.html
    Personnely i think with this skin and this interface the sky would be the limit. Looking to integrate some oem buttons into RR
    ill check it out.
    Quote Originally Posted by greatwhite View Post
    Hi Smoke,
    Not sure if this has been brought up before or not (the thread's just too bloody long now) but:
    Any chance of adding movie listings to void?
    Seen here:
    http://www.mp3car.com/vbulletin/rr-p...-near-you.html
    It would be a cool little addition. Useful too, when the navigation feature is worked out...........
    ill take a look at the link.
    You do know there already is movie listings in the skin right?
    Quote Originally Posted by Enforcer View Post
    sounds good to me
    Quote Originally Posted by djmickyg View Post
    hey LS
    Small request (if it isn't already implemented)
    would it be possible to get a GPS button that uses the external link in the main RR settings?
    I use DEST7 and I'm sure many other use different ones also.
    Untill now i have just edited your ExecTBL.ini but i think it would be easier for people if they could just change the setting in RRconfig?
    would this be possible?
    the skin supports most of the GPS apps out the box except for mappoint. I dont like the gps menu pop up cuz it just forces an extra step for everyone. isnt mapmonkey and freedrive frontends for Destinator right? cuz both of those are supported. Click and hold the Navi button and choose ur gps app.
    What i could prob do is use the external link , but set up some settings to save what your choice is so u dont have to click it each time.
    Quote Originally Posted by GTO View Post
    Any ideas?
    Thanks.
    ill take a quick look at my settings, but im pretty sure all you need to do is add the file types you want to view (under music settings) and they should show up.
    beer replenishment fund
    mp3car live search
  4. #2274
    FLAC djmickyg's Avatar
    Feb 2004
    Quote Originally Posted by liquid_smoke View Post
    free drive and mapmonkey use Destinator3 which does support many maps after ~2005, so alot of people have moved over to Destinator6 and now 7 (which doesn't imbed to nicley yet).
    I usally just go into your excebl.ini and change the freedrive or mapmoney lines to my Destinator7 path, but this might not be easy to do for some people. so if there was also an ExternalGPS button in you option list, people could change it eisier?
  5. #2275
    Nov 2005
    Regarding the volume strip along the bottom left:
    1. At 100% volume can it be made to cover all the way across to the right, rather than leaving that small gap uncoloured on the right (near the plus)?
    2. I know that volume goes up/down depending on where u press/click in relation to the current volume level. I think thats a great feature, however, can we make it that if you click anywhere in the left 1-2cm (near the -) or anywhere in the right 1-2cm (near the +) it just does a up/down volume respectively? I can never get it down to the lower volumes easily because the current level is so near the corner of the LCD.
    Jul 2006
    Quote Originally Posted by Iceman_jkh View Post
    i think you can get it to fill up the whole slider, its just hard to keep clicking in that corner to get it to get there. if you go into the mixer and increase the slider volume to 100 percent, i beleive then that bar will be fully filled. either way, i would assume that you wouldn't be driving with your volume at 100% most of the time. if you are u may want to turn up your wave volume some or increase the gains on your amp.
    as for the volume going all the way down, i do agree it gets a bit difficult at the end, but the way he has it designed right now, it wouldnt make much sense to click in the last 2 cm after the volume is already down past that point and actually have it go down further. you'd be clicking in the gray area, but actually be goin down.
  7. #2277
    Nov 2005
    Hari, I know what ur saying.. but to me, Id rather sacrifice that 'logical' issue - clicking in grey area - in order to get it a little easier to control at the extremes. I personally dont really look at where the current level is.. I just press either near the + or -. I know LS went to the effort of checking where u press relative to the current state.. but that extra feature is in most cases lost on me while driving and attempting to control the volume.
    I have set the volume to 100% via the main screen, but the bottom volume bar still doesnt fill all the way up.
  8. #2278
    Aug 2003
    Chicago
    ah, i see. So basically i just need to just add support for D7 specifically. Thats not a problem.
    how about i remove the track slider on the right and extend the volume to take up the entire bottom?
    prob wouldn't solve the problem though.
    Why do u want to turn the volume down to 0% instead of mute?
    Just a wild guess, but i assume you guys don't use your HU for volume?
    mp3car live search
  9. #2279
    Nov 2005
    No no.. keep the layout as it.. its good
    I dont run a HU at all. 0% = mute, whereas 1% = a small amount of sound. Enough to be audible. Its that last 4% which has a big difference at night or any other time i need to be a little quiet without being mute. I know I could use ATT, but if my finger is already there, Id rather just press -. It also reacts faster than ATT. Also, I prefer to mute it via 0% than hold the play button down - thats just me though.
    If its a hassle then not to worry. But I def would pref it if the last 1cm on either side was purely - or + only. Not current position dependant. Cheers mate.
  10. #2280
    Aug 2003
    Chicago
    Hi Smoke,
    Seen here:
    just checked this thread out. Looks pretty cool.
    Im not sure where the data comes from, our how accurate it is but it looks like it would be a nice replacement for the current movietimes in the skin.
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 01:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 12:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 09:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 01:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 07:00 AM
