have deleted the file named ziplocator.dll working fine so far will update. soon
Printable View
Nope, mine cuts it off too. And I have the radio hooked up. It's most likely how the eal estate is alloted in the skin. Probably a font size or something similar somewhere. It's never bothered me enough to go looking for it.
About the only usb radio that offers Am is radioshark (also the HQCT), but it's absolutely worthless on am, I had one of those too.
Trust me, radioshark+AM=useless.
Cheers
its an easy fix, and will come this weekend.
This may have been covered somewhere but I call my self looking and did not see it. Is the re a way in the Sirius skin to get it to display the channel logo's?
Have you figure out the solution to your flickering problem? I tried to update to the newest directx 9 but it only cause RR to lock up. I did a system restore and now RR only locks up when using Lsx void 3.3. When I switch to another skin, everything works fine. Any help?
I tried to re-install direct 9.0c, reinstalled flash, reinstalled lsx void 3.3 and even tried uninstalling my codecs incase that was a problem. Nothing seemed to work.
I installed everything on my fresh xp pro at work and no flickering, so i am assuming it has something to do with my video card drivers, but i updated those and still the same problem, so not sure what to do next.
Wish i could be of further help. Its not that big of a deal as the options still work, but would be nice to get this fixed..
I just downloaded a gui for the dsatx brainstem provided by member at_b.
DSATX GUI Interface
I have embeded the application which is done in flash manually in ExecTBL.ini in void directory with the directions on that file so i can choose the app and put on a button.
I then created a skin file to incorporate the external application which i did by grabbing another skin file as a template.
Everything looks good exept for a few problems.
On the bottom of the screen i have attache the volume indicator and the song positon bar.
For some reason i can't adjust the volume or even the '+' and '-' icons are not showing up.
I have attached a screen shot of what it looks like and also provided the contents of the skin file. If anyone could assist that would be great.
http://www.mp3car.com/vbulletin/imag...3479bc1588.png
contents of dsatx.skin file:
RoadRunner Skin
RRScreen DSATX
/, F, x, y, w, h, Movie name
F,0,45,800,640,"dsatx.swf"
/, INC, FILENAME
INC,LSXCOLORS.txt
/, Y, Back Slider file path
Y01,"vslider1\slider_*.gif"
Y02,"vslider2\slider_*.gif"
/, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
S01,9,440,390,35,9,440,390,35,H,01,"vslider1\point er.gif",013,"MASTER",
S02,399,440,390,35,399,440,390,35,H,02,"vslider2\p ointer.gif",043,"SONGPOS",
/, I, x, y, w, h, Code;INDICATORCODES
I,210,1,28,27,"HEADING"
I,541,-7,30,36,"ONLINE"
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B,0,-1,212,40,"MAINBT37",@HOLDMAINBT37@
B,577,-2,223,40,"ESC",
B,315,0,156,38,"MAINBT38",@HOLDMAINBT38@
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L09,13,6,34,27,#COL3R#,#COL3G#,#COL3B#,6,"Webdings :B","=g g","LEFT"
L09,13,19,35,27,#COL3R#,#COL3G#,#COL3B#,6,"Webding s:B","=g g","LEFT"
L09,44,8,90,27,#COL3R#,#COL3G#,#COL3B#,#SIZE1#,#FO NT1#,"TIME","CENTER"
L,625,8,160,27,#COL3R#,#COL3G#,#COL3B#,#SIZE1#,#FO NT1#,"=CLOSE","CENTER"
L,321,2,131,31,#COLGR#,#COLGG#,#COLGB#,#SIZE1#,#FO NT1#,"= ||GPSSPD","RIGHT"
A,0,42,800,394,
L,22,437,61,21,#COL3R#,#COL3G#,#COL3B#,#SIZE1#,#FO NT1#,"=_","LEFT"
L,352,444,34,28,#COL8R#,#COL8G#,#COL8B#,#SIZE1#,#F ONT1#,"=+","RIGHT"
END
Any help would be appreciated.
I'm trying out this skin and I keep getting "Playsound has encoutered a problem" right after it starts up. What can I do to fix this?
d
