Thread: Lsx Void 3.0
  1. #2371
    Jun 2007
    Quote Originally Posted by liquid_smoke View Post
    also, i just caught this.
    When you install the skin, you should not point the installer to the skin dir in RR, you should point it to RoadRunner's root path.
    So the installer should point to
    C:\Program Files\Road Runner\
    Your copy of RR can be installed anywhere u like, but the skin must be installed into RR in the proper dir, which is RRs root folder.
    So when everything is done you should have a folder in the root of your RR install named "LSTOOLS" and the actual skin should be located in \Road Runner\skins\LSX VOID 3.0.
    Ok, I'll uninstall and re-install in the root dir and let you know later this evening.
    Thanks!
    d
  2. #2372
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    what does that app do? If its something a lot of people use its prob a good idea for me to include it by default.
    RSX is correct. It is an app that allows control of the dsatx through a gui instead of using hyperterminal.
    I'm sure we all know what a dsatx is (intelligent 220w power supply). It has many user set-able options, but the .swf app is a nice way to see and adjust all the options of the power supply.
    And I'll be "user number two" that would like to see it included as I use a dsatx with brainstem as well.
    If you could include it in the skin, that would be great!
    Cheers
    Leonardo Da Vinci
  3. #2373
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by greatwhite View Post
    Cheers
    sounds pretty cool, i had no idea what dsatx was since i dont actually have a carputer. When i did though i had an opus psu and i suspect that it was part of the reason my original carputer died. So i likely wont be getting another one. This dsatx sounds pretty cool though, so when i do get a new carpc ill def look at getting one of these.
    Im working on an update right now, dealing with some timer issues holding it up so i cant promise ill add the dsatx in this update, but i can add it as its own update. But we'll see, what i can do if this timer crap dont drive me crazy.
    beer replenishment fund
    mp3car live search
  4. #2374
    Aug 2003
    Chicago
    actually, if TeamRSX would post his modified .skin file for the dsatx and the swf file ( plus any other needed files ), i can add it right now and include it in the update. Since im assuming the screen is mostly for setting and changing options on the power supply and not a screen that you would constantly have up, i can add it directly to the options screen instead of having to shuffle button commands around to integrate it into the dynamic buttons.
    mp3car live search
  5. #2375
    May 2007
    DSATX info:
    http://store.mp3car.com/Mp3Car_DSATX_p/pwr-023.htm
    And;
    http://mpegbox.com/products.html
    Zootjeff makes them and keeps forums at mpegbox. And he actively supports it both here and at mpeg box. Seems like a great guy.
    I've been running one for about a year and a half on my p4 system, love it. Works without a hitch, everytime. Never had a dead battery, survives crank, works in -30 C weather, etc. I just can't say enough good things about it.....
    Adjusting the settings through hyperterminal was a bit of a pain though until the GUI project started.
    Highky recommended purchase for any carputer.
    Littel pricey compared to some of the cheaper PS's out there, but as far as I'm concerned you get your money's worth.
    "You get what you pay for" defineatley holds true here. You pay a bit more but get a great dependable product and support to boot!
    Cheers
    Cheers
    Leonardo Da Vinci
  6. #2376
    May 2007
    I can't help with the skin file, but here's the thread with the .swf file in .rar and teamrsx's posts about getting it to work:
    http://www.mp3car.com/vbulletin/soft...interface.html
    Cheers
    Leonardo Da Vinci
  7. #2377
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    ok, you did the right thing.
    The problem i see is your Flash file is infact overlapping the bottom volume controls. Its set to be 800x640 and nothing should be set that big in the skin as the skin itself is only 800x480 and all edits should be done with that in mind. When you change the skin res to 800x600 via options everything scales relative to the original.
    change your F line to look like this
    F,0,42,800,394,"dsatx.swf"
    that should fix ur overlap and also size it to properly fill the correct area.
    Thanks for your help LS. After i changed the F line as you suggested everything is perfect.
    Appreciate your help.
  8. #2378
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Anyone know where this file is coming from?
    I get it every time I use the installer. Pain in the *** the first time when I didn't know what was crashing RR.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  9. #2379
    Nov 2007
    Ottawa, Ontario
    LS,
    I have attached a .rar for all the files for dsatx gui application.
    Please note you will need a serial to tcp/ip software converter to connect to brainstem comm port on the DSATX. Most ppl use comfoolery, but seems its hard to find.
    Included is the following:
    dsatx.swf - I think its the most current app.
    dsatx.skin - skin file i used which works great
    cf.au3 - autoit script that minimizes comfoolery at launch
    Here is the URL to the original threat for this software provided by member at_b
    DSATX GUI
    Blair
    Attached Files Attached Files
  10. #2380
    Aug 2003
    Chicago
    Quote Originally Posted by Quattro View Post
    thats what i kind of figured. Ill post something in the installer thread, not sure how good it will do though as neither RR or the Installer have been updated in months.
    Will add a note on the first page about it though also.
    Quote Originally Posted by TeamRSX View Post
    LS,
    DSATX GUI
    Blair
    cool.
    I dont have the hardware so im not sure if even need to bother with the converter. Its kind of odd though the converter is online, so for this all to work you also have to have an online connection?
    either way, im gonna pass on doing it tonite, ive been screwing with the timer **** all day and need a break. I prob need to read through that thread though and know of any issues etc before i add it in as default. Dont want to rush it as it seems it requires a few things.
    so ill post the update in a bit and work on the dsatx update as a separate update for those that have the hardware.
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 01:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 12:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 09:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 01:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 07:00 AM
