Thread: Lsx Void 3.0
  1. #2291
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by djmickyg View Post
    one problem is Dest6 an 7 are just zipped files, so there is no one set location where people run then from.. mine is in c:\destinator7\destinator.exe, but I've seen a few others
    thats not a problem for me, it'll be setup just like with the other gps apps. You will have to provide a path to your application in the skins settings screen.
    Quote Originally Posted by greatwhite View Post
    Hi LS,
    Have you considered using coverflow for BBAA?
    yes , ive considered it a few times, but there are a lot of issues i have with it.
    1. Its really CPU heavy, like way too much for what it is. Even on fast machines.
    2. ascetically i dont like some of the choices the creator has made with adding a gazillion buttons and huge sliders etc. I want it to look just like it does on my ipod, pictures of the albums and nothing else.
    3. The last version i tested had its own audio player built in. Cool, but why? Thats what RR is for. I see no reason to bypass RR's media management and loose pretty much all the audio features of RR.
    4.Its SLOW (didnt i say that)
    5.Last i checked it was also a bit buggy.
    Void does come with a coverflow folder and there is some coverflow code in the ExecTBL.ini file, but non of it is hooked up to anything anymore and its only there from when i was testing. It was originaly included with the hopes of making it easier to activate later if all the above issues were fixed at some point. I have since gave up on it long ago.
    sorry.
    Quote Originally Posted by GTO View Post
    Hi,
    I've embedded iGO8 into RR but when I touch a button on the GPS screen iGO looses focus and the map stops drawing. In another forum someone said that if I add ||ACTIVATE;iGO8||" to the end of the NEXT PREV lines in the GPS skin file it will sort the problem.
    The thing is that I know nothing about skin files or what to look for.
    Can anyone help, maybe show me an example of where this text should be added and which one of the GPS skin files the lines are located?
    Thanks.
    ps
    Sorry for adding to the hugeness of this thread.
    no need to appologize for posting, thats what this thread is for no matter what the size is. When it gets too big, ill do something about it. But that too big mark is whats too big for me, not everyone else
    anyway. using the activate line would fix the situation, but not really the best way to fix it. You would have to edit every button on the screen to include the activate command. When all you really need to do is send the command to force iGO8 (what is iG08 anyway) to be topmost when you first enter the screen.
    Im not sure what iG08 is or how you have it setup/embeded or what screen etc. But it would take only a few sec and one line of code to fix this for you, if i knew what screen you were using the app on (file name) and how you have it setup to run.
    beer replenishment fund
    mp3car live search
  2. #2292
    Constant Bitrate slvrsol's Avatar
    Mar 2007
    Plus, if you want coverflow, nobody is stopping you from adding it yourself. I agree with LS on some points and am using an older version of coverflow that I modified.
  3. #2293
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by slvrsol View Post
    Hmm.....
    Any chance you might want to make that file available for download?
    I'm just starting to mess with coverflow now (I've got a p4 2.6 Ghz in the car, so it should run), but if you've got a working skin and wouldn't mind sharing..................
    And maybe a little writeup on adding it to void?
    Leonardo Da Vinci
  4. #2294
    Mar 2007
    Unfortunately, it won't be of any use since I wrote my own program to generate the albuminfo.xml file to fit my music structure and I don't have the original. Adding it to void is as simple as defining a flash region to a skin file.
  5. #2295
    GTO
    GTO is offline
    Newbie GTO's Avatar
    Jul 2007
    Quote Originally Posted by liquid_smoke View Post
    iGO is GPS software and all I need to know is which lines to add the active command to for the NEXT and PREV track buttons in viods GPS skin. I've looked at the GPS1.skin & GPS2.skin files but not being a skinner it means nothng to me, I'm not even sure if they are the right files.
    iGO is top most when I enter the GPS screen but as soon as I hit the NEXT or PREV track button iGO looses focus and stops drawing.
    Does that make sense?
  6. #2296
    Sep 2006
    Denmark (Devil Island)
    Now I have read and read.
    I can't see to understand why my skin is looking like this.
    Why the "next", "prev" and "play/pause" are numbers instead of the symbols there are other buttons which letters/numbers instead of what it is supposed to be.
    I have installed LSX and the update 3.2.5
    Please help
    Thanks in advance
  7. #2297
    Jul 2007
    Hi, exist lsx void night skin ?where i can download it?pls give me some link
  8. #2298
    Jul 2006
    Quote Originally Posted by K4BlOs View Post
    no exist
  9. #2299
    Jul 2006
    Quote Originally Posted by HypeTaxx View Post
    Please help
    Thanks in advance
    THAT is weird. try uninstalling the skin, deleting the LStools folder in the RR root and reinstalling. also make sure u are running the latest RR by getting the installer, installing it, and then downloading the newest version off the website (http://guino.home.insightbb.com/download.html). it says its 12-06 but i think its actually 12-13.
  10. #2300
    May 2007
    Ummm.............void is, essentially, a night skin. There is no day skin yet.
    Download link?
    You gotta be kidding.
    Look at the very first post.....................
    Leonardo Da Vinci
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
