I just downloaded a gui for the dsatx brainstem provided by member at_b.
DSATX GUI Interface
I have embeded the application which is done in flash manually in ExecTBL.ini in void directory with the directions on that file so i can choose the app and put on a button.
I then created a skin file to incorporate the external application which i did by grabbing another skin file as a template.
Everything looks good exept for a few problems.
On the bottom of the screen i have attache the volume indicator and the song positon bar.
For some reason i can't adjust the volume or even the '+' and '-' icons are not showing up.
I have attached a screen shot of what it looks like and also provided the contents of the skin file. If anyone could assist that would be great.
contents of dsatx.skin file:
RoadRunner Skin
RRScreen DSATX
/, F, x, y, w, h, Movie name
F,0,45,800,640,"dsatx.swf"
/, INC, FILENAME
INC,LSXCOLORS.txt
/, Y, Back Slider file path
Y01,"vslider1\slider_*.gif"
Y02,"vslider2\slider_*.gif"
/, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
S01,9,440,390,35,9,440,390,35,H,01,"vslider1\point er.gif",013,"MASTER",
S02,399,440,390,35,399,440,390,35,H,02,"vslider2\p ointer.gif",043,"SONGPOS",
/, I, x, y, w, h, Code;INDICATORCODES
I,210,1,28,27,"HEADING"
I,541,-7,30,36,"ONLINE"
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B,0,-1,212,40,"MAINBT37",@HOLDMAINBT37@
B,577,-2,223,40,"ESC",
B,315,0,156,38,"MAINBT38",@HOLDMAINBT38@
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L09,13,6,34,27,#COL3R#,#COL3G#,#COL3B#,6,"Webdings :B","=g g","LEFT"
L09,13,19,35,27,#COL3R#,#COL3G#,#COL3B#,6,"Webding s:B","=g g","LEFT"
L09,44,8,90,27,#COL3R#,#COL3G#,#COL3B#,#SIZE1#,#FO NT1#,"TIME","CENTER"
L,625,8,160,27,#COL3R#,#COL3G#,#COL3B#,#SIZE1#,#FO NT1#,"=CLOSE","CENTER"
L,321,2,131,31,#COLGR#,#COLGG#,#COLGB#,#SIZE1#,#FO NT1#,"= ||GPSSPD","RIGHT"
A,0,42,800,394,
L,22,437,61,21,#COL3R#,#COL3G#,#COL3B#,#SIZE1#,#FO NT1#,"=_","LEFT"
L,352,444,34,28,#COL8R#,#COL8G#,#COL8B#,#SIZE1#,#F ONT1#,"=+","RIGHT"
END
Any help would be appreciated.
